Guys, I just bought me a decent Cadillac 2 door Hardtop. It's a driver as is but I could use some parts quickly. I've fiddled before with easier cars (parts wise) and from what I can tell some parts are really hard to get.. or maybe I'm looking in the wrong places. Anyway, I could use some advice in where I can source the sought after parts. I also struggle with the correct denomination so Googling is a challenge Looking for the vent window "pillar". The chrome part of the pillar is broken just an inch above where it goes into the door. Is it repairable at all? Can I use a 4 door pillar? someone mentioned that the 4 doors are taller? Also trying to find an un-molested window "flip-up" molding for the p***enger side. Finally the rear fender, right hand piece where the exhaust exits. Mines all rusted.. Any input is highly appreciated! Thanks/ Speedy
It can be IF you can find someone that can weld pot metal...that's what it is made of and not the easiest to repair. Finding those are becoming a challenge as most of them break from improper adjustment. 1954/'55/'56 Cadillac two door hardtop pillars are all the same. Buick Roadmaster two door hardtops of the same years are Cadillac parts. NO, the four door pillar is entirely different...GM did not make a four door hardtop in 1954. Those might be the easiest to find...ANY '54/'55'56 flip up molding will be the same and Buick will work. Typical Cadillac...they all rusted out there and they are hard to find items and very expensive IF you can find them (and those that have them KNOW what they fit...!!!). 1954 and '55 Cadillac are the same... I do have some '54/'55 Cadillac parts IF you should need other things...PM me if you have a list... Hope that helps... R-
Just picked up a copy of hemmings motor news october and there is a whole page dedicated to cadillac parts and vendors Posted using the Full Custom H.A.M.B. App!
Ok, thanks guys!! Much appreciated I think the pillar is most urgent so I need to go fishing. Anyone got one lying around? I'm thinking of dropping it moderately in the rear and I trust there are no kits around.. Can one survive a 2 or 3" drop using some sort of universal parts? Thanks/ Speedy
I used 3" lowering blocks in the rear of my '55 (avatar) and have plenty of travel-no drive-shaft rubbing at all...3" is not extreme...just make sure you get longer U-bolts to hold it in...available at most speed shops and on-line... R-
I'm about to swap my alloys (which look like **** anyway) for some steel wheels and wide whites. Got a counter question from the tyre shop if I have 5x5 or 5x5,5!? I'm convinced that it's 5x5 but I thought I'd run the ***umption through u guys. Am I right? I'm not overdoing the wheel thing. Just want the car to look right with enough 15 inch rubber to fill the wheel wells reasonably. Thinking of 7" rims but I'm not sure about backspacing. I'm running skirts. Any advice? I'm shipping from the US so whatever I can do to ***ure fitment is welcome. Again - thanks in advance! Cheers/ Speedy
I might have an extra vent window pillar. What side do you need? Keep checking ebay for the door flipper, they pop up on there every now and then. The bumper end rot on all these cars. Very expensive if you can find a nice replacement. It may be cheaper if you have the skills to rebuild the one you have and rechrome it. PM me about the window pillar. I have a bunch of other 54 parts if needed.
7" wide wheels really didn't become available until the late 60's, and there are few WWW tires available to fit that width, plus you may run into rubbing issues if you run fender skirts, especially lowered. Consider a 5.5" or 6" wide wheel and maybe a 7.10-15" tire. Too small of a tire diameter might look odd on such a big car.
Ok Tyre shop suggests 6 inch with a 235-70 o 75 profile and it sounds about right. What about the PCD? I'm getting gremlins in my head about the 5x5 or 5x5,5 question... Thanks/ Jonas
I think the tire shop is asking you what bolt circle you have is it 5x5 or 5x51/2? Are you buying new wheels? If so your bolt circle is 5x5. Now go put those Gremlins to bed!
Eaton has a hot rod line of springs. A bit more expensive than lowering blocks, but they are made to original GM specs, and work well. Look on their web site for add'l info
Here is a long list of Cad Parts Suppliers http://www.jalopyjournal.com/forum/threads/finding-cadillac-parts.298882/
Thanks guys! I'll look in to it looong winter coming in Sweden so plenty of time for improvements! Cheers/ J
Agree.. Wheels are in the works but I dunno 'bout paint yet.. Flat black ****s and I can dig the rockabilly style but not on a car like this. It's two-tone green originally and the interior is still in good shape (green). Thinking on off-white or perhaps a white pearl. Maybe this type of car should have a pastel color It's completely rust free so painting it would be a moderate challenge - not much work apart from stripping the car. the rest is on the painter. I guess it's just a question of "pay up ****er" Cheers/ J
Yep, wheels/tires are easy...paint and body not so much...my '55 was two tone green as well...most the Caddys I've seen were that color as well...including my brother's '54...here's a pic of his: As you can see we did some mods to the scoop and added another piece of chrome to the rear quarter...oh, and changed the grille...stock 331"/Hydramatic that gets 20-21 mpg on the highway at 70 mph ... We just finished this trip a few weeks ago:http://www.jalopyjournal.com/forum/threads/the-cadillac-of-travelogues-canada-road-trip.943262/ R-
If I was that lucky.. Previous owner shot this paintjob and went a tad too thick so I've got a funky orange peel feeling going on the car. I could go Black and that would require less of an effort compared to switching color. However, I don't think black is doing the car justice. BTW: your brothers ride sure is sweet!! /J
