Hello this is my first post. Hope someone can give me the answer.
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by luckyglucky, Sep 25, 2014.
  1. luckyglucky
    luckyglucky
    Just bought a 1951 Chevy Deluxe.
    At some point it was converted to 12V although the wiring under the dash looks a untouched.
    can anyone identify this for me?
    There is are 2 wires, 1 coming from the ignition switch and then 1 going out, cant tell where to.
    I disconnected the one going out, the engine turns over but wont start.
    I thought it might be a resistor?
    the reason I need to know is when the engine is running it gets REALLY hot. Could it be 6v.
  2. proartguy
    proartguy
    from Sparks, NV
    I would guess it did not run when you disconnected is because it supplies power to the coil. The resistor may have been installed to drop the voltage to the points when converted to 12 volt, rather than using the regular ballast resistor. Yes, that would get hot.
  3. luckyglucky
    luckyglucky
    Thanks for the input, much appreciated.
    There were so many issues with the bad conversion from 6 volt.
    Have decided to start again and am putting in a new wiring harness.
  4. jimcolwell
    jimcolwell
    from Amarillo
    You are doing real good now go get a HEI distributor from your local junk yard and do away with that resistor before it burns you car to the ground.
  5. sprdave4264
    sprdave4264
    from Arkansas
    gotta agree with jimcolwell I've had a wiring related fire and no fun. spend the money now on new wiring.
  6. luckyglucky
    luckyglucky
    Yup.... Had a little fire just before I ripped it all out. Scary for sure.
    All wiring is history now, nearly completed the new harness.
    Thanks for the input.
  7. Last edited: Oct 24, 2014
  8. raymonds55
    raymonds55
    Probably used as a kill switch.
