Technical Removing hub from Buick drum
Discussion in 'The Hokey Ass Message Board' started by 550Coupe, Sep 26, 2014.
  1. 550Coupe
    550Coupe
    Can some one tell me the proper way to remove the hubs from my Buick finned drums without damaging them? I have drilled out the rivets but they won't budge. I believe the drums are press fit onto the hubs, so will I need to have a machine shop do this or is there some way I can do this myself? Thanks for the help,
    Art
  2. Tuck
    Tuck
    Tech Editor
    from MINNESOTA
    I've always just knocked them out with a BFH. Usually one good hit and they fall right out- you can put a slab of something on top to help even the force distributed from the blow of the hammer-
    Tuck
  3. Mr48chev
    Have you knocked or pressed the studs out? The drums are a tight fit on the hubs but I think that the corrosion between the dissimilar metals may be causing most of your problem.
  4. 550Coupe
    550Coupe
    No I have not removed the studs, just the rivets. So I need to remove the studs also?
  5. tommy
    tommy
    Did you press out the studs? ( back up the flange so you don't bend the drum)
  6. 550Coupe
    550Coupe
    Thanks for the info Guys!
  7. 550Coupe
    550Coupe
    OK, got the drums off. Now one more question. I have 53' F 100 brakes on the car now. Can I use these hubs with the Buick drums or will I need the car hubs? Thanks again,
    Art
  8. 29AVEE8
    29AVEE8
    Doesn't the F-100 use an 11 inch drum/backing plate? Think those Buicks are 12 inch.
  9. Wooster
    Wooster
    from Soso, MS
    Do a search here on the HAMB and also Google it. You will find all the different ways to mix and match Buick drums to other hubs and backing plates and such.
  10. 550Coupe
    550Coupe
    I only want to use the hubs. I have Wilson Welding Lincoln brakes to go with the Buick drums. Just want to know if I can use these hubs or need to get something else.
  11. Mr48chev
    I've never heard of using the 60 something Buick hubs on any non full size Buick. Can you clarify exactly what what you are attempting to do and what spindle you are using?
    We use the Buick finned drums on Ford hubs after redrilling the bolt pattern and I believe that the Wilson Welding Lincoln brake setup is designed to use 40 Ford style hubs.
    550Coupe likes this.
  12. gimpyshotrods
    gimpyshotrods
    I have 45-fin Buick drums, on original Buick hubs (post ball bearing), on my early roundback spindles.
