Traditional 283 build..
Discussion in 'Traditional Hot Rods' started by sodakmini, Sep 19, 2014.
  1. Isky will sell you the cam with the gear drive as a set. I'm guessing this became available in 1963.
    Oh, you also need to use a reversed distributor drive gear with a reverse helix.
    Do whatever you want, just throwing out that gears weren't a "70's" thing.
  2. sodakmini
    sodakmini
    Ok. How about another question.... Do I need to run a 4 blade fan? Or are there other period correct fans that will function better?
  3. joel
    joel
    Based on the choices you have favored so far, I think you would prefer it and a 4 blade shouldn't be hard to find or expensive.
  4. sodakmini
    sodakmini
    I've been told a 4 blade won't have sufficient cooling... True?
  5. CGkidd
    CGkidd
    It will work fine.Throw a fan shrould on it if need be.
  6. sodakmini
    sodakmini
    Can any of you recommend a distributor for me???
  7. F-6Garagerat
    F-6Garagerat
    Here's my 1957 283 in my A pickup. It's a front mount only block with a hurst mount and an oil canister.
    3731539 heads
    Howards hydraulic cam similar in specs to the GM 30/30 cam
    Vintage Fenton 3x2 with oil fill tube and three 97's and vintage frog mouth scoops
    Vintage Segal progressive linkage
    Corvette valve covers
    Vintage Mallory dual point
    Chevy 4 blade fan
    Delco generator
    Rams horn manifolds
    Here's a couple pics:
  8. sodakmini
    sodakmini
    Absolutely awesome!!
  9. F-6Garagerat
    F-6Garagerat
    Thanks.
  10. sodakmini
    sodakmini
    I'd like you to put up some pics if your able.
  11. joel
    joel
    I like the firewall clearance for the dist. The whole compartment is neat and clean.
  12. joel
    joel
    I like the 4 lobe Mallory dual points. Point wear is very low; although finding points may be an issue.
  13. 283
    283
    I have a 283 in my digger. The heads are from a late 70's 264. The intake is an Off 360 the dual Webers didn't like the intake so I switched back the a 600 Holley. The cam is a 350 horse cam. Car runs mid 7's in the 1/8. I've got a set of the 305 4 barrel heads on the 307 in my 37 Plymouth and they are great but require 93 octane.
  14. F-6Garagerat
    F-6Garagerat
    Thanks. I don't care for the look of flipped firewalls on 30-31 model A's for engine clearance. When you lose the rounded edge to the firewall at the cowl it just doesn't look like a model A to me anymore. You also lose toe board too. Not a lot but 4" of leg room in an A pickup is a lot. Just under the valve cover clearance area my recess angles forward to the stock toe board location. No modification to my floor.
  15. Hotrodmyk
    Hotrodmyk
    Very nice!
  16. F-6Garagerat
    F-6Garagerat
    Thanks
  17. racer32
    racer32
    Depending on the casting #, a 283 block will bore up to 4" with no problems, so your engine at +.040 gives you LOTS of leftover walls for future rebuilds. If you want a streetable 283 that you don't have to rev to the moon to make any power, DO NOT use camel/double hump heads or a "performance" cam (not even the Duntov 097 or the L-79 327 cam). Use the Power Pack heads, and upgrade to 305-sized (1.84) intake valves. Your 283 needs the smaller ports and valves. It also needs less duration than a 327 or a 350. Over-cam it and run heads with too much port, and I guarantee that a stock 2bbl 283 will outperform it in 99% of "real-world" street driving situations. FWIW, if you swap to 305 heads, you ain't building a traditional 283...might as well build a 350.
    gas pumper and 3wLarry like this.
  18. Hurley50
    Hurley50
    from NC
    Nice engine!
  19. 3wLarry
    3wLarry
    from Owasso, Ok
    finally, someone gets it right...this is excellent advise
  20. j3harleys
    j3harleys
    Weiand and Nicson cast 2x2 SBC manafolds back in the day. Very hard to find. That would cool and unusual.
  21. Babar40
    Babar40
    from Florida
    image.jpg Here are 2x2's on a small block. Not mine but a very cool set up. I have a '57 power pack motor from a Belair that I am doing the 270 hp deal on it and I am keeping factory (small) heads on it. Won't race it........much.
    Hotrodmyk likes this.
  22. 40panel348
    40panel348
    C[​IMG]
    Here's mine mocked up... 1960 Corvette 283 being set up to 270 hp specs, 1961 power pack heads, 097 cam with solid lifters and a Man-A-Fre intake. The block is .060 over. My machinist put in slightly larger exhaust valves and some port and polish work on the heads. I have a T-10 4 speed and a 1960 Chevy rear in it too. I have some repro Fenton headers. I am going to use reproduction Corvette "off road" mufflers to get the sound of an old dual quad Vette. The fun part is that a '40 pickup and a '60 Vette weigh almost the same. It should be fun if I ever get back to work on it.
  23. louisb
    louisb
    I just bought the last set of Patrick's repo Fenton SBC headers for my 1957 283 project. the rest will be 4 97's on an Offy intake, 10.5ish compression, ported '62 power pack heads, 1.84 intake, stock exhaust & L79 cam from comp cams. Can't wait to get mine together.
    --Louis
  24. sodakmini
    sodakmini
    Got a stuck complete 283 with power pack heads from a friend. Pulled the heads......full of rust. I'm not smart enough to know if there salvageable...guessing not. ImageUploadedByH.A.M.B.1415461714.455371.jpg
  25. Engine man
    Engine man
    from Wisconsin
    Your wife leaving you is very traditional!
    treb11 likes this.
  26. Engine man
    Engine man
    from Wisconsin
    They should be salvageable. Have them cleaned at a machine shop. As has been said, hard valve seats should be installed so even if the valve seats are very rusty it shouldn't matter.
    CGkidd and loudbang like this.
  27. Koz
    Koz
    Resurrecting this thread for a quick question..... Anybody know what the compression ratio will be on a 283 using 462 casting/1.94 heads and stock pistons? The pistons are typical relieved flattops, probably TRW and the motor is 0.30 over, not that it matters. I believe they were 8.5 from the factory.
  28. joel
    joel
    ***uming 64cc chambers & .041 piston/head clearance, about 8.7 to1
