Features *Lets see those detailed traditional engines!!
Discussion in 'Traditional Hot Rods' started by Bondoboy, Mar 23, 2008.
  1. Paul
    Paul
    Editor
    I would sell the Studebaker parts to somebody building a Studebaker.
    you can save a couple bucks if you aren't in a hurry by waiting for some nice Isky or McGurk rockers to turn up.
    or if time is more important and you want better technology buy Tony's rockers.
  2. falcongeorge
    falcongeorge
    from BC
    I'm in no hurry Paul, got lots of time, it will probably take 1 1/2-2 years to finish the car. Probably what I will do is get a set of stock rockers from you, and then if I find a set of Iskys over the next year, I will go solid, otherwise I will put a hyd cam in it. I'd really prefer solids.
    Once I get a core from you, I will be pretty much broke till the new year, Christmas is expensive with a 5 yr old in the house, and I am going to Vietnam for a month in January, so money will be tight for the next few months.
  3. JohnnyD.
    JohnnyD.
    from Kentucky
    THAT'S QUITE THE COMPLIMENT. THANKS!
  4. olscrounger
    olscrounger
    JohnnyD--love the look of your engine compartment-spot on!!! Have a couple of those intakes laying around and may put one on a 40 coupe I'm doing with an early 327.
  5. Cragar
    Cragar
    ImageUploadedByH.A.M.B.1412539115.931224.jpg . Here is my little Windsor in my 32 roadster
    biggeorge likes this.
  6. hotrd32
    hotrd32
    from WA
    Thanks Dale ...
  7. 56don
    56don
    This isn't as detailed as most of the engines on here. But I will get more picky about the details once I get the truck painted and going. This is a 1959 348 with 1960 3x2 setup in my project 34 truck.
    biggeorge, Hanke, Hotrodmyk and 2 others like this.
    This is my T Truck engine board 283 now 292 isky cam forgot what grind
    early 194 heads Edelbrock X1 intake came off my friends sprint car holly carbs
    Jakesrocks likes this.
  9. tevintage
    tevintage
    A 350 in my 39 Deluxe Tudor.
  10. loudbang
    that is one nice looking FSB.
  11. vtwhead
    vtwhead
    May not be as detailed as you wish but nothing is nicer than a "W" block in a hot rod!
    56don likes this.
  12. Runnin shine
    Runnin shine
    Yeah, what George said.
    "I need my mirror boy"
  13. Jakesrocks
    Jakesrocks
    Jandlcars, I love that you've left the telephone booth cab on your T truck. Way too many are getting chopped.
  14. 32 Spitfire
    32 Spitfire
    biggeorge and Hotrodmyk like this.
  15. JohnnyD.
    JohnnyD.
    from Kentucky
    Thanks! I'm running a Crane 113801 hydraulic cam and I'm really pleased with how it runs. The WCFB's are crazy responsive. Just take a little extra time with the intake install. This intake is kind of a mismatch to the larger ports of the 327 heads. I used ultra black real thin and let the gaskets set up on the heads a bit so things wouldn't move around when I sat the intake down. I think you'll be more than happy.
  16. deto
    deto
    This is exactly what I want my motor in my 49 to look like. What intake and carbs are you running?
  17. 504640
    504640
    I'll have a 63 327 soon. I'd like to dress it like this to drop in my 40. Is that a corvette air cleaner. I sure don't remember the wire looms like this. What about them?
  18. falcongeorge
    falcongeorge
    from BC
    The intake is the cheap and easy part, wait till you try to find the 9 fin valve covers...
  19. 504640
    504640
    Babbit Pounder!
  20. enloe
    enloe
    from east , tn.
    I heard that
  21. falcongeorge
    falcongeorge
    from BC
    Yuppers, and it took me two years of hunting to get mine.
  22. Elco Heads
    Elco Heads
    My Flathead fitted with Elco Twin Plug Heads and a Nash Twin 8 Dizzy. ELCO 1.jpg
    airsix, biggeorge, FlatJan and 2 others like this.
  23. Elco Heads
    Elco Heads
    biggeorge, FlatJan and Hotrodmyk like this.
  24. Elco Heads
    Elco Heads
  25. Doc.
    Doc.
  26. qzjrd5
    qzjrd5
    from Troy, MI
    Yeah, that's a late C1 air cleaner. Those aren't actually wire looms, that's shielding for a Corvette so that it doesn't get radio interference from the ignition system. Used only on Corvettes - cause they are fibergl***. I thought it looked cool though, so I put it on. '63 was the first year for alternators, keep that in mind.
  27. 504640
    504640
    Thanks qzjrd. I haope to find some bracketry for a generator. Also, in some of the photos I have seen, the 63 'vette air cleaner looks a lot different: bigger and with 2 long skinny snouts, both facing directly forward. Some of the 250 hp vettde motors I looked at had the big chrome distributor housing, others haven't.
  28. fairlane 63
    fairlane 63
    from NO.DAK.
  29. JohnnyD.
    JohnnyD.
    from Kentucky
    IT'S A '56-'61 VETTE DUAL 4 SET UP. '56-'57 AIR CLEANERS ON CARTER WCFB CARBS. THE FACTORY DUAL QUAD CARBS AND ***OCIATED PARTS ARE PRICEY, BUT WCFB'S CAME ON ALOT OF 50'S CARS, SO A CLONE DEAL WOULD'NT BE TO FAR OUT OF REACH. THE INTAKES ARE REASONABLE. KEEP IN MIND IF YOU HAVE TO HAVE THOSE NICE NINE FIN COVERS THEY HAVE THE STAGGERED BOLT HOLES.
  30. JohnnyD.
    JohnnyD.
    from Kentucky
    LOVE IT!
