Well I bought this motor as a 327, but after reading crank number it turns out to be a 283 instead-I **** again. But I was able to see the piston walls were fresh as are the valves-so that's a good thing. So I say screw it, I'm using it anyway! Thought I would post a picture of it before the engine swap happens next week-when the REAL work begins!
I would check the block casting number on the back of the block, as well as the ID number on the tab, right side. some people would install a 283 crank into a 327, back in the day.
That engine ****S! You will NOT like it! Just put it in a wood box, ship it to NC to get it as far away from Cali as possible, and I'll be sure it gets a proper resting place!
I knew the valves needed to be adjusted, so today I removed the intake to see if the lifters were solid or hydraulic. They look solid to me-am I correct? I could also see through the spark plug holes the pistons were more of a dome top, and had 0.30 on all of them. This little motor gets funnier all the time!
