Projects A 1933 Ford 5w coupe from a 4 door sedan...
Discussion in 'Traditional Hot Rods' started by Fordgasser1, Jun 4, 2011.
  1. jseery
    jseery
    from Wichita KS
    That would most likely depend on the state, but there is nothing in the car ID number that would indicate body style. The ID numbers is on the frame and both of my frames are from under sedans, but now have coupe bodies. Unless someone pulled up an original registration on the car that showed body style.
  2. 3blapcam
    3blapcam
    Good question! I need a floor also!
  3. 62hotcat
    62hotcat
    Needs a cooler and fishing pole mounts. Beach buggy tag so you can tnt.
  4. Fordgasser1
    Fordgasser1
    from Jersey
    Thanks Tim,You are in deep! I've seen what you're doin and its awesome work!
    Thanks guys!
    Hi Dave!.Thanks much! I have a ***le for a 1933 Ford 2dr. which came with the second frame I used to repair the original.
    The floors came from howells in TX.
  5. Fordgasser1
    Fordgasser1
    from Jersey
    Howells in TX
    Ha ha! Maybe I should add a cooler rack to the frame! I actually used to make them for a place I worked at 20+ years ago!
  6. TANNERGANG
    TANNERGANG
    from alabama
    Some people are gifted with too much talent and patience.......you are one of those........why couldn't some of that have been p***ed on my way...........................
  7. hotrodderhaag
    hotrodderhaag
    im going to have to ask the same question....... damn..
  8. mgtstumpy
    mgtstumpy
    No turning back now, beyond the point of not return. Love it.
  9. Fordgasser1
    Fordgasser1
    from Jersey
    Thanks guys! I appreciate the compliments!
  10. Fordgasser1
    Fordgasser1
    from Jersey
    33coupepics 001 (Small).jpg 33coupepics 004 (Small).jpg 33coupepics 006 (Small).jpg In case you think I'm slacking..Work is progressing on the drivers side 1/4 panel..Lots of fitting,slicing and beating..Tacked it up with the mig and tig welded a good portion of it. I'm not that great at tig welding thin steel so I will use the mig to finish it up..
    mrrooth and crozch like this.
  11. Fordgasser1
    Fordgasser1
    from Jersey
    33coupepics 002 (Small).jpg 33coupepics 003 (Small).jpg 33coupepics 006 (Small).jpg 33coupepics 005 (Small).jpg more progress.Starting to look like a 1/4 panel. I recycled some of the original 33 sheetmetal I trimmed off the cowl and made a patch for the lower quarter. .
  12. 1952B3b23
    1952B3b23
    from Western MA
    Lookin' good man. These types of transformations really amaze me, great skills.
  13. HOTRODPRIMER
    HOTRODPRIMER
    The recent wheel well patches make a big difference,this is going to be a great build. HRP
  14. schoum
    schoum
    from france
  15. alchemy
    alchemy
    The key to TIG welding is cleanliness. If you cleaned the rust off first (every bit of it) you will have much more success. A quick sandblast of the area, then a wirebrush to clean the sand from the pits (yes, the sand down in the pits still affects the welding) and it will be like welding on new metal.
    cptn60 likes this.
  16. wedjim
    wedjim
    from Kissimmee
    Wow, when I first saw this thread I thought...make a sedan into a 5 window, yeah right.
    It's obvious you know what your doing and it's coming along great. Too many of these projects are started as dreams by the less capable, then abandoned.
    Looking forward to your progress!
  17. TomT
    TomT
    This ****er is really coming together nicely - if I only had just a little of the talent you guys have I would be extremely dangerous. Really great work ....
  18. six pack to go
    six pack to go
    from new jersey
    How did I miss this thread!?!?! AWESOME!!
  19. Excellent work Fordg***er1!!
    Dustin
  20. onekoolkat1950
    onekoolkat1950
    Nice job. Can't wait to see more.
  21. 48 Ragtop
    48 Ragtop
    nice, very nice
  22. 1951hudson
    1951hudson
    I am new to the HAMB and want to know how do I subscribe to a thread? I see people talking about doing it, and would like to follow this thread! Btw the work here and on a number of other posts are amazing!
  23. 3blapcam
    3blapcam
    A lot of times, just posting in it will subscribe you (it does for me but that could be set up in the settings or something). Or, at the top of each page of the thread on the right side is a "watch" ****on.
    Good luck!
  24. 345
    345
    from Michigan
    Sweet!
  25. harleycontracter
    harleycontracter
    Such talent !!!!!!!!!!!!!1
  26. thequietwon
    thequietwon
    More pics please...
    This thread actually motivated me to work on my 34 5w last weekend...
    Crazy good work!
  27. Rocky
    Rocky
    Classified Editor
  28. Fordgasser1
    Fordgasser1
    from Jersey
    Thank you!
    Yeah, it really does make a huge difference..They are one of the bigger obstacles,I'll be relieved when they are finished and on the car permanently!
    Thanks Shoum..Your builds are awe inspiring!
  29. Fordgasser1
    Fordgasser1
    from Jersey
    Thanks for the help. I taught myself how to tig weld so I'm still learning. I did more tig welding today on the 1/4 panel and had much better results!
    Thanks for the compliments! This build stalled because of other work but I am determined to see it finished
    Thanks guys!
  30. Fordgasser1
    Fordgasser1
    from Jersey
    I spent a few days this week chasing some parts for this build. My bud Ken Kull in Pa. had a busted '39 toploader w/double detent top for cheap and a few 97 carbs. The 39 box will need a cluster and 2 gear but otherwise looks good! I scored a good cluster and intermediate gear for it tonight so I'll be rebuilding that this week. I also picked up an old Schroeder sprint car steering box to do a cowl steering setup!
