Technical halibrand quick change
Discussion in 'Traditional Hot Rods' started by RatrodKevin, Nov 2, 2014.
  1. RatrodKevin
    RatrodKevin
    The casing on the one against the wall has a 201 number and looks older then the front one there almost the same but the front one has a square on the housing and the breathers on top on the opposite side as the other they both have the culver city cover ???the one against the wall has a crack and has bin repaired the other looks fine he is asking 1800$$ for either one is this a fair price?? in the pic. there is also a sprint car steering box forgot the name just wondering the value...thanks a lot hope to get sum info before he sells them...thanx
  2. jseery
    jseery
    from Wichita KS
    First, the Culver City covers mean nothing more than they are Culver City covers, tells you nothing about the cases. I posted some photos of mine for comparison. A repair on these may or may not be an issue, mine has several repairs. If they were being raced they are not that strong and are often broken and repaired. Not sure on the price, but I know they are not cheap and getting more expensive every day. Why do you want it? You can buy new cheaper. I wanted an original, but it ended up costing more than a new V8 quickchange would from say Hot Rod Works. If you want an original you are going to pay for it, if you just want a quickchange to drive under a Hot Rod I would go with a new one.
  3. hotrodA
    hotrodA
    $1800!?!!!! :eek:
    With repairs??
    Keep looking, or buy a new one.
  4. 383deuce
    383deuce
    I go with hotrod A buy a new one as they are better than an old one with repairs. rodsville make s a killer one like the old Hallie's but better.
  5. Pewsplace
    Pewsplace
    As Jeery stated, the real deal cost way more than a new one and may not be able to be functional. Old cases that have been abused are really not worth the $$$ unless that is your thing. Halibrand has the vintage name and looks but the new technology used by Winters is far superior for performance and longevity.
    $1800 for the welded pinion is too much in my mind. If the other one is good (inside and out) it will bring the money at the swap meets. Nothing beats the look of a QC under a hot rod.
  6. hotrodA
    hotrodA
  7. jseery
    jseery
    from Wichita KS
    Yep, if you want an original you are going to pay for the privilege.
    Update: Just checked, a Rodsville center-section with all the parts is $1695 at Hot Rod Works.
  8. hotrodA
    hotrodA
    Yep, but in 1984, they were only $75! And Culver City covers were $20! Ranks right up there with 32 stuff.
  9. Corn Fed
    Corn Fed
    I have 3 Halibrand 201 rears. 1 with the square blocks on the side, and 2 without. I think the blocks were there so you could knock a hammer against it to help loosen the cover during removal. But that's just my guess. One of mine has had the whole snout broken off and welded back on years ago. It came out of a stock car and was obviously used after the repair. So I'm not scared to use it myself. But that said, $1800 is too much for the broken one. It's probably a fair to high price for the good one though. If I didn't already have a few Halibrands and was wanting one, I'd probably just buy a Rodsville.
  10. RatrodKevin
    RatrodKevin
    thanx guys allways good help!!!good info how about the gear box??any info on that???
  11. jseery
    jseery
    from Wichita KS
    It is a sprint car type box, but I know little about them. Looks similar to the ones we ran in our sprint. But, I just bought them and installed them.
  12. hotrodA
    hotrodA
    Steering box is later model, possibly Schroeder or Norden, definitely not early model Franklin. Race car specific, normally way too fast for street application. I've seen them from $200-400, but if it's unuseable, it's a moot point.
  13. alchemy
    alchemy
    That box has a Schroeder sticker on it. You can still buy a Schroeder exactly like that, or buy one with the exact dimensions you need for your application. That are really not that expensive, especially compared to those quickchanges.
  14. Garry Carter
    Garry Carter
    Price for the steering box?? I could be a buyer if the price is right.
  15. Pewsplace
    Pewsplace
    Two NOS, Culver City units just sold for $1200 each at the Don Broyles auction last weekend. The were still in the original boxes.
    kidcampbell71 likes this.
  16. alchemy
    alchemy
    That center section in the box looks more like a Rodsville to me than a 50 year old Culver City Halibrand.
  17. chickenridgerods
    chickenridgerods
    from DSM, IA
  18. ROADSTER1927
    ROADSTER1927
  19. Pewsplace
    Pewsplace
    I would tend to agree with you but the seller said no. I don't see the 201 on the bottom ridge either. Still a good deal at $1200.
  20. hotrod_grmi
    hotrod_grmi
    Used a Rodsville on my new 32 5w build and it worked out nice.
  21. jseery
    jseery
    from Wichita KS
    Boy, folks love to through that "Culver City" ***le around!!!!!!
  22. thunderbirdesq
    thunderbirdesq
    That is definitely a rodsville, check out the beefed up support inside. Good deal regardless of the lie...
    I have a CC halibrand under my current roadster, bought it at an auction a couple years ago. It is kinda beat up looking, more than a few battle scars... I had one superficial crack in a non-critical area repaired and I paid considerably less than $1800 for it. In fact I don't even have $1800 in the whole rolling rear end.
      99.4 KB
