Technical Dash for a 29 Model A Coupe
Discussion in 'Traditional Hot Rods' started by blazedogs, Oct 31, 2014.
  1. blazedogs
    blazedogs
    The 29 Model A coupe does not have much of a dash board The front cowl is made up of the gas tank and what a person might call a dash which is not usable for gauges or much of anything.
    What can I use for a dash?.Is there another car's dash that would fit without too much fabrication or a rod shop that sells one specifically of the 29 Model A Coupe? Gene
  2. chessterd5
    chessterd5
    from u.s.a.
    I put a dash from a 1941 GMC pickup in my 1927 coupe could be close to the same. Also check out "the Mother of All Dash Thread". It has some great ideas. Someone could post a link to it from here.I would but I **** at computers. I don't even have a build thread of my own car!
  3. Model A Gomez
    Model A Gomez
    Several companies sell a 32 style dash that fits below the stock dash rail. Brookville Roadster has them for around $150, I have one in my 30 Sport Coupe.
    05snopro440 likes this.
  4. Jakesrocks
    Jakesrocks
  5. hellerlj
    hellerlj
    from Minnesota
    There is an early dash listed in the cl***ified, it is from a 29 Chevy, pretty nice
    looking dash, oval for gauges too, you might take a look
  6. hellerlj
    hellerlj
    from Minnesota
  7. Here's the dash and center console in my 31 Model A during the building process. 10170814_772784326087835_3914244836338962449_n.jpg
    kidcampbell71 likes this.
  8. Canuck
    Canuck
    34 Chevy MAster dash. Picked because of glove compartment and matching insturment area. Fairly easy install in a 30 coupe.
    Canuck
    sorry don't have a later picture or with gauges, indicator lights and stainless trim strips
  9. Just Gary
    Just Gary
    05snopro440, Adam simmons and fine29 like this.
  10. 31Apickup
    31Apickup
    Keep in mind how the ventilation system is designed to work on Model A's. When the windshield is open, the air flows through the slots behind the upper dash down the front of the dash. It works really well.
    Just Gary likes this.
  11. RICH B
    RICH B
    You can fit SW gauges in a stock '29 panel. Here is one I used in my T along with a pic of a Brookville '32 type panel we are putting in a friend's '29. It will get a SW Ensign panel.
  12. Donut Dave
    Donut Dave
    I used a aftermarket '55 F-100 insert and filled the lower part of the model A tank/dash 1928 Progress P.jpg
    05snopro440 and RICH B like this.
  13. X38
    X38
    I like the stock ones, and modified as per Rich B.
  14. Runnin shine
    Runnin shine
    Look at all that spaghetti!
    "I need my mirror boy"
    1927graham likes this.
  15. Dusty56
    Dusty56
    Me too, but then I'm using the stock gas tank so I have the original fuel level gauge in there.
  16. OzyRodder
    OzyRodder
    I cut out the stock fuel gauge to put this auburn copy in. The bottom line of the tank flows perfectly into the base of the auburn panel visually. ImageUploadedByH.A.M.B.1414935816.213997.jpg
    60'shotrod likes this.
  17. Just one wire at a time, it'll get done.
  18. Rocky
    Rocky
    Classified Editor
    I cut a 49 ford dash down for my old 29 sedan. When I sold the sedan, I kept the dash and installed it in a 33 ford pickup with no changes in width. 33interior.jpg
  19. sjrodder
    sjrodder
    from vermont
    ImageUploadedByH.A.M.B.1414937523.046747.jpg . 36 ford dash in 29 coupe.
    We sliced to flatten it then had to shorten about an inch
    60'shotrod and baspinall like this.
  20. curbspeed
    curbspeed
    Hard to find but I used a 41 Willys dash in my 29 rpu. perfect width. Get creative. I hotrod pics 006.jpg
  21. paul55
    paul55
    from michigan
  22. Metaltwister
    Metaltwister
    I narrowed this one a few inches and it fit nicely... Room for gauges and a glove box that I hade to make a new door for.
  23. Russ B
    Russ B
    this is what i am planning to use in my '29 coupe
  24. jgochneaur
    jgochneaur
    I have a nice dash from wabit dash it is wood and has holes for 5 Gage's
  25. Dean Lowe
    Dean Lowe
    If you are not going to use the stock tank, which I wouldn't, you can fit 3 gauges and the stock speedometer in the stock dash panel. I like the '29 dash panel, so I used it.
  26. Muttley
    Muttley
    Are you wiring the Space Shuttle or a Hot Rod?
    Runnin shine and 28A like this.
  27. missysdad1
    missysdad1
    I don't know the source but here's an aftermarket (I think) steel dash panel that's in my '29 Coupester. It covers a tubing framework for stiffness and is designed to be removable with just two screws, one on either end. It's clean, functional and very attractive in my opinion...but then, it's my car. Switches and other junk run vertical below and forward of the panel. Whoever did this installation was right on! week3.10.jpg
    osage orange and 05snopro440 like this.
  28. Garry Carter
    Garry Carter
    It took a bit of whacking, but I like the way an old `52 Chevy dash fit into my `30 coupe. Stripes by Von Franco. IMG_1216.jpg
    osage orange and flatty_ like this.
  29. Corn Fed
    Corn Fed
    Here's the dash in my '28. It's a 31 Cad that has been narrowed about 3" thru the center.
  30. So do you want to keep the fuel tank or are you going to cut it out? If you cut it out, the 38-39 dashes work out nice, only a little t******* at the ends and you get a glove box.
    But, that dash Rich B. posted with the SW gauges in it looked sooo-good!!
