Projects 32 5 window build
Discussion in 'The Hokey Ass Message Board' started by Novaron, May 4, 2014.
  1. Novaron
    Novaron
    from New York
    Thanks
  2. edcodesign
    edcodesign
    Nice job, got the look, good luck !
  3. Please keep us up to date on your build.
    I love the look of a mildly chopped 5 window '32.
  4. Novaron
    Novaron
    from New York
    Thanks. Will do.
  5. Novaron
    Novaron
    from New York
    Making a bracket for the Mallory coil, resister and surge protector
  6. Novaron
    Novaron
    from New York
    Mounted under dash with u bolts.
  7. Novaron
    Novaron
    from New York
    Upper radiator hose. Gates 20607. Straight ahead thermostat housing. The cut off piece is sitting on the manifold.
  8. Novaron
    Novaron
    from New York
    Bottom hose. Gates 20242. 1956 Chevy. Fit perfect, no trimming required.
  9. Novaron
    Novaron
    from New York
    Shifter mount.
  10. Novaron
    Novaron
    from New York
    B&M prostick works with an overdrive automatic. Moon pedal all mocked up. Brake pedal is from a Harley. 20140705_214903.jpg
  11. Novaron
    Novaron
    from New York
    Shifter mount still needs some legs to add a little more stability.
  12. Novaron
    Novaron
    from New York
    Better shot of the Moon pedal. The metal plate, for now, is bolted to the firewall with some small nuts and bolts. After I expoxy the mounting plate to the firewall, I will remove the bolts and fill in the holesfrom the outside for a clean firewall. I tapped the metal plate for 1/4-20 bolts. The bellcrank is Speedway. Throttle cable is Lokar. Pedal to bellcrank is just some medal rod for now. Seems to work alright. I hate auto correction. 20140705_215009.jpg
  13. loudbang
    Maybe it's just the photos but to my eyes it looks like the top of the radiator/grille should be tipped back toward the body by an inch or so if you plan to run no hood. It looks in the photos to be tipped out just a bit too far.
  14. Novaron
    Novaron
    from New York
    Your right. It's on my short list.
  15. Novaron
    Novaron
    from New York
    Making linkage for the Moon pedal
    1/2 rod drilled and taped to 1/4-28 for QA1 CMR4 hiem joints.
  16. Novaron
    Novaron
    from New York
    Ground down the heads of the stainless bolts and polished it all up. Ready to install. 059.JPG
  17. Novaron
    Novaron
    from New York
    Cut off switch.
  18. Novaron
    Novaron
    from New York
    Drilling holes for fuel lines and battery cable. Getting ready for wiring.
  19. Novaron
    Novaron
    from New York
    Battery box install. Snaking cable thru frame.
  20. Novaron
    Novaron
    from New York
  21. Novaron
    Novaron
    from New York
    Master cutoff...
  22. Novaron
    Novaron
    from New York
    Ran fuel line thru frame.
  23. loudbang
    Nice "clean" work you are doing.
  24. Novaron
    Novaron
    from New York
    Thanks.
  25. Novaron
    Novaron
    from New York
    Finished the fuel lines today. Starting on the exhaust.
  26. Novaron
    Novaron
    from New York
    Bleeding the master cylinder. Found some leaks at a couple of fittings.
  27. Novaron
    Novaron
    from New York
    20" trans cooler...
    Merlin likes this.
  28. gtolarry
    gtolarry
    from Texas
    This is a cool build. I am starting a 32 roadster and I am likeing some of your ideas. Car looks good lowered.:)
  29. Novaron
    Novaron
    from New York
    Thanks. Good luck with your build.
  30. Novaron
    Novaron
    from New York
    Some progress on the exhaust system.
