Projects Chevy Hardtop Chop
Discussion in 'Traditional Customs' started by Grant_Maclean, Aug 31, 2014.
  1. atomickustom
    atomickustom
    The Ernst car is my all-time favorite and a great chop to emulate!
    Eric H likes this.
  2. 'Mo
    'Mo
    Kieth Ashley is responsible for the Ernst clone, and is a HAMB member. I don't remember his HAMB name, but maybe he could be of help.
    kidcampbell71 and Eric H like this.
  3. CadMad
    CadMad
    If you are talki.g about cutting the gl***, then it must be laminated , You can cut laminated. I have a 53 eldo and had to make amould to slump tbe screen into . Moran gl*** in Brisbane did it for me. I suspect your fear gl*** istempered/toughened. look at tge edge can you see a seam?
  4. Torchie
    Torchie
  5. Eric H
    Eric H
    Love the car and where your going with it. Sinking the gl*** might be your best option here. I also think slightly pancaking the trunk lid slightly would change the look of the roof flow.
  6. Great work keep it up. Is that the park in Rockhampton in the background??
  7. Grant_Maclean
    Grant_Maclean
    Alright guys. So I've been pretty busy and haven't had much time to work on the car. But I did abit today on it. I talked to the gl*** guy and he said to go with Lexan. So, with that in mind I decided to re shape the rear window section a little.
    I never liked the wide pillar section on the Ernst car, but it has grown on me alot the last couple of weeks and it just seems like the way go to. I don't know how the Barris guys did it, I can't figure it out but I've got it pretty close I think. I took measurements of the pillar and scaled it up and all that so it should be pretty close.
    Also, I found more rust and ****. Pretty annoying but I was expecting it.
  8. Grant_Maclean
    Grant_Maclean
    I couldn't get the side window bottom sections to lay right so I cut them out and have tacked them back on where I think they should sit.
    New cat walk section. Decided to do it in a couple of pieces, just to make it easier to handle etc.
    Making the paper pattern for the side area. Helps to know what size to cut the steel out, where to put the bends and gives you an idea of what part needs to be shrunk/stretched.
    Panel started. It looks abit funny in the picture, Not so bad in person. I'll take it to work tomorrow and use the shrinker rather than putting hammer marks in from stack shrinking with the hammer.
    Here's a comparison to the old gl***.
  9. dtracy
    dtracy
    How do the back window corner pieces fit if you swap sides?
    Dave.
  10. Grant_Maclean
    Grant_Maclean
    I actually did try that, nowhere near it haha.
  11. atomickustom
    atomickustom
    Are you in Australia or somewhere? I don't recognize that 4-door car in the background.
    Nice work so far. You are making me really look more closely at the Ernst Chevy than I ever have, and it's my all-time favorite kustom. Go man go!
  12. Hdonlybob
    Hdonlybob
    Really looking great...
    I personally like the original roof line, and when I started reading your thread I thought...oh ****....but hey, me was WRONG...
    Will be one awesome car when done...very nice work :)
  13. 56don
    56don
    Did you chop the front the same amount as the back? If you did then it looked to me like the Barris car had it chopped more in the front than in the back.
  14. carlitoswhay
    carlitoswhay
    Nice chop and the car lools way better now
  15. ct1932ford
    ct1932ford
    Nice looking chop!
  16. chevy54man
    chevy54man
    from NC
    Great looking chop, man I love the looks of a chopped hardtop~
  17. FASI
    FASI
    The center gl*** needs to be laid forward, not sunk into the quarters or the catwalk. The corner pieces on my car are aircraft quality acrylic plastic formed over a buck I made by an aircraft windshield maker. The shape is different than what a stock gl*** can be cut down to IF you could cut stock gl***.
  18. chopolds
    chopolds
    from howell, nj
    I did the same thing as Keith (FASI) on my 55 Olds (with a 57 back gl***). Lean the center until you have the look right, then make new side windows out of Lexan. I usually don't like the use of plastic for gl*** on cars, but here it was unavoidable.
  19. 56don
    56don
    Man, that is a really nice look.
    40fordtudor likes this.
  20. atomickustom
    atomickustom
    FASI! I tried to PM you recently, but the new "conversation" format stymied me!
    I have read several times that the windshield was leaned back on your car/the original. Is that correct? After looking at several photos and posting a thread about it here on the HAMB I'm still not sure??
  21. Grant_Maclean
    Grant_Maclean
    Yeah mate, I'm in Australia. I'm guessing you're talking about the gold one? It's a 78 Ford Fairlane.
    No, the back is about 3 1/2 and the front is about 3/38
    I have laid the center gl*** forward, but I have also added an inch or two into the catwalk. The reason for this is the thing that's really got me stumped on your car. If I don't add to that catwalk, then I need to add more into the roof, which means I need to angle the side gl*** parts back to keep from making the rear pillar too wide. Though looking at the picture comparing mine to the original, it looks as if that angle is roughly the same. I might be able to get a little more length out of the screen if I laid it out abit flatter, but once again comparing it to the original it looks like mine is almost flatter. The only way I can explain it is if the front pillars were laid back like Atomickustom has said. I'm not going for an Ernst clone so it doesn't bother me if the chop is slightly different. As long as it looks similar, it's just got me stumped as to how it was done. Hope to hear back from you FASI
  22. Grant_Maclean
    Grant_Maclean
    It's been slow progress, had alot on the last couple of weeks.
    R/H panel made up pretty much ready to weld in.
    Both catwalk sections made up.
    Hard to tell in the ****ty photo but the L/H sail panel or whatever you want to call it is not far off being done. Just need to order an Oxy set then I'll be on my way to having the outside done.
  23. chopolds
    chopolds
    from howell, nj
    It's OK to play with the catwalk. If you have a good eye, you should be able to balance the angle of the rear window, with the slope of the roof to come up with the best look. Just be sure to step back to a distance, and look at the car fom all angles to see if it looks right. As long as you can work with the gl***, getting the profile looking right is the most important thing!
  24. 'Mo
    'Mo
    Grant, I snapped these photos of an Olds at TRJ show this weekend, with your car in mind.
    Unfortunately, I could not find the owner to ask questions, but the rear window appears to be all gl***.
    Anyway, it might inspire, if not inform.
    Eric H likes this.
  25. Grant_Maclean
    Grant_Maclean
    They're interesting photos. It's hard to tell if the catwalk has been played with, but looking at the trim at the top of the quarter it looks like he may have lengthened the roof, that could solve some issues with the wind up quarter gl*** as well.
  26. morac41
    morac41
    Hi Grant .... Gotta keep the 3 piece rear screen....have done the same on a 49 Caddy and kept the 3 piece screen....find an old timer glazier he will cut the 2 end toughened gl*** pieces to shape...a few pics of the gl*** this is a 5 " chop at the rear had to extend the cat walk 5-6" lay the gl*** frame forward about 12" to get a smooth body flow
  27. FASI
    FASI
    My windshield post are not laid back. The top slides forward to meet the posts when cut. The rear center window was laid forward to flow with the top lines. The rear outside surface of the top was sliced and pieces added to continue the flow. The top at the rear narrows by chopping so the width has to be recovered. Nothing was done to the bottom corner window channels other than dress the joint as the channel gets shorter when chopped. See the thicker "C" pillar on my car. The acrylic replacement with aircraft quality acrylic is the way to go for clarity, color and scratch resistance over Lexan. I hope this helps.
  28. atomickustom
    atomickustom
    I KNEW IT!! Do you realize how many books out there start describing the Ernst Chevy by referring to the windshield being laid back? I think even Pat Ganahl has repeated this, and I know I've seen specific numbers!
    Thank you for clarifying that, FASI, it's been driving me crazy for a while now. (Sorry if I'm hijacking your thread, Grant, I'm just happy to get this information.)
  29. atomickustom
    atomickustom
    Regarding the aircraft-quality acrylic, I used to work at a very busy airport/flight school and I've cleaned a LOT of Cessna windshields over and over and FASI is correct, that stuff does not scratch easily and does look like gl***.
  30. CadMad
    CadMad
    I made acrylic and polycarbonate skylights for 25years. . . but if it was me I'd go gl***. Architecural gl*** bending companies are able to do it. shop counters etc have bent gl***. Moran gl*** did a whole wrapped screen for my 53. . but i made the mould. On your small cornrs its an easy make.
