I am at work so I can't research this now. I was just hoping that someone would know. Where do I get the nails that hold the wood in, in my 32 5w? Mine are old, bent, and crusty, kinda like me. Would like to find as close to stock as possible. Thanks in advance.
It would not surprise me if they are the same as the nails used in 1928 to 1931 Model A Fords. Those are readily available at Snyders or Brattons, both have on-line catalogs.
Found them at Snyder's. They are called body nails. So tomorrow I will measure the nails I took out to check for a match. Thanks very much. I love the HAMB!
My 30 coupe's roof was held down with spiral nails (very hard) the relacements that I purchased, I forget where, were not the same spiral or hardness. So just a heads up, if you're looking for exact copys, check closely. The ones I got did the job but they weren't the same. -Pat
