Projects My First Custom - Shoebox Project
Discussion in 'The Hokey Ass Message Board' started by the-rodster, Aug 26, 2010.
  1. the-rodster
    the-rodster
    I got some new literature in the mail......
  2. daddio211
    daddio211
    Gotta few questions, if you don't mind. What heater core did you use? Where'd you find the compressor? What air shocks did you use?
  3. beyond static
    beyond static
    from Louisiana
    To add to the questions.....What 12v motor are you using for the heater? I like how you did the turn indicator switch. I ended up using one of the cheap universal steering column mount units and putting it low on the column under the dash so it's half way hidden
  4. the-rodster
    the-rodster
    Stock 49 heater core
    Air Lift 25804 Air shock controller kit $142.83 - summitracing.com
    Monroe Max-Air MA727 air shocks $69.99 - advanceauto.com
    Habitual likes this.
  5. the-rodster
    the-rodster
    I found several threads about what 12V heater motor may or may not fit - ranging around 30 bucks.
    But, shoebox-central.com has one for 40 bucks, so I figured that was a safer bet.
  6. BenDaPirate
    BenDaPirate
    Just read the whole thread. You've got some killer talent! Looks great! Can't wait to see more!
  7. Slopok
    Slopok
    Considering what you started with and where you're at today, amazing transformation and the fact that you've done it all yourself is even more is even more commendable. I admire your commitment to continue this project to the end. Congratulations on your 1st award, I'm sure it's just the 1st of many more to come once the car is finished.
  8. PurdueSD
    PurdueSD
    Rich, You've got a nack for these budget builds! Wish i had half your work ethic!
  9. the-rodster
    the-rodster
    Go ahead, call me a cheap ***.... I don't mind :)
    Rich
  10. jimcolwell
    jimcolwell
    from Amarillo
    Hello I was thinking of working the rear bumper over with alum. foil. Your car is far out so don't back up. People like your car.
  11. Brentphx
    Brentphx
    I'm curious what pressure you find yourself using in the air shocks for show vs normal driving. I'm ***uming you get a slight boost in the ride height aired up, right?
    Love the build thread, looks great!
  12. the-rodster
    the-rodster
    When parked, I let all the air out, and have about an inch and a half of travel.
    When driving, I inflate to 30-40 lbs, and it raises the rear almost two inches.
  13. daddio211
    daddio211
    Thanks for the answers and part numbers. Much appreciated!
  14. the-rodster
    the-rodster
    Peel. Stick. Repeat.
  15. the-rodster
    the-rodster
  16. the-rodster
    the-rodster
  17. Buddy Palumbo
    Buddy Palumbo
    Nice ! I guess I've gotta start thinking about sound deadening soon .
  18. the-rodster
    the-rodster
    I bought all of the trim tools that a hot rodder in Knoxville was getting rid of...
    Consew 226
    Tons of thread
    Staples and stapler
    Hog rings and pliers
    etc....
  19. the-rodster
    the-rodster
    My first seams!
    Yoohoo....
    I ****, and need a LOT of practice...
  20. Buddy Palumbo
    Buddy Palumbo
    LMFAO !! I know that feeling .
  21. DBruce
    DBruce
    Love the "Peel & Stick", s***ching ain't perfect, but your gonna get it, I can tell.
  22. 4rod
    4rod
    Cul I've been looking for an industrial machine...very cul find
  23. the-rodster
    the-rodster
    Worked on more insulation this weekend.
  24. the-rodster
    the-rodster
  25. the-rodster
    the-rodster
  26. the-rodster
    the-rodster
    The back two bows had to be lengthened to keep them nice and tight against the insulation.
  27. the-rodster
    the-rodster
    Getting ready for a headliner, removed the rear gl***...
  28. Slopok
    Slopok
    Is that Peel & Seal on the headliner to or Reflex??
  29. the-rodster
    the-rodster
    This stuff....
    http://www.lobucrod.com/
    He's an alliance dealer.
  30. Slopok
    Slopok
    Ok Thank You.
