Technical Nailhead in model a
Discussion in 'Traditional Hot Rods' started by fine29, Aug 17, 2014.
  1. fine29
    fine29
    from Des Moines
    When putting a nailhead In a model a ch***is should the intake be level or should the starter?
  2. The intake should be level...........That being said, I like the looks of a Nailhead when the valve covers are level. I 'm running a log intake on my 401 so with the intake level the motor is level also. Not much help am I?
  3. tfeverfred
    tfeverfred
    The engine should have a bit of inclination. I can't remember the degrees, you'll have to look it up. An intake usually compensates for that inclination, making the carb sit level. I'm going to go out on a limb and say that just about anything attached to the engine would have the same inclination as the engine.
  4. fine29
    fine29
    from Des Moines
    With the engine, starter/valve covers level the intake leans forward or high in the rear
  5. The bottom line is the carbs SHOULD be level............As you can see in the picture, the carbs are level, the valve covers are level and the motor is level.......................Most other intakes will be high in the back but there are ways to work around that. 100_5863.jpg
  6. fine29
    fine29
    from Des Moines
    ImageUploadedByH.A.M.B.1408318594.897563.jpg ImageUploadedByH.A.M.B.1408318607.011372.jpg so could my intake be raised slightly in the back? Could it be on backward?
  7. tfeverfred
    tfeverfred
    "Could it be on backward?" Sure it could. Lots of fabbing, but anything is possible.:D
    Here's some info from a 15 second GOOGLE search:
    "Engine, pinion angle and ride height are all relative to the ground. Most engines are set at 3 degrees, when you look at the side of the intake manifold on a carburetor engine you will notice the manifold has a wedge in it. This wedge is to allow the carburetor to sit level. The main purpose of having an engine angle is to allow for more room in the p***enger compartment by having a smaller tunnel. That is why the car manufacturers build front engine cars with the engine at an angle. Drag race cars have a 2 to 3 degree negative engine angle, the engine will tip down in front. Having this negative angle allow for better weight transfer to the rear of the ch***is. The 3 degrees you keep hearing about is the recommended angle for carburetor cars with intake manifolds set at 3 degrees. With the engine and pinion set at 3 degrees they do not line up directly and requires you to make them parallel. This misalignment allow the u-joints to rotate on a street car."
    Read more: Determining Engine and Pinion Angle http://www.roadkillcustoms.com/hot-rods-rat-rods/hot-rod-engine-pinion-angle.asp#ixzz3AhMYjlQz
    So, what angle did you set your engine at? I'm sure there's a thread about it some where.
  8. fine29
    fine29
    from Des Moines
    Well for it to be level at the valve covers and starter it is at 0 maybe 1 degree down
  9. fine29
    fine29
    from Des Moines
    From your link though I gather that the engine does not have to be level and should have some rearward drop to it.
  10. fine29
    fine29
    from Des Moines
    It's in the intake I measured and it is 4.5 in the front and 5.5 in the rear
  11. tfeverfred
    tfeverfred
    That was just something that I found that may apply to your situation. I didn't even look at the link. But one of the things I learned a while back is engine placement and setting the carb level. It made sense, so I keep it in mind. Do ALL cars require the carb base to be 3 degrees? Maybe not. But those engineers did a few things for a good reason.
  12. something a long time Hotrod builder taught me was that with an angle finder sat on the carb pad, reading level that is where the engine needs to be mounted if that makes sence, as this helps set up the engines "fall back" angle "incase of any engine mount failure", so from the side as said above the intake rear will usually be sitting higher than the front, and the valve covers/engine leaning back, but this could be different with Nailheads though I believe it depends on the intake setup too
    hope this helps
    Charlie
  13. mgtstumpy
    mgtstumpy
    Don't forget to check both directions as indicated, lengthwise and across the engine. It's all about float levels, when both directions are level the engine should be then roughly 3 degrees down at rear. Engineers spent $M on R&R, I take advantage of their experience and try not to reinvent the wheel. Differential will be then 3 degrees up otherwise you'll suffer strange driveshaft harmonics. One thing follows another.
  14. iafraser39
    iafraser39
    from Warmland
    I have a 401 nailhead in my model A R.P.U.
    The back of the engine is 3/4 " lower than the front
    when measured to the frame. I think I put the angle at 3 degrees.
    Illustrious Hector and Hotrodmyk like this.
  15. fine29
    fine29
    from Des Moines
    Thanks I figured it out lol. I think that's another thing that is different on these than the sbc haha.
  16. slimpick
    slimpick
    My level-angle isn't the most accurate, but from my own experience it is 4 or 5 degrees for a 401 or 425 with the stock 4 barrel carb manifold.
    1927graham likes this.
  17. LOU WELLS, CTAV8, loudbang and 2 others like this.
  18. fine29
    fine29
    from Des Moines
    Looks good. I just picked up my steering wheel and column and mocked my floors out in cardboard lol
  19. fine29
    fine29
    from Des Moines
    Picked up a radiator shell today and figured I would set it up really quickly to see how much I am going to have to Bend my headlight mounts and get an idea on upper shock mount position. ImageUploadedByH.A.M.B.1412050902.176115.jpg ImageUploadedByH.A.M.B.1412050915.158245.jpg ImageUploadedByH.A.M.B.1412050925.608590.jpg
    Hotrodmyk likes this.
  20. fine29
    fine29
    from Des Moines
    ImageUploadedByH.A.M.B.1412559488.092742.jpg ImageUploadedByH.A.M.B.1412559499.943265.jpg ImageUploadedByH.A.M.B.1412559514.725511.jpg ImageUploadedByH.A.M.B.1412559531.792310.jpg ImageUploadedByH.A.M.B.1412559544.809304.jpg
    Got the top insert tacked in place ran out of welding wire so had to stop for the night
  21. BLUDICE
    BLUDICE
    Your're going to have alot of fun stepping over those "cool" hot pipes - been there done that!!
  22. Bam.inc
    Bam.inc
    from KS
    I don't usually like the gallery of critical comments, but I'll have to agree, this time. Please re-engineer those pipes. After you instruct every p***enger & every kid "don't burn yourself" You'll stick your leg to it too. Good luck
  23. HOTRODPRIMER
    HOTRODPRIMER
    Having fried my leg on the side pipe exhaust of a friends plastic cobra,,I hate them,,if they stick out as sure as the sun comes up in the morning somebody's kid is gonna grab hold of one of those pipes ad get severely burnt. HRP
  24. fine29
    fine29
    from Des Moines
    The plan with the pipes has always been to shorten them and angle cut them.
  25. edwardlloyd
    edwardlloyd
    from Germany
    The problem is. You'll end up breathing fumes and get a headache and feel sick.
    AHotRod likes this.
  26. edwardlloyd
    edwardlloyd
    from Germany
    I've got the same issue actually. I'm putting a Nailhead in a '27 roadster. The Nailhead is a very tall engine. I don't want the carb sitting up above the cowl. It actually limits how low I can go with the car. If I could level the engine it would lower it and the entire car.
    Maybe I can have the intake machined level?
  27. fine29
    fine29
    from Des Moines
    Why not level the intake?
  28. Saxman
    Saxman
    As stated, you're going to need 3-4% down for driveline phasing. If the intake is higher in the back that should get it pretty close to level, I would think. I always measure the angle at the transmission tail shaft but I would think you could also measure it at the starter.
  29. 55willys
    55willys
    The carbs will work with a little off angle, or you could machine it level weld up the stud holes and retap at new level. As for drive shaft angle most hot rods have the opposite problem than the oem's have, the drive shaft is usually going uphill to the rear increasing u-joint included angle. The engine and rear end should have the same angle within a degree dependent on your suspension design.
    The key to drive shaft angle is that it needs to be the same on both ends and the included angle of the u-joint should not be more than 5 degrees. I have had to use a double cardon joint at the front and tilt the rear end down to within 1/2 degree of inline with the drive shaft to make the drive shaft not vibrate and the rear u-joint to work and lubricate itself.
    The reason for the u-joint angle to be the same on both ends is that as the joint goes through its rotation angle the drive shaft speeds up and slows down twice per revolution. Having the angles the same means that the rear joint is canceling out the front joint and all the speed changes are in the drive shaft. When you are greater than 5 degrees included angle on the u-joints the speed changes start to be felt as vibration because they become more violent as angle increases. A double cardon joint cancels it self out letting the drive shaft run at a constant speed.
    Isn't it funny how when you are building hot rods one change can affect so many other things and one needs to think like an automotive engineer. Jim Ford
  30. edwardlloyd
    edwardlloyd
    from Germany
    Well we are Automotive engineers. Only difference is we're not on OEM wages with pensions built in:)
    In the Model-T roadster, the engine and transmission centerline will be an inch or so lower than the axle centerline. (16" wheels) so I can run the Nailhead level and have the driveshaft run uphill to the axle.
    BTW. This lightweight car has over 300hp. I'll want it to launch well. It doesn't want to embarr*** itself on the 1/8th. I'm having to balance a build here which runs a compe***ive 1/8th, looks 100% mid-fifties authentic and fulfills my aesthetic requirements too. Anyway I'm hijacking this guys thread here. I'll start my own build thread soon.
