Projects 1955 Pontiac gasser build
Discussion in 'The Hokey Ass Message Board' started by 55chieftain, Aug 10, 2010.
  1. 55chieftain
    55chieftain
    Only 12.4 in the 1/4. Should go mid 11's once the carb gets redone and converter straightened out.
    Thanks for all the nice words everyone, cars a blast to drive can't wait till I get the tune in and really make some good runs.
  2. swade41
    swade41
    from Buffalo,NY
    Any updates on this one ?
  3. el Scotto
    el Scotto
    from Tracy, CA
    Just caught this thread! Rad****!!! Love the car!
  4. 55chieftain
    55chieftain
    Thanks for checking back in . I had to take the engine back apart for a head gasket that blew . Also found some bearing wear upon inspection . So now adding main studs and getting the align bore done for crank and cam . Also did some more porting on the heads , should pick up 10 cfm's. I would have liked to do a few other things but just for now just get it back together .
    With another carb it did get down to low 12's and with
    A looser converter will be in the 11's easily.
    I also pick up some old round spoke Et wheels for the front.
  5. RamJet1
    RamJet1
    Very cool, nice work. Looking forward to hearing your new times after the rebuild and higher stall converter.
    What color/colors are you thinking of?
  6. 55chieftain
    55chieftain
    I might leave the roof the off white and either orange, gold or a light mettalic blue for the rest of the car . Or might bring the off white down to the trim line.
  7. swade41
    swade41
    from Buffalo,NY
    Good to see it didn't fall by the way side.
  8. moval57wagon
    moval57wagon
    from So Cal
    I love that g***er. I have the perfect tow car / support vehicle for it...My wifes 55 wagon.
    Keep up the good work. Hope you post some videos of it at the strip.
  9. 55chieftain
    55chieftain
    I have a few updates and a few pics with the "new" front wheels (ET II) , got the engine back together over the winter and up and running again. A little bigger cam & torque converter. Getting the 60 ft's down to 1.66 and working out the tune for the new combo. I went to the local track for the nostalgic race and got invited to run with the Nostalgia G***ers group. Looking forward to running with those guys more once I get a few more things done and straightened out. http://www.nostalgiag***ers.com/
    http://www.danricksphotos.com/Other...0177_bjXgph#!i=3272533800&k=svDGRHp&lb=1&s=X2
    benchseat4speed likes this.
  10. OahuEli
    OahuEli
    from Hawaii
    Your car looks good man. What E.T.s do you expect?
  11. loudbang
    Awesome wrinkle wall photo at that link that is a keeper.
  12. 55chieftain
    55chieftain
    Looking to get to lower 11's, maybe just mid 11's with my weight. At least with these heads, a nice set of alum dports would/should get me in the 10's.
  13. 55chieftain
    55chieftain
    Thanks, only problem is the front tires are still touching the ground LOL.
  14. 55chieftain
    55chieftain
    Speaking of front tires , I picked up some cheap radials for now so I could use these wheels. I didn't like the sidewall so with some sanding removed all the lettering and smoothed them out.
    Also another change I made on the engine, Pontiac's like to run a little hotter towards the back of the block and can get air pockets and overheat like I had some issues when I first put it together last year, also i'm not running a heater core to help with any flow out the back. I added in some fittings and routed it to the front water crossover to help equilize the cooling system out.
    benchseat4speed and loudbang like this.
  15. mjlangley
    mjlangley
    from SE MI
    Great build, your car looks like a blast!
  16. loudbang
  17. Such a cool car!
  18. 55chieftain
    55chieftain
    Thanks for the comments, ended up running a best for now 7.50 in the 1/8 which is a 11.70 1/4 mile. I have 1 more race left before i'm done for the year.
    I had a couple renditions done for my car in the photoshop thread i'm considering , thanks to themoose.
  19. 56PonchoWagon
    56PonchoWagon
    from El Paso TX
    Definitely liking that top color scheme
  20. bobwop
    bobwop
    from Arley, AL
    I prefer the lower color scheme. One color suits a two door post in my opinion
  21. cgaswillys
    cgaswillys
    from New Jersey
    Top one looks better. White with a red flake roof would look cool.
  22. 55chieftain
    55chieftain
    With the way my body work is I may have to opt for the lighter color. It's not a show car by any means.
  23. mad mikey
    mad mikey
    Love the car in any color! Very cool , and that name would be a great fit. Mikey.
  24. carpok
    carpok
    from Indy
    Hi Bill just ran across your build. You've done a great job on the car I can really appreciate your sticking to your convictions.
    Everything about the car is just right hope to see you next year. Ron
  25. loudbang
    One more for the bottom choice all red one.
  26. Rusty Heaps
    Rusty Heaps
    I vote for the red also. The only criticism I have is that I would have tubbed it instead of cutting quarter panels. I have wanted to go that route on my '55 Chieftain.
  27. deto
    deto
  28. 55chieftain
    55chieftain
    G***er and tubbed rear end don't go together. I'm not building a street rod...probably would look ok though for that
    bobwop likes this.
  29. How about red/cream/red?
  30. 55chieftain
    55chieftain
    Still undecided, might just leave the roof white and lower candy apple red or whatever. Right now just looking forward to doing some more racing this weekend.
