Technical Ford type C 4 banger
Discussion in 'Traditional Hot Rods' started by the vonstripers, Aug 6, 2014.
  1. the vonstripers
    the vonstripers
    from france
    What do you think about this, i would like to run it, in a 30's looks model A racer.
    NOS high compression aluminum head, NOS BURNS intake, new stromberg 97's,
    i found a 81's stromberg, and seems to be better for this motor,
    NOS VERTEX magneto, cal custom air filter....
    patmanta, bonesy and flyin-t like this.
  2. Pierre H
    Pierre H
    from france
    Great set up !
    Ready for a street racing contest ;)
  3. waxhead
    waxhead
    from West Oz
    what sort of head is this??
  4. waxhead
    waxhead
    from West Oz
    Vonstripers, great set-up you have there !!
  5. Pierre H
    Pierre H
    from france
    repro Cragar OHV ...
  6. Jakesrocks
    Jakesrocks
    Starter or push start ? If you're going to use a starter, you'll be happier with a Mallory dual point distributor. Unless you're doing extensive internal mods, no more than a 3/4 race cam with adjustable lifters. Have steel valve seats installed, and use stainless steel valves.
  7. gwhite
    gwhite
    SUPER MODERATOR
    Pure banger ****! Love seeing these under-rated engines getting the credit they finally deserve!!
    Here's mine (mocked up - in progress);
    [​IMG] [​IMG]
    bonesy likes this.
  8. colinsmithson
    colinsmithson
    Nice looking engines guys
  9. the vonstripers
    the vonstripers
    from france
    Thanks guys...!
    Onething's missing, the camshaft and adjustables lifters, still the original one, where i will can buy these set up for street racing used...
  10. the vonstripers
    the vonstripers
    from france
    It's a GAZAL buissonnet high compression aluminum head, a special construction from a french motor spe******t who worked for citroen in the 30's, i don't know more about this aftermarket parts builder...
  11. Hitchhiker
    Hitchhiker
    A little more banger ****.
    [​IMG] [​IMG]
  12. Bud Crane
    Bud Crane
    The Stromberg 81 carb is too small for even a stock B motor. I think it will run much better with a 48. The 81 is made for a 136 cu. in. engine, not a 200.5 inch one.
  13. gwhite
    gwhite
    SUPER MODERATOR
    I dunno about that...lots of folks run Winfield "B" and "BB" carbs (which flow somewhere between an 81 and a 97) with larger cams and don't have problems...
  14. colinsmithson
    colinsmithson
    I have used Stromberg 81s on some warm bangers and they work very well
    plenty of flow 125 cfm
  15. leroux
    leroux
    from SoCAl
    Nice work. I have duel 81 stroms and all Thomas race equipment on my hoped up A. And I drive it like I stole it.
  16. jkeesey
    jkeesey
    Ive got a 97 on mine and shes running like a top.
  17. 4-port Riley
    4-port Riley
    the 81 is bigger and better than the stock carb, but if you are going to race, it is not enough. i run three 81's on my cyclone flathead.
  18. the vonstripers
    the vonstripers
    from france
    What do you think about this, i built different molds for the 4 banger, the first is a finned valves cover side for sand casting, the second mold is a dual two's intake manifold in wax for the lost wax shell casting process need finitions but it's sounds good,
    and two small fuel distributors in wax too...
    The furnace is in my backyard, waiting for shell casting stuffs and petrobond sand ( good casting stuffs is hard to find in france)
    Here's the picts
    Jet96, Hotrodmyk and kiwijeff like this.
  19. boo
    boo
    from stuart,fl.
    i have a wormed A in my truck, have a winfield intake manifold w/flathead 6 cyl carb[cant rem. #] 223+- cu in. same bore as win. intake, runs good. 60 over, Crane #302 cam, Snyder head, mdl. B distributer, balenced crank & eng bal., v-8 clutch& pp, 25# off flywheel, B/W overdrive, 4.11 rear. got Safty tubes and and i'm not scaired the brakes are good and the tires are fair
    Hotrodmyk, kiwijeff and Jakesrocks like this.
  21. Jakesrocks
    Jakesrocks
    Oh hell ya. I could look at **** like that all day.
  22. Ole don
    Ole don
    **** like that shouldn't be legal before my second cup of coffee.
  23. Jakesrocks
    Jakesrocks
    Makes me wish I still had my Fargo 4 port from the 50's.
  24. denis4x4
    denis4x4
    from Colorado
  25. denis4x4
    denis4x4
    from Colorado
    This is my other banger, a 1931 with a Crower cam, inserts, counterweight crank and a pair of the the English 97's ImageUploadedByH.A.M.B.1412211706.850562.jpg
    If you don't go first cl***, your heirs will!
  26. manyolcars
    manyolcars
    7:1 Lion Speed head, New, not reground Model B cam, Pertronix, alternator, timing set with a timing light and a degree wheel, twin SU carbs on a stainless header, fully synchronized 3 speed with overdrive, SS valves, adjustable cam followers
