Projects What to do with the Hagans…?
Discussion in 'Traditional Customs' started by piraya2, Nov 1, 2014.
  1. piraya2
    piraya2
    from Sweden
    When i bought the Merc (-49) i didn't mind the Hagans. Didn't give them much tought but after reading a lot of treads here i hate them… Thanks :)
    Since i have much work left on the car the Hagans isn't my priority but i still like to do something to them without cutting to much.
    Any ideas?
  2. HOTRODPRIMER
    HOTRODPRIMER
    ' 53/54 Ford car headlight rings have a steel bezel you can cut down and weld directly to the fender. HRP
    flynbrian48 likes this.
  3. metal man
    metal man
    You can cut away some of the depth from the Hagans with a cut off wheel, so the headlights aren't set back as far. It looks better that way .
  4. Tony
    Tony
    I had them on my truck when i bought it.....one of the first things to go as well.
    I put stock stuff back on, but its a 52 chevy and i dig the stock look on them.
    Im with HRP, id get a pair of those Ford bezels and go that route. I actually used them on a 53 chevy i built a few years back.
    Gonna take a little work to put the flange back on the fender for the bucket to mount, but worth the effort in my opinion.
    Tony
  5. flamedabone
    flamedabone
    My 51 has 53, 53 Ford steel rings welded to the fenders. The trim rings are stock on the 53, 54.
    About a weekends worth of work and well worth it to get rid of those god forsaken Hagan rings. Nothing says street rod like a set of those ugly *******s.
    -Abone.
  6. flamedabone
    flamedabone
    Here is the only pic I could find.
    First, you weld the rings directly on the Merc fenders, them make a transitional filler piece to smooth it together, thin coat of bondo, and you are done. I thought there was a tech article around here, but I couldn't find it.
    Good luck, -Abone.
    flynbrian48 and dana barlow like this.
  7. timwhit
    timwhit
    Oh well here goes. What the heck is a hagan? did I just date myself or have I had a sheltered life. Tim
    Model T1 and kidcampbell71 like this.
  8. Squablow
    Squablow
    A local car has Hagans in it and I was looking at it one day. It would take some measuring but I wonder if you could just take the Hagan ring out and replace it with a different stainless ring, one that isn't dished in to cover part of the bulb. What's the diameter of the Hagan opening and what is the depth from the lip to the headlight bulb? If you could figure out what fits in there, you could be the hero of everyone trying to undo Hagans without ruining finished paint.
  9. Kinky6
    Kinky6
    Hagan is a company that makes some "street roddy" type parts. What these guys are talking about are these instant frenched light kits that Hagan sells. You should see the ones for a '39 Chevy! The ones for a Merc look like they cut the bottom out of a medium size chrome frying pan and use that as the trim ring around the head light. K6
    Model T1 and X38 like this.
  10. 49ratfink
    49ratfink
    I don't think there is any way to fix those stupid things other than cutting them off and doing it right.
  11. tommyd
    tommyd
    from South Indy
    Great car!!!^^^^^
  12. headlight rings.JPG here is the stock ford/merc units. I hate the hagans
    here is an aftermarket merc "copy " attempt but looks better than hagans
  13. K13
    K13
    The aftermarkets one no longer come with the inner stainless trim so one really needs to find originals these days.
  14. retromotors
    retromotors
    You're not alone, Tim. I didn't know what the hell they were talkin' about either!:eek:
    kidcampbell71 likes this.
  15. arkiehotrods
    arkiehotrods
  16. upload_2014-11-2_9-48-32.jpeg here's a shot of the hagan frenched headlight UGLY!
  17. Unkl Ian
    Unkl Ian
    A couple minutes with a BFH will make them look a lot better.
    Muttley likes this.
  18. clean cut creations
    clean cut creations
    That Hagan junk needs to go straight in the trash......
    I use these from Speedway
    They are trimable and when installed look just like the '53/'54 for rings on the merc above.
    Just got done installing a set on a '48 Chrysler Windsor coupe.
  19. Kinky6
    Kinky6
    Yeah, that's the chrome frying pan look that I was describing. Gross!
  20. metal man
    metal man
    Man, those are ugly. The rings in post 13 are what I THOUGHT you guys were talking about , that can be trimmed to look decent.
    Those Hagans are beyond help.
    If you can't find a pair of the Ford rings, the Speedway kit above looks alright to me.
  21. Muttley
    Muttley
    The kind of guys that have those on their cars can usually be seen roaming the local car show wearing a Hawaiian shirt & socks W/sandals combination while carrying their wifes purse.
  22. atomickustom
    atomickustom
    If you really don't want to cut them out and put in something else (like the cl***ic '52-54 Merc rings and bezels), your only hope is to find a convex rather than concave stainless or chrome trim ring that will mate to the inner diameter of the fender opening. I think you're going to have to either take some very careful measurements at the next swap meet you hit OR buy a lot of rings until you find something that works.
    Start by trying the '52-54 Merc.
    In fact, I have a couple laying around. Measure your fender opening carefully and if it seems like one might work I'd be willing to send you one to try if you'd like? I can't imagine it would cost more than a couple bucks to ship one?
    If it works you will be the hero of everyone with a Hagan-equipped car!
  23. piraya2
    piraya2
    from Sweden
    This is what it looks like and it me***ures 200 milimeters across.
  24. SicSpeed
    SicSpeed
    from Idaho
    Hahaha , rich , so true. And a lowered Caprice Wagon daily
    Posted using the Full Custom H.A.M.B. App
  25. atomickustom
    atomickustom
    I'll measure my rings when I get home from work tonight and post tomorrow to let you know.
    It looks like the distance from the front lip to the actual bucket is very shallow - you will have to do some t******* even if the diameter is correct.
    If the '52-54 Merc rings don't fit then maybe '54 Ford will. They are very shallow.
  26. San_Jose_Speed_&_Chrome
    the 54 ford units are 3 inches long or so, and they are cast pot metal at least on mine. they were a pain in the *** to install. the 53 merc rings are what you are after. 52's are more rounded. 53's are a little longer with less round . 54 fords again are cast pot metal, and a major pain in the *** to do, im not sure on what 54' merc's are like if i remember correctly they are like the 53' merc... the picture is of my 54's fender with the stock 54 ford bezel.
  27. 50 customcoupe
    50 customcoupe
    Anybody ever try using the rings from a '76/77 Chrysler Cordoba ? They look like they may fix. I had never tried one but always wandered if they would fix the Mercury rings. Just a thought.....
  28. Shamus
    Shamus
    from NC
    These are Mercs done the traditional way.
    They are just as ugly as the Hagens.
  29. Oooops. .. I just burped a little vomit in my mouth!
  30. atomickustom
    atomickustom
    I am talking about just the inner trim ring, NOT the entire bezel!
    We're trying to find a stainless or chrome trim ring that will fit the headlights he already has mounted on his fenders.
