Hot Rods how do u remove 55 bel air trim below side windows?
Discussion in 'The Hokey Ass Message Board' started by bigvinny, Sep 19, 2014.
  1. bigvinny
    bigvinny
    trying to get trim off my 55 bel air post. any tricks to do this with out damage?
  2. Engine man
    Engine man
    from Wisconsin
    I'm thinking that the clips are threaded studs but someone will know for certain.
  3. 56don
    56don
    Man, its been years since I removed mine but I also think the clips have threads on them and you access them from the back side after you remove the interior panels.
  4. neb-rivet
    neb-rivet
    from Nebraska
    Going from memory, on a hardtop there are screws that can be accessed after the side gl*** is removed same as the doors. I do not recall spring clips on this trim.
  5. rfraze
    rfraze
    Get an ***embly manual from Danchuk and catalogue while you are at it.
  6. Hot Rods Ta Hell
    Hot Rods Ta Hell
    IIRC, the Bel Air below window trim is held with screws driven through the whisker strips and a clip at the front of the trim. The curved "C" post has clips that snap in holes, but I'm pretty sure it also has a single stud clip and the nut is accessed through the trunk. Trim above the window is also held by snap-in hole type clips.
    As rfraze mentioned, the (repoped) 55 Chevrolet ***y manual is invaluable.
  7. squirrel
    I don't think the Fisher body stuff is in the ***embly manual...
    Standard procedure is to remove whatever is in the way, so you can get your eyeballs up in there, and see what is holding it together.
  8. rfraze
    rfraze
    The tricky part of trim on these cars is that sometimes you have to remove a different piece of trim to see the "hidden" fastener on the ones you want to get off. My first experience with these cars was a Belair 2 Door Hardtop. Get the book, whichever one it is. I imagine that all cars wearing a lot of stainless have their little secrets and special tools. Reverse the order when putting it back on and do not forget to weatherproof the fastener holes properly, like with that black rubbery rope sealent.
  9. Special Ed
    Special Ed
    Back window molding simply snaps in/out. The front windows (if I remember correctly) snap in/out, but are also attached (only) near the ends (two on each piece of molding), with threaded clips.
  10. rfraze
    rfraze
    Think you are right. It might be a Fisher Body Service Manual you need. Dealing with the difference today on another project.
