<><>Ladder Bar Picture Thread<><>
Discussion in 'The Hokey Ass Message Board' started by BloodyKnuckles, Mar 15, 2009.
  1. 1971BB427
    1971BB427
    from Oregon
    And here they are under the car:
  2. granny
    granny
    from WA state
  3. granny
    granny
    from WA state
    The T/A's i make are used on cars that have the rear located by links (not leafs), so we have very little fore/aft movement of the linkage as the suspension goes thru it's travel. We've had as good as 1.3sec 60' times with one, but if the car has that much power, the tunnel's gonna need some reinforcing ;)
    Handles nice and goes straight, but goes around corners too.
  4. CalGasser
    CalGasser
    I like the idea of a shackle in the front in lieu of a slider at the housing, especially if you have a car already together.
    My questions is has anyone tried this shackle setup on the track? :confused: I'd think under load, there'd be a lot of action going on and a lot of stress. Theory is good but would love to hear some actual proof. If you've done this, how thick material did you use for the shackle? Thanks!
  5. langy
    langy
    Neither will them being parralel and mounted so far apart i'm afraid.
  6. granny
    granny
    from WA state
    The shackle plates are 1/4". I've been building these solid axle TA conversions for years, to replace the IRS in customer '86-'91 Maxda RX-7's. Use one in my personal OT street/strip car too..5500rpm clutch dumps, drag radials, trackbited/gold dusted tracks... http://grannys.tripod.com/20102.html
  7. CalGasser
    CalGasser
    Thanks Granny, beautiful job on the RX-7! Vic
  8. grantzky
    grantzky
    from toronto
    why are all these ladder bars pointed up so high?
  9. grantzky
    grantzky
    from toronto
    use the trans mount crossbar for the forward mount
  10. BloodyKnuckles
    BloodyKnuckles
    Any new pics??
    ******Knuckles
  11. edweird
    edweird
    yep, thems some laddddddddddddddder bars.
  12. manyolcars
    manyolcars
    I dont have pictures but with my transverse spring, I made ladder bars out of black pipe and attached them under the tail of the transmission with a large heim. 1935 Ford, 350/350
    For the guys who insist that you gotta use chrome moly, I will point out that I seriously overstressed the bars on the street and they have held up for 20 years now
  13. Hamtown Al
    Hamtown Al
    These came on my car. They bolt to same bracket off the frame that has the rear of the front radius arms. Been that way since 50s to early 60s.
  14. bowtie40
    bowtie40
    You're right! S/S Ford teams used them back in the early 60's. They were more of a "reverse traction bar" and seemed to work quite well. The F/X Fords used the ladder bar style. They were rectangle tubing that were fairly long, about 48" I think they used a shackle up front to stop the bind. bowtie40...
  15. That thing is AWESOME!!! :D
  16. Tudor
    Tudor
    from GA
    WOW - That is one bad MF! Love it.
  17. Utahvette
    Utahvette
    sucp_0701_06_z%201955_chevy_210%20wheels.jpg Heres a shot of My 55
  18. hotroddonnie
    hotroddonnie
  19. 3kross
    3kross
    Alliance Vendor
    from Adrian, MO
  20. cs39ford
    cs39ford
    Heres mine that were made in the mid 1960s on my 56 chevy IMG_3611 (200x133).jpg
  21. SmokinBill
    SmokinBill
    One of the million sets of Lakewoods. Did'nt have shackles or floaters and they were binding. So I changed to the *******s
  22. Utahvette
    Utahvette
    57 under.jpg 570001.JPG Pic of my Vette
    loudbang and Max Gearhead like this.
  23. Special Ed
    Special Ed
    Those "welds" are truly scary. I'm not talking about their appearance alone either, but by the looks of 'em, I see inadequate penetration. They need to be repaired...
  24. Bean Dip
    Bean Dip
    I'll get right on that slick
  25. Special Ed
    Special Ed
    This is what a decent and SAFE weld should look like ...
  26. gimpyshotrods
    gimpyshotrods
    I have been a master mechanical engineer for 20-years, a certified pro welder for 27-years, a welder for 36-years, and most importantly a welding inspector for 15-years.
    Your welds are not safe. You are placing yourself, and everyone around you in danger, for the sake of foolish pride.
    Hurling insults is the behavior of a small man.
    Rise above, and fix your welds.
    gwhite likes this.
  27. DeucemanLt1
    DeucemanLt1
    And you think someone will buy your "production" trash.
  28. gimpyshotrods
    gimpyshotrods
    What sanctioning body has accepted these welds in a tech inspection?
  29. gimpyshotrods
    gimpyshotrods
    I will call the local inspectors in your area, on Monday, and ask that your safety certification be audited.
  30. saltflats
    saltflats
    from Missouri
    I have first hand seen those pretty welds brake on ladder bar brackets welded to a rear end housing at the track.
    And I have seen welds that don't look pretty that you could not jack hammer apart.
