Projects The Hardscrabble Hop-Up; A 1940's Style 'T' RPU build
Discussion in 'Traditional Hot Rods' started by gwhite, Jul 21, 2013.
  1. Great work on the dash! I just went back through the whole thread again and I must say this is a really cool build. So glad you're sharing it with us. We all know life takes precedence over our hobbies at times but hang in there, it'll all come together.
    Blessings,
    David
    gwhite likes this.
  2. Squablow
    Squablow
    Dash looks great, I'd dump my T dash for that setup in a heartbeat. And I bet you could sell the top strip you cut off to someone putting something custom into a '32. Maybe someone would want to weld the T bottom onto the 32 top!
    gwhite likes this.
  3. dwest999
    dwest999
    from Saline, MI
    Gman... looks great and glad I found this build thread... Funny the dash was just sitting in my garage for over a year waiting for you to find it... must have been devine intervention!
    gwhite likes this.
  4. Runnin shine
    Runnin shine
    I love seeing these "throwaway" 32 dashes being repurposed into something beautiful and GW, yours is one magnificent piece.
    "Listen Mr... It ain't broke if I can't fix it"
    gwhite and sko_ford like this.
  5. Chris
    Chris
    Wow, I have not seen this thread! Nice job!
  6. kidcampbell71
    kidcampbell71
    Baddddd *** ! Yeah, you better not delete this thread. It's in real time, and yet a year old. What the hell is wrong with that? Nuttn' !! Keep up the good work.
  7. gwhite
    gwhite
    SUPER MODERATOR
    Thanks guys, your encouragement means a lot!
    Still waiting on some ch***is parts (some in transit, others I need to make a day trip or two to pick up) - once those are in-hand, I'll get the suspension installed and fab up my body mounts. Then it will all get blown apart, blasted, refurbished, and painted. Until then, I'm busying myself with little projects - restoring/refinishing my '37 banjo steering wheel, finalizing instrumentation, and building a proper seat pan. This is going to take forever, but I'm really enjoying the journey!
    My OCD over the dash has continued...I managed to dig out a grubby '32 Speedo and scored a 2 3/8" back-mount SW ammeter (date coded April 1944).
    The ammeter is NOS - no signs of use/mounting and the face & gl*** are perfect! As with most wartime SW offerings, the bezel was painted black, but years of 'shelf wear' reduced it to a scuffed and chipped up mess. After careful dis***embly the paint was stripped, revealing a VERY thin nickel plating over br***. Not crazy about the color difference between it and the chrome speedo bezel, but I can live with it.
    Now I gotta find a matching temp gauge!
    general gow and kidcampbell71 like this.
  8. Speedy Canuck
    Speedy Canuck
    Looking good!
    I think the colour difference helps with your era of build. Exactly what somebody would have done after the war ended... gotten a surplus gauge and stripped off the black paint.
  9. Hitchhiker
    Hitchhiker
    I'm running two miss matched gauges in my truck. I did it on purpose. Like one was added as an after thought and they couldn't find a match.
    Looks good to me! really excited to see this one come together, as I know you have done your homework.
  10. Runnin shine
    Runnin shine
    You guys are so on with the gauges. I did mine similarly. I wanted them them to look like they had to be worked on and changed. But to still be old with not to much thought and be believable.
  11. gwhite
    gwhite
    SUPER MODERATOR
    Spent some time this evening with some graph paper and some old fashioned drafting gear making a template for the instrument support panel (I'm not using a '32 dash tunnel). A s**** of plywood and a hole saw gives the gist of it;
  12. gwhite
    gwhite
    SUPER MODERATOR
    Found an SW temp gauge! Postman should be delivering it toward the end of the week!! Funny thing is that it's an EXACT match to the ammeter - same black bezel, br*** case, and funky mounting bracket. Even has the same "20 22" inspectors stamps - unfortunately the date code is illegible, so I'm ***uming it was probably manufactured at approximately the same time. Supposedly it's NOS and functions perfectly. Only downside is that the capillary tube is ridiculously long. Oh well - guess that just gives more flexibility to route it cleanly and place the probe exactly where I want it.
    In the mean time, I hacked up a mid-1930 to 31 instrument panel to make a bracket for my '22 Cadillac fuel pump.
    It'll go in the middle of the dash like this;
    volvobrynk likes this.
  13. gwhite
    gwhite
    SUPER MODERATOR
  14. gwhite
    gwhite
    SUPER MODERATOR
    And here's the final mockup; time to tear it apart, do a little finish work on the metal, weld 'er up, and engine turn some aluminum for the gauge panel. The matching 2 3/8 temp gauge should be arriving mañana (it'll go to the right of the speedo).
  15. Looks fantastic. I can't wait to see it with the aluminum!
  16. tb33anda3rd
    tb33anda3rd
    the wheel choice, gauges and shape of the dash, all go together nicely. the way it should be.
  17. gwhite
    gwhite
    SUPER MODERATOR
    Thanks guys! The postman dropped off the last remaining bits to complete the instrument panel; a nice, freshly serviced '32 SW speedo and a SW temp gauge (matches the ammeter perfectly)!
  18. gwhite
    gwhite
    SUPER MODERATOR
    Heard from Ross (my engine builder) the other day...there's an issue with the crank, so it'll be a little while longer before she's ready. No biggie, still a lot of little stuff to mess with.
    My attention is now being turned toward getting the ch***is set up and ready to receive the motor. Need to ***emble the front end (33-6 axle, 33-34 perch pins, 33-34 spindles/backing plates/brakes, A tie rod/drag link/wishbone), install the T rear spring and slide the rear axle ***embly in place. Once that's done, I'll get the motor/trans in, finalize body position, modify the pedals, and fab up body mounts. Then it all gets blown back apart, blasted, detailed, and painted.
    Already getting started on some small parts - these Model A shocks were mechanically refurbished by Robert Paul - but were dinged up and full of pits and left a lot to be desired cosmetically. Sounds crazy, but I've got about 30 hours in filling, blocking, painting, and hand-polishing the set - a good deal of that time was occupied trying to match Ford's 'dipped' enamel paint (shown here against a NOS motor mount for comparison). I think I'm pretty close, and that formula will come in handy when it's time to paint some of the other ch***is components. You'd be surprised at the amount of variation in "black" paint!
  19. 3wLarry
    3wLarry
    from Owasso, Ok
    dude...you are seriously **** about the details...therapy time
    kidcampbell71, Outback and MrModelT like this.
  20. gwhite
    gwhite
    SUPER MODERATOR
    Hahaha if you think this is bad, wait 'til I get started on the frame :). Asphaltum- based paint...yum!
    Sweating the details is my therapy!
  21. dwest999
    dwest999
    from Saline, MI
    Saw the build live this past w/e... thanks for having me over Gary... The RPU looks even better live. As several here have mentioned before, Gary's attention to detail impressive.
    gwhite likes this.
  22. gwhite
    gwhite
    SUPER MODERATOR
    Thanks neighbor! I was a little afraid you were going to be pissed when I told you I chopped up the '32 dash, hahaha. Glad you were able to see the method to my madness; you're welcome back anytime, really enjoyed the conversation and checking out your MoPar - that's one sweet little car!!
  23. kidcampbell71
    kidcampbell71
    Wow....that looks great!! Asphaltum based paint I'll have to look up. I do know what *** fault....ummm, is though. Had a few of those work on my stuff, maybe even me.
  24. Angry Frenchman
    Angry Frenchman
    wow man, great thread!
  25. gwhite
    gwhite
    SUPER MODERATOR
    Thanks man...I want to see more of your T! The few pics I saw from TROG coverage were impressive...you freaking nailed it!
    Hahaha. Asphalt-based paint was known in the early 20th century for its quick-drying characteristics...Ford used Gilsonite, a mineralized form of bitumen (asphalt) in their varnishes during production of the Model T (used extensively on car bodies), then on the A frame. When pulverized and dissolved with naphtha, suspended in linseed oil, and modified with 'japan' driers; Gilsonite makes a fine varnish (also known as "japan paint"). When wet it looks like extremely dirty used motor oil and dries a deep brown-black with a decent gloss (depending on the smoothness of the substrate). I've done some experimenting and have (what I believe) is a pretty good match to Ford's recipe.
    Main goal is to replicate - as best I can - a fairly stock A ch***is with a few hot rod improvements.
  26. loudbang
    Awesome and this is the very first time on ANY board that somebody used the word substrate and in the correct way. Our total intelligence level just moved upward several points. :rolleyes:
    volvobrynk, gwhite and kidcampbell71 like this.
  27. kidcampbell71
    kidcampbell71
    Wow man. I hope you nail that recipe. Of course it will look cool, but those original frames had their share of good looking years......before the rust and crust obviously. Should hold up, nice. So cool.
    gwhite likes this.
  28. Squablow
    Squablow
    Damn, and I was worried about hose clamps, this takes it to a whole new level. 30 hours! You have the good kind of insanity.
    Outback and gwhite like this.
  29. Jungle Jalopy
    Jungle Jalopy
    Asphalt based paint. You are a FREAK. I love it!
  30. Hitchhiker
    Hitchhiker
    I fear that if you and I ever get within close proximity of each other that the universe may implode.
    gwhite likes this.
