Webber carbs on a SBC
Discussion in 'The Hokey Ass Message Board' started by swimeasy, Nov 17, 2011.
  1. Duntov1967
    Duntov1967
    My newest project. ***y, yes?
  2. paul55
    paul55
    from michigan
    That's pretty cool!
  3. Rocket-Boy
    Rocket-Boy
    ill play, Here is my upcoming project.
    324 olds Latham and x2 40Dcoe's will have to run 45's though
    daddio211 likes this.
  4. tfeverfred
    tfeverfred
    WHAT THA'.........? :eek: More info needed.
  5. Rocket-Boy
    Rocket-Boy
    its a Latham axial flow supercharger 11 stage axial compressor one of approx 600 made. alot were used on FE's back in the day with Carter YH's and a single thin belt to run them, This one when purchased had the tripple v belt setup and the twin 40's.
    i bought this off Evilbay and adapted it to fit the olds.
    To pay the respect it deserves i will run webers and the triple V belt it has already.
    ill post up a couple others.
    And sorry for jacking the thread.
  6. Duntov1967
    Duntov1967
    It's not my brain child as I got the idea from a project Jim Inglese did on a 455 Olds. The tops are IDA four barrel adapters that I profiled to fit an Offy tunnel ram individual runner base. This profile works on all the small block Chevy, Ford & Mopar bases along with the 455 Olds base. The adapters are also individual runners so this setup should have great performance along with good low end torque with the long runners. I made the custom oil filler tube using a Moon mini tank cap and bung.
  7. Cragar
    Cragar
    I love Webbers here is my 44s on my Windsor ImageUploadedByH.A.M.B.1407900401.594800.jpg
  8. Duntov1967
    Duntov1967
    Would like more details about the EFI conversion!
  9. Deuce-Deano
    Deuce-Deano
    from Gilroy Ca.
    Manifold by Hogan Racing fabricated for the Boss 302
    EFI system by Eightstack. " www.eightstack.com "
    Domed air cleaners by Cook Enterprises
  10. banjeaux bob
    banjeaux bob
    from alaska
    Mickey T unnamed (1).jpg hompson all aluminum 283 W/Weber carbies.
    rod1, volvobrynk and daddio211 like this.
  11. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Spotted on a SBF yesterday in Carmel, CA:
  12. Deuce-Deano
    Deuce-Deano
    from Gilroy Ca.
  13. HRBOB34
    HRBOB34
  14. Deuce-Deano
    Deuce-Deano
    from Gilroy Ca.
  15. paul55
    paul55
    from michigan
    now that's purty!
  16. Duntov1967
    Duntov1967
    Jim I. sent me these progress shots of the SBC Offy IDA Triple he is doing for me. He managed to work out the progressive linkage. It will cruise on the center carb and then the two outboard carbs will kick in. I'm stoked.
    gnichols likes this.
  17. rfraze
    rfraze
    My experience with them is that they are like fuel injection with a float bowl. I strongly believe that they are designed to be used on individual runners, resulting in tunability. **** Willets had a set of IDAs on SBC powered A and kept searching for the source of gas smell in garage. Finally came to believe that smell was coming from float bowl vents. Not good in a garage with water heater, etc. Anybody got experience, input, or a fix for that issue? Don't believe I had it with my Dellortos, which would, as a side note, mellow out most any cam.
  18. loudbang
    This is AWESOME never saw one like it before :eek:
  19. waydel
    waydel
    from Arizona
    Check out carbs unlimited they have what looks to be complete setup for sbc cost is 2445.00
  20. waydel
    waydel
    from Arizona
  21. waydel
    waydel
    from Arizona
    eBay has them 286.00 last I checked
  22. gnichols
    gnichols
    from Tampa, FL
    Unless you are a stickler for Webers, Mikuni makes a carb that is pretty much a clone of the DCOE Weber.
  23. Nakada1932
    Nakada1932
    Do u still have
  24. willymakeit
    willymakeit
    I may have inherited a Delloreto set complete with manifold and carbs for small block Chevy.
    If so im going to buy a Ford manifold for my small block.
