'32 3 Window Seats
Discussion in 'Traditional Hot Rods' started by TJ2, Sep 28, 2014.
  1. TJ2
    TJ2
    from Bel Air,Md
    ImageUploadedByH.A.M.B.1411956790.286324.jpg ImageUploadedByH.A.M.B.1411956819.668885.jpg ImageUploadedByH.A.M.B.1411956871.122320.jpg ImageUploadedByH.A.M.B.1411956933.061718.jpg
    Next week the body is going back on the frame and I'm fabbing in the steering & peddles. Going to the junk yard looking for a couple buckets.
    Any suggestions on what seats would work well and look good?
  2. Vics32
    Vics32
    TJ2, I just bought that same body (N&N)......got a Chrysler something middle van seat with it, looks like it will fit nicely.......will probably end up with buckets like Honda Civics or some about that size, had those in my last '32 5-W and they worked well. VICS32
  3. 383deuce
    383deuce
    I built my own with a pattern from an original 3 window seat. Like the bench much better as it gives you more room in a 3 window than buckets......I still have the pattern if interested and it was eazy and cheep to build.
    rexrogers likes this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Like Dennis suggested build your own,it's not too hard. HRP
    LOU WELLS and rexrogers like this.
  5. deathrowdave
    deathrowdave
    from NKy
    I have 2 frames , 1 OEM NOS springs , other dual density foam shaped to OEM shape . No sliders . Not sure which one I’m going to use . You will notice the 3 W body tapers to the front , a van seat may fit and work good enough but it’s not the best fit .
  6. So-cal Tex
    So-cal Tex
    I have a model A coupe seat in mine which is almost identical to the 5W coupe seat and fits great....
    deathrowdave and Just Gary like this.
