Technical Lowering the rear of a '32 Roadster the traditional way
Discussion in 'Traditional Hot Rods' started by firerod, Sep 23, 2014.
  1. DeucemanLt1
    DeucemanLt1
    It's not the reversing that makes it "grow", it's the de-arc.
  2. firerod
    firerod
    from Colorado
    Today I took all of your advice and reversed the eyes myself with a press. Took about 30-45 minutes and was no big deal. Thanks HAMBers.
  3. Hitchhiker
    Hitchhiker
  4. alchemy
    alchemy
    Evidently DeucemanLtl hasn't read the article. Or taken some before and after measurements.
  5. "It's not the things you don't know that get you into trouble, its the things that you know for certain that just ain't so. "
    But I suppose you could reverse one and keep the eyes the same, but there's no way to de arch one and keep the same Eye to Eye
  6. Hitchhiker
    Hitchhiker
    But then the arc isn't the same.
  7. Yes I know, it's a little ****y.
    Then you need to de arch it to get the same arc. And as we all know de arching a spring makes it bigger in the eye to eye dimension.
  8. terrarodder
    terrarodder
    from EASTERN PA
