History NHRA Junior Stock
Discussion in 'Traditional Hot Rods' started by colesy, Aug 12, 2007.
  1. 270283
    270283
    This thread is on page 348, anyone have pictures of 348-powered Junior Stockers?
  2. Hydrophobia Delivery
    The second part of the York 2015 Musclecar madness show actually takes place at Beaver Springs for drag racing in Sunday , July 12th, 2015. There's a pretty good possibility that the famous " Stockers To The Lanes Please" call may very well be heard as Beaver Bob may be planning to run the Stockers in their own eliminator this year!! The more cars, the better chance that the Stockers will have a part of the show. If you're sitting on one from the past, dust it off. It's going to be a blast. There won't be a Teardown barn so Cheater cams welcome.......
  3. R W Ohio
    R W Ohio
    from Ohio
    wheelsup60 and lawman like this.
  4. Grandadeo
    Grandadeo
    Only wish I had a picture of our G/Stock '58 Chevy my brother and I ran at Niagara Drag Strip in '66 and '67. Think I've shared this on here before but it's probably 200 pages back. We wanted to put a Junior Stocker together and my brother wanted to run a 348. Figured a '58 would be the cheapest body to buy so we got with a tech guy at Niagara to see what body weight/HP combination would be the best for any given cl***. Turned out a 250 HP 348 in a Delray Tudor sedan ratio was 14.00. If you look up a few posts you'll see that G/Stock was 14:00 - 14:99. Pretty much a no brainer. Found a decent Delray body and a donor '58 with a running 348. Put everything together with a 4spd and 4:56 gears and went racing. We put a new stock cam in it, checked the bearings, Doug's headers and M&H cheater slicks. The car was compe***ive and won its cl*** most of the time. All that fun and new friendships for around a thousand dollars total. Great memories.
    Lee
    lawman likes this.
  5. Chuck Norton
    Chuck Norton
    from Division 7
    The attached picture has been in my files for several years. It is an unattributed shot of an early A/S '60 Chevy with California black-on-yellow license plates. That license plate series was replaced by the yellow-on-black plates in about 1962 so that cons***utes about the only evidence of that moment in time. I suspect that the driver might have been Elwin Westbook but I have no proof of that.
    Kevs56 likes this.
  6. Jimbo17
    Jimbo17
    I miss the Junior Stock cl***es. I always thought they put on a great show!!!!!!!!
    I would love to see the NHRA bring back Junior Stock and Modified Production someday.
    Jimbo
    lawman, slowmotion and loudbang like this.
  7. WGuy
    WGuy
    from Central NJ
    Photo courtesy of Joel Naprstek
    lawman likes this.
  8. Paul Ceasrine
    Paul Ceasrine
    from Wilton, CT
    I remember those 348's.
    Back in 1969, at Dover Drag Strip my father came up against
    1961 Impala 'convertible' 348/280 HP 'Tri-Power' 4-Speed in
    K/Stock {12.50 to 12.99 Wt/HP}.
    A bunch of kids from Danbury, Connecticut found it sitting in the
    side-lot of a Sunoco Gas Station with about '40' Cl*** Winner decals from Connecticut Drag Strip on the windows. The Impala hadn't been raced for 2-Years {since early-1967}.
    Man was that 61' Impala 348 'Tri-Power' loud. It scared the Hell out of us.
    In Time Trials it was running in the 13.2o's, which was just off
    the National Record of 13.12.
    We had never seen a 348 Tri-Power in our cl*** before, so my Father went
    down to the Tower to see if the Tech Inspector had made a mistake in cl***ing the Impala with us in K/Stock.
    Sure enough, the 1961 Impala 'convertible' with the 348/28o HP 'Tri-Power'
    with the Hydraulic Camshaft fit into our cl***.
    #3600 lbs. ~ 280 HP = 12.75 Wt/HP
    Man, 'what a beast' that car was.
    lawman likes this.
  9. Jimbo17
    Jimbo17
    Paul Ceasrine:
    Who owned the 62 or 63 Chevrolet blue station wagon with either a 348 or a 409 that raced at Dover every Sunday for years and if my memory is correct was driven by a gal.
    The car ruled for years and was really bad to the bone.
    Jim Hill
  10. Paul Ceasrine
    Paul Ceasrine
    from Wilton, CT
    Jim,
    There was a 1962 Chevrolet Biscayne 'Station Wagon' with a 409/380 HP 4-Speed that ran at Dover in the mid-and-late 1960's. But it was 'Honduras Maroon'.
    Very Fast.............
    It could have been driven by Ms. Jean Jankaura .....
    It was cl***ed in;
    1967 > C/Stock
    1968 > F/Stock
    1969 > G/Stock
    There was also, Fred's Speed Shop that ran a 1963 Station Wagon {light blue} in F/MP.
    They won just about every week.
    lawman likes this.
  11. biscaynes
    biscaynes
    wenzelbros1.jpg wasn't the wenzel bros '60 a 348...
    wheelsup60 likes this.
  12. Paul Ceasrine
    Paul Ceasrine
    from Wilton, CT
    Yes,
    The Wenzel Brothers, 1960 Biscayne 'Sedan' was a
    348/320 HP 'Turbo Thrust Special'.
    But it was not at Dover Drag Strip.
  13. Kentuckian
    Kentuckian
    C/S 348 Chevy of Geiger and Williams ran at '64 Indy Nationals. Driven by Ron Williams from C**** Fulton, OH. Looking at the emblem in the grille, the car was probably not an original 348.
    lawman likes this.
  14. Paul Ceasrine
    Paul Ceasrine
    from Wilton, CT
    The Wenzel Brothers
    Did run a 348/320 HP in 1964 and 1965.
    D/Stock = 11.29 to 11.88 Wt/HP
    It was an 11.25 Compression Ratio engine
    with the 'optional' High-Lift Mechanical Camshaft.
    And with the Carter AFB #2897S {1 9/16" x 1 11/16" Throttle Bores},
    and advertised at 670 CFM's.
    Weight puts the car at a 'minimum' of #3616 lbs.
    lawman likes this.
  15. biscaynes
    biscaynes
    536814_10150700346615382_246208513_n.jpg 'tension '57s'....
    tension likes this.
  16. biscaynes
    biscaynes
    10433305_300858956747267_3530605792485714717_n.jpg again....
  17. loudbang
    Where was that Hawkeye Racing News from I can't remember seeing it?
  18. hemiman_1999
    hemiman_1999
    I love seeing these Junior Stockers Great Pics everyone thanks for sharing...
  19. 57peppershaker
    57peppershaker
    Thanks for posting the 2 TENSION pics, biscaynes. Do you have any more ?
    This 57 really has bitten me hard.
    Unfortunately, my 1;1 57 was finished before I came across the pics of the j/s, so I'm having to make do with a 1;25 model.
  20. 57peppershaker
    57peppershaker
    I'd love to see this rebuilt.
  21. Paul Ceasrine
    Paul Ceasrine
    from Wilton, CT
    Does anybody know what the Camshaft Specifications were
    on the 1960 Chevy 348/320 HP.
    It is listed as having a 'special high-lift' camshaft.
  22. WGuy
    WGuy
    from Central NJ
    Lift .410 I, .412 E
    duration I: 316deg E: 287deg
    lash .012 & .018
    overlap 80deg.
    This cam and heads were replaced in April of '60 and upgraded the HP to 340hp rating for '61 but continued to be rated at 320hp for the rest of '60 production. A sneaky winner if you bought one after April!
    Verne
  23. Paul Ceasrine
    Paul Ceasrine
    from Wilton, CT
    Thanks Verne,
    Chevy,,,,,,,,,always thinking !!
  24. AHotRod
    AHotRod
    More great stories and pictures, so many THANKS to all of you guys!
  25. chevy57dude
    chevy57dude
    The photo of Tension & Good In-tension gave me a good enough look to see:
    Tension's bumper bullets have been swapped for something chrome(?) that doesn't fit quite like the rubber bullets.
    -and-
    Looks like the rockets may have been removed.
    Great pix!
  26. biscaynes
    biscaynes
  27. biscaynes
    biscaynes
  28. biscaynes
    biscaynes
  29. biscaynes
    biscaynes
    more... 269150_10150231028645382_4418884_n.jpg 1004834_10152257213905027_2048868596_n.jpg
    enloe and lawman like this.
  30. Paul Ceasrine
    Paul Ceasrine
    from Wilton, CT
    Verne,
    You would know.
    Was the 409/380 HP available in the 1962 Biscayne Wagon
    with a 4-Speed.
