Hot Rods Rear end noise
Discussion in 'The Hokey Ass Message Board' started by tkmark, Sep 23, 2014.
  1. tkmark
    tkmark
    I have a 50 Chevy Fleetline with 235, 3 speed manual and enclosed driveline. I bought an automatic rear end for it with the 355 ratio, had it "set-up" at a local shop before I installed it. It makes a growl upon deceleration that my 411 original set-up did not. Please let me know your thoughts and or suggestions. Thanks, Mark
  2. manyolcars
    manyolcars
    run it until everything seats and is silent
  3. saltflats
    saltflats
    from Missouri
    What brand gears are they?
    Or are these used gears.
  4. stimpy
    stimpy
    for new gears there is a break in sequence for them , run them 500 miles at varying speeds , no excessively hard accelleration ( hard off the line or engine braking or towing for the first 500 miles , ) then it should quiet down , then change the oil .
  5. Grahamsc
    Grahamsc
    from Colorado
    Depends on your definition of a growl.
    Bearings that are damaged growl.
    Gears that are not set up correctly will make a howl or whine type noise.
    New gears and bearings set up correctly should make little to no noise at all.
  6. Hnstray
    Hnstray
    from Quincy, IL
    The OP stated he "bought a 3.55 Powerglide rear end".....I am ***uming he purchased a used complete unit. That being the case, I was surprised that he had a local shop "set it up". Does 'set it up' merely mean install it...or did they
    replace bearings and seals, etc.?
    I'd start by taking it back to the local shop and see what they say.....then look for a knowledgeable rear axle guy to fix it.
    Ray
    banjeaux bob likes this.
  7. tkmark
    tkmark
    Ray is right, used gears and the noise is a whine only on deceleration. After a 15-20 minute drive, the rear axle housing is not hot or even warm. i guess i'll just pull it and get it into a shop that knows whats up. Thanks!!
  8. bobss396
    bobss396
    Old car manuals used to have a gear-noise identification chart on them, what noise it makes coupled to what driving condition. That would isolate where the noise is coming from.
  9. 57 HEAP
    57 HEAP
    Used gears into a different housing? That is the problem. You can chase your tail trying to fix it, but it will still make noise. Best bet is new parts and a complete rebuild.
  10. tkmark
    tkmark
    OK guys, I got the rear end out of the car and it needs a good going through by somebody that knows whats up. I need any suggestions as to who to take it to in the Portland, OR - Vancouver, WA area. Thanks in advance for your help. Mark
  11. 302GMC
    302GMC
    from Idaho
    Call Joe at Old Car Parts ... he'll fix you up with a GOOD used one ready to run.
  12. banjeaux bob
    banjeaux bob
    from alaska
    Just a few words on gears.... a new gear set with new bearings should not make any noise.If they make noise from the start,they will NOT wear in and get quiet.It's also hard to get them to set them up to be quiet after they have been run.
    Noise on decel with a new gear set usually means too much backlash.
    A used gear set installed with proper tooth contact,backlash,and bearing preloads that makes noise will always make noise.However,that does NOT mean it will not deliver service.
    Hnstray likes this.
  13. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Check with John at Gateway Auto Center on Stark st in Portland Oregon
  14. The 3:55 rear end and torque tube from the powerglide car is removed, then installed, as the same unit, into the stick shift car. No fussin' with preloads, gear pattern shimming, etc., just R & R.
    Why the need to have the rear "set up" ? New parts added ?
    Not necessary, under every day conditions.
  15. 56premiere
    56premiere
    I got one out my 54 if you want to drive 6 hours each way you can have it. Powerglide so should be 3:55
    302GMC likes this.
  16. tkmark
    tkmark
    Where are you premiere? I'm headed south on Thursday.
