Ford 302 intake question
Discussion in 'The Hokey Ass Message Board' started by Greaser Bob, Nov 28, 2008.
  1. Greaser Bob
    Greaser Bob
    Can any one tell me if it is possible to swap the port injected '95 Ford 5.0
    intake with a carburatored intake ? Pulled it from my truck because it had
    a knock, and I'll rebuild it and use it in my '29 A if I can get away from using F.I.. Thanx!
  2. tjsr19
    tjsr19
    from Lincoln NE
    I am in the same boat mine is a 93 f150 though.
  3. twofosho
    twofosho
    When I got my Fairlane the previous owner had swapped to a 5.0 Mustang injection unit on the original 289 with an early non feedback computer adaptation and electric fuel pump mounted in the fuel line laying in the trunk. Going back to an aluminum intake, four barrel carburetor, and point type distributor and also plan to do so with the 88 5.0 destined for the 26 T that I pulled from a Mercury Marquis.
  4. hotroddon
    hotroddon
    Yes, any 289/302 intake manifold will fit the fuel injected motors, heads are the same. If it's an AOD trans you will need a special bracket for the trans cable
  5. Greaser Bob
    Greaser Bob
    Thats awsome! Now I'm wondering if there is such a thing as a 3x2 intake
    that will vintage-ize the the look of the beast?!
  6. hotroddon
    hotroddon
    Yes there are, but they are pretty pricey when you find one
  7. dirtbag13
    dirtbag13
    yes it is possible i have done it in a couple cars of mine , as stated above if you are running the aod behind it make sure to get a bracket to hook up th tv cable from the trans to the carb and get it adjusted properly or it will ruin the trans, tri power and dual quads are both available but are pretty pricey, check out blue thunders website if you are lookind for an original type over the parts counter setup tri power !
  8. kellym
    kellym
    from Menlo Park
    Search on here, there's a guy in australia making a 3X2 adapter that bolts onto the fuel injection manifold
  9. ynottayblock
    ynottayblock
    there is also a guy in this neck of the woods doing the same, he is a hamber but dont know how often he comes on. Uses the lower efi manifold, seals the injector holes and makes an aluminum adapter
  10. Greaser Bob
    Greaser Bob
    Yah man with the upper portion of the intake off it looks entirely
    possible to fab some type of top end to accept 3 two's. But I do
    not own the tools or skills to be able to make one at this time. I know
    so little about these engines to begin with but if I can get r done it would
    be cool!
  11. THE FRENCHTOWN FLYER
    from FRENCHTOWN
    I made up a faux tri-power for my tub using three Rochester 2GCs (turned backwards to clear the front-mounted distributor), a stock 2V intake,and a 3/8" adaptor plate. Used dummy fuel lines n linkage. Fools most people. Cost me $23 plus a little Bridgeport time.
    Of course only the middle 2V is functional,but in a 1700 lb car I can still get into plenty of trouble with it.
  12. Reverendcolin
    Reverendcolin
    Anyone know if I can use a set of GT40p heads with an older carb manifold?
    BTW it's an 85 flat tappet motor.
  13. hotroddon
    hotroddon
    Yes you can, but the spark plugs are relocated on GT40P heads and headers can be an issue
  14. sunbeam
    sunbeam
    Jegs sells the Edlebrock 5412 three x two intake for $285.99
  15. Mike51Merc
    Mike51Merc
    You can use GT40P heads on a flat tappet motor, but make sure you carefully measure for pushrod length.
  16. deathrowdave
    deathrowdave
    from NKy
    I have aluminum 2v intake somewhere great for faux deuces
  17. mike bowling
    mike bowling
    This was a fuel injected 302-- with the ram horn off and a custom block-off plate/intake a machinest buddy of mine made for me.Running two single barrel Holleys(mounted sideways) that were from slant six Plymouths. It got a few double-takes! AND it ran good.
    Greaser Bob likes this.
