anyone remember the 4.3 buildup in car craft afew years ago??
Discussion in 'The Hokey Ass Message Board' started by freightdriver, Jan 17, 2006.
  1. freightdriver
    freightdriver
    i guess i should start off by introducing myself i'm 19 and from ca i've got a 71 challenger and hopefully here soon i'll be starting on a more traditional hot rod pretty much set on a fibergl*** t body with a 20in bed and pretty much set up like midwest kustoms sinister tee. it'll be powered by either a straight 292 or 4.3 with the 4.3 being dressed up to look alot more ol skool then it is and backed up by either a 5 or 4 speed manual..
    Well anyways i remember seeing a car craft article afew years ago where they built up a 4.3 pretty decently and then later ended up supercharging it... has anyone seen this article or have a copy of it?
    Thanks in advance Josh
  2. 31Apickup
    31Apickup
    Hot Rod magazine had an article several years ago about building a 4.3, don't recall what issue.
  3. Roothawg
    Roothawg
    Welcome, there are magazine junkies all over the board. I'd bet money someone has it.
  4. REJ
    REJ
    from FLA
    Be like the rest of us SIX freaks, put the straight 292 in there with 2 or 3 carb manifold and headers.
  5. snapper
    snapper
    from PNW
  6. bwiencek
    bwiencek
    Built a 4.3 for a friend's boat that used similar tricks to the one in the HotRod article - flat tops from a 350, performer intake, 600 CFM 4bbl, mild cam, undercut stainless valves - never dynoed it but it sure ran great and suprised the heck out of me - it was able to out holeshot stock 350 V8 powered boats due to less weight and a flatter (non-v) hull sitting up out of the water and it even keept up pretty good on the top end so I knew it was healthy! ~I had guessed 260-280 HP, but their dynoed ~300 hp sounds about right...
  7. jalopy43
    jalopy43
    They didn't make cars in '43'cause of the war:eek:sheesh,Sparky
  8. 34Fordtk
    34Fordtk
  9. brandon
    brandon
    was that the one that ended up in a late 70's early 80's malibu ? brandon
  10. bcarlson
    bcarlson
    I'd like to see a copy of that one too.
    Thanks,
    Ben
  11. flynj1
    flynj1
    from C.B. IOWA
    One of the guys I race dirt track with had a 4.3. His had 229 heads with 202 valves in it and sbc pistions. That thing would screem. It ran right with the 400+ hp sbc I was runing at the time. Allso I run a 85 4.3 in my 34 chevy tub. I cought alot of **** for putting it in the car but I like it. Its got alot of balls for that lil car and gets great milage as well. Im planing a new roadster project now and there is allready a 4.3 in my garage to put in it.
