Projects 32 5 window build
Discussion in 'The Hokey Ass Message Board' started by Novaron, May 4, 2014.
  1. Novaron
    Novaron
    from New York
    Hanger bracket.
  2. [​IMG]
    Have you considered using a zips riser to get the fan centered in the radiator,the fan is so low it's probably not going to do it's job. HRP
  3. Novaron
    Novaron
    from New York
    So-Cal speed shop alternator bracket.
  4. Novaron
    Novaron
    from New York
    I might have to if this does not work.
  5. Novaron
    Novaron
    from New York
    Drivers side exhaust completed , at least back to diff for now.
  6. Novaron
    Novaron
    from New York
    Dynomax Super Turbo mufflers with a Jegs 2 1/2" street rod exhaust kit. Wish the exhaust kit had a few more 45' bends in it, but all in all very happy with the kit. I'll add the tailpipes later.
  7. Novaron
    Novaron
    from New York
    Here's the video.
    http://vid752.photobucket.com/albums/xx167/ronr2/Video/32 ford startupwith ag2.mp4
    Start up went fairly well. The brand new Mallory coil had a short so I ran down to the local parts store and bought an Accel coil and now had some spark. Next was no fuel. I failed to tighten the fuel line connections real tight when I installed them, and the pump was sucking air instead of fuel. After that it fired right up. Oil pressure at 55psi, water temp 190 F. Hope to take it for a ride after Thanksgiving , if the roads are dry.:(
    norms30a and Merlin like this.
  8. loudbang
    Really sucks when on "the big day" you find freaken brand new parts are BAD. :mad:
  9. Novaron
    Novaron
    from New York
    Yes it does. But a fairly cheap fix.
  10. Novaron
    Novaron
    from New York
  11. Novaron
    Novaron
    from New York
    Front shock mounts tig welded by Nick at Racemasters in Ballston Spa, NY.
  12. Novaron
    Novaron
    from New York
  13. Blue One
    Blue One
    from Alberta
    Nice job, the only thing I could be critical of is the welds on the exhaust. It always looks nicer if they are ground smooth.
  14. Novaron
    Novaron
    from New York
    A few shots on the trailer.
  15. Novaron
    Novaron
    from New York
    Ill need to work on those after I tear it down for paint. Right now I'm kind of pushing to get it ready for the DMV inspection so I can get a VIN and register it...
  16. Novaron
    Novaron
    from New York
    Raised the back up a little.
  17. Novaron
    Novaron
    from New York
    Merry Christmas all. Have a happy and healthy New Year.
  18. Novaron
    Novaron
    from New York
    Socal speed shop Arrow head lights
  19. Novaron
    Novaron
    from New York
    Well, finally on the road! Here's a shot of some tailpipe hanger brackets I made. hangersmall.jpg
  20. Novaron
    Novaron
    from New York
  21. Novaron
    Novaron
    from New York
    A little road trip IMG_20150412_184115small.jpg IMG_20150412_184201small.jpg
  22. Novaron
    Novaron
    from New York
    IMG_1414.JPG A great day for a ride...
  23. Novaron
    Novaron
    from New York
  24. Novaron
    Novaron
    from New York
    Drilled brake pedal.
  25. Novaron
    Novaron
    from New York
    Trans tunnel.
  26. Novaron
    Novaron
    from New York
    Master cylinder cover.
  27. Novaron
    Novaron
    from New York
    Apart to paint the frame.
  28. Novaron
    Novaron
    from New York
    The tie down strap really helped keep it even as it came up. IMG_1722.JPG IMG_1724.JPG
  29. Novaron
    Novaron
    from New York
    Time to clean up the frame and paint it.
    54reno likes this.
  30. Novaron
    Novaron
    from New York
    Put almost 1000 miles on it before dis-assembly. Here's a few shots.
