Technical Chevelle "Torque Strap"
Discussion in 'The Hokey Ass Message Board' started by Byers, Nov 6, 2014.
  1. Byers
    Byers
    Not sure of the right name for this. It came off of a 1971 Chevelle. He says they called it a Torque Strap, but I can't find any info on a Torque Strap. He says it bolted to the frame and went over the motor mount to keep it secure when the engine is really launching.
    Here's a pic:
    Any idea of the Technical Name for it, I'd appreciate it. I'll like any good comments!!!
    volvobrynk likes this.
  2. Byers
    Byers
    Nevermind... I guess it's an aftermarket recall part. Was put on by the dealer to prevent the engine from going crazy if a motor mount gets broken.
  3. squirrel
    that's right.... the original design motor mounts didn't have anything to limit movement, and it was a big problem when they broke, and the engine raised up, and held the throttle open. that was in the days before cable operated throttles, you know
    volvobrynk, lothiandon1940 and Byers like this.
  4. Mike51Merc
    Mike51Merc
    There were some problems with Chevy motor mounts back then. My dad had a '70 Impala wagon. One day the motor mount broke, the engine tilted, and the throttle went WOT.
    Byers likes this.
  5. 270283
    270283
    The more permanent cure was sidemounts that interlocked if the rubber pad separated. I had the torque strap on my Camaro in 1968.
    Byers likes this.
  6. Byers
    Byers
    Other names: Anti-Lift Bracket, Stop Bracket
  7. bobss396
    bobss396
    There were a couple of different types of straps, the ones for the Belairs, etc were a bit different. My dad had a '68 Impala wagon with a 327 and TH400 that we beat the snot out of.
    It broke a mount on me... nailed the throttle wide open and pulled the hose out of the brake booster. I was very glad that there wasn't anyone close in front of me. I guess dad missed the recall somewhere. I got a mount for it, the new safety type.
    volvobrynk and Byers like this.
  8. My uncle's '68 Impala 325hp 396 had one.
    Byers likes this.
  9. lothiandon1940
    lothiandon1940
    I've often used one of these.:) th.jpg
  10. aplayer
    aplayer
    Ditto. had a chain on my chevelle. My kid thought it was pretty cool.
  11. 1lucky1
    1lucky1
    from Morgan NJ
    My 66 Chevy ll 283 wagon has one and a smog pump!
  12. Don's Hot Rods
    Don's Hot Rods
    from florida
    My 64 Impala kept breaking distributor caps and I couldn't figure out why. So one day I had a buddy brake race it and I watched the motor come up on the drivers side and the distributor smacked the firewall. Chevy had a recall and added that mount to fix the problem.
    Don
  13. Atwater Mike
    Atwater Mike
    I had a chain strap on my F100 after breaking 2 Chevy engine mounts...then redesigned the mounts.
    Now, it's... "F100! Unchained!"
  14. txturbo
    txturbo
    My 427 impala did it one day.....and that was one of the rare times the tires hooked up and I almost rear ended a mini van. Sure was wishing someone had installed one of those on my car at that point.
  15. pdunn10
    pdunn10
    We run a bolt throught the sbc motor mount with a double nut on the one side its loose but holds if the mount fails
