Projects Lifting body off the frame. Do I need to re-enforce body?
Discussion in 'Traditional Hot Rods' started by BEAR51, Sep 25, 2014.
  1. BEAR51
    BEAR51
    from Chicago
    I have a 51 Mercury and am doing a frame off. But, some people tell me that I need to re-enforce the body with cross bracing so the body won't twist and others say theres no need to brace. Not using a rotisserie will be using a gantry crane to lift body and putting on horse to clean under carriage. Can anyone tell me the proper way to do it?
    Thanks
  2. roundvalley
    roundvalley
    I would play safe and cross brace.
  3. Unkl Ian
    Unkl Ian
    Are the floor and rockers, sound, or rotted to **** ?
  4. fms427
    fms427
    If the body is solid-no rust in floors ,rockers,etc-then it is safe to remove without bracing. If structure is compromised, then you better brace-or fix body structure before removing body from frame.
  5. The G00SE
    The G00SE
    Im with roundvalley brace it .. better safe than sorry
  6. Unkl Ian
    Unkl Ian
    Exactly correct.
  7. 57JoeFoMoPar
    57JoeFoMoPar
    For the little cost in both money and time to brace it, why take the chance?
  8. Hnstray
    Hnstray
    from Quincy, IL
    When the bodies were manufactured and ***embled to the ch***is they did not need, nor have, supplemental bracing. As others have said, if the body is solid, not rusted in any structural area, and the doors are on it, it does not need additional bracing. If the body is weakened from rot, follow the advice in post #4.
    Ray
    bobg1951chevy likes this.
  9. Ronald Bowman
    Ronald Bowman
  10. BEAR51
    BEAR51
    from Chicago
    I appreciate all the feedback. The body is 100% rust free and very solid.
  11. The 39 guy
    The 39 guy
    I would use a speader beam to pick the body. In other words pick the body up from four points with the slings ,chains or ropes in a vertical position so you do not squeeze the body.I just did this this week with my 40 ford coupe. I will try to remember to post a picture tomorrow.
  12. JEM
    JEM
    If it's a convertible or a rustbucket brace it. If it's a solid closed roof car then crossbracing is not needed but as others have noted pay attention to where you pick it up from and how the load's applied.
  13. mgtstumpy
    mgtstumpy
    If a good solid body no, if there are rusty sills and floor etc, yes. If like this 42 Chevy PU I'm doing, Yes. A bit overkill but you know what I mean.
  14. J'st Wandering
    J'st Wandering
    I have worked on a '50 Merc. I pulled it off the frame with no bracing. The bodies are well made, reminded me of a tank.
    Neal
    BEAR51 likes this.
  15. 19Fordy
    19Fordy
    NO NEED TO BRACE if it's structurally sound.
    Keep the doors closed and tack weld short strip of steel on inside of car between
    B-pillar and door to hold doors in place.
    Then lift off the body.
    BEAR51 likes this.
