Hey Guys, I picked up a sweet '30 Model A coupe that has been chopped.It was done really well, but it does not have any quarter or back gl***. What do I need to install them? This is the first coupe I have owned. I have the quarter window garnishes, I believe they are called, but they are stock and not chopped and that's it for parts. If someone can point me in the right direction for parts and installation procedure I would appreciate it. (I have a good gl*** shop to cut the gl*** for me too when its time.) Thanks again!
Well you already know you need to cut down the garnishes and youll need the rubber kit. Other than that you need nails and screws. Oh and wood to nail and screw too of course.
does it have the wood frames installed ?if so make some cardboard templates and transfer that to wood about a quarter inch thickabout the same as the gl*** thickness , test fit it and take it to youre local gl*** shop for cutting , installation is fairly easy , its held with tiny nails and your mouldings and some gasket material
Thanks guys! I don't have any wood on there now. Does someone make it pre-fabbed or do I need to make it and if so what size wood? Also does it just use silicone to install? Or actual rubber gaskets? Posted using the Full Custom H.A.M.B. App!
You should be able to buy a wood kit from Macs, CW Moss or Snyders but in OZ we replace the wood with square steel tube to stiffen it all up Good luck with your project
