Drove a 32 Roadster Today
Discussion in 'The Hokey Ass Message Board' started by agshelby, Oct 4, 2014.
  1. Honestly, this is the most exciting moment in my recent memory. I had a bit of trouble with the downshifts down to first ( need some tips on a '40 Ford transmission) , but it was great once I was rolling. The car is a great driver and I put about 50 miles on it before locking it back up.
    I am running'32 plates on it in Texas and they don't arrive til Tuesday - so didn't venture far due to no plates. ImageUploadedByH.A.M.B.1412462462.708775.jpg
  2. HOTRODPRIMER
    HOTRODPRIMER
    Looks great,I know the feeling of that first drive..Congratulations! HRP
    lothiandon1940 likes this.
  3. harleycontracter
    harleycontracter
  4. harpo1313
    harpo1313
    from wareham,ma
    Very nice.Any side shots with the top up?
  5. brady1929
    brady1929
    Great hot rod
  6. Texas Webb
    Texas Webb
    Wow you done great!
  7. 26 T Ford RPU
    26 T Ford RPU
    Very nice Roadster, way Cool !!! JW
  8. 26hotrod
    26hotrod
    from landis n c
    Thanks for sharing. This will be a day you will long remember and will encourage you to over come any future problems so you can enjoy some more good rides..............................
  9. kidcampbell71
    kidcampbell71
  10. Dale Fairfax
    Dale Fairfax
    Pure and simple: If you don't know how to double clutch, you DON'T downshift a 3 speed into 1st gear.
    Mpls 40 likes this.
  11. Merlin
    Merlin
    from Inman, SC
    Cool roadster, Congrats!
  12. retromotors
    retromotors
    Yeah, what Dale said.
    Transmissions with synchro low gear are a relatively modern invention.
    Unless you've been driving semi tractor trailers, you've got a bit of a learning curve ahead of you.;)
  13. I have been taught the method of 'double clutch' - but don't have the feel down 100%. For now I am avoiding down shifting at all into first and working on my technique as I shift into first from idle at lower rpms. I can do it - it just isn't at at point where it is a natural movement, yet.
  14. Nice car. You did good..................
  15. roundvalley
    roundvalley
  16. when down shifting try going to second with foot off gas before going to first
    500 miles behind the wheel - Loving the Central Texas weather. Ran into a couple of nice 3 windows here in San Antonio - and a nice OT Impala.
    Getting ready to make a few minor changes to make it my own - lowering (or replacing) the seat, and adjusting the headlight position due to tire rubbing at lock. I have a set of smaller guide headlights that I am going to fit and see how they change the look.
    kidcampbell71 and loudbang like this.
  18. Pewsplace
    Pewsplace
    Nice ride. Congratulations!
  19. Have been busy driving the car - have about 1200 miles on it so far. I swapped out the clutch for a '50 Merc unit (much less pedal effort), removed the rear bumper, changed the headlights & exhaust, went to bias tires ... just about "done" for now. The only remaining items are the interior, some pin striping, and then I am going to lower the rear by reversing the spring eyes.
    kidcampbell71 and Rich B. like this.
  20. It's been rain pretty much every week - so driving has been stalled. Can't complain about the rain in central Texas -
    So doing some minor tweaks:
    I fitted some hood tie down straps and did a little painting of the toe boards and transmission cover. Polished the headers, fixed an oil leak, cleaned little parts .... I need some sunshine. ImageUploadedByH.A.M.B.1434821783.443745.jpg
    kidcampbell71 and lothiandon1940 like this.
  21. lothiandon1940
    lothiandon1940
    Nice Roadster. Have fun.
    kidcampbell71 likes this.
  22. Picked up some parts for a longer term engine project. I've already heard that I'm crazy for going backwards in technology - save your time and just ignore if you don't agree. I think it's a great fit for this car.
  23. alchemy
    alchemy
    I DO AGREE! I love flatheads. Hopefully you will too after the conversion.
  24. Yep, we vote FLATHEAD too.
    We have five - three that run and two more builders.
  25. Deuce Daddy Don
    Deuce Daddy Don
  26. reefer
    reefer
    You'll think you've left the handbrake on and that there is a hole in your gas tank...lol.
    belair and kidcampbell71 like this.
  27. oj
    oj
    Flatties are the ***s, go for it!
  28. timwhit
    timwhit
    Did you just buy the car? I like most of the "improvements". The forty trans will be much friendlier if you come to a stop before trying to put it in first gear. You can do it rolling at low speed. Yep, most newer stuff (mid sixties) had syncrho's. Tim
  29. Tim, remember when you shift up through the gears (1-2-3) you naturally allow the engine RPM to drop a few hundred RPM to engage the next gear; the exact opposite is true as come down (3-2-1) through the gears, you increase the engine RPM to engage the next lower gear. Since your trans has no synchros for first gear you will have to keep your left foot OFF the clutch pedal and moderately increase RPM and gently pull the lever back toward 1st gear until you FEEL the gears gently "tick tick tick" together. The RPM you go up to to move the car at 5 or 10 mph is the same RPM you will need to engage the trans as you come down...it's definitely a FINESSE move, no "blipping, jazzing or punching" that throttle. I spent 40 years in a Peterbilt ready mix truck with a Roadranger trans in L.A. traffic; the only time you need the clutch is at a full stop. Patience, you'll get it. By the way that's a REALLY NICE RIDE!
