Technical 350 SBC Starter
Discussion in 'The Hokey Ass Message Board' started by 40Ford77, Nov 8, 2014.
  1. 40Ford77
    40Ford77
    from Louisa
    I have one of those 350's sbc that does NOT have the third hole for the starter. I'm changing from an auto 168 flexplate to a 153 pressure plate. Need a starter that is angled, but works on a 153 toothed flywheel. Who makes such a beast" The standard mini starter that is a straight bolt pattern has no hole at the back.
  2. BOBCRMAN
    BOBCRMAN
    from Holly
    Aftermkt (Hitachi type) race style mini starters will work well. Two bolt patterns with an exposed drive pinion.
  3. squirrel
    good luck...I think the staggered hole is kind of in the way of the starter motor, so it won't get close enough to the center of the block. If you are careful, you could drill the extra hole. Maybe we could give you dimensions?
    BORRACHO13 likes this.
  4. dave lewis
    dave lewis
    from Nampa ID
    I have a drill fixture that I bought from an automotive machine shop supplier..
    You are welcome to borrow it. .
    Pm..or call me @ 831-262-7294..
  5. 40Ford77
    40Ford77
    from Louisa
    Thanks Bob ... any idea who has them?
  6. 40Ford77
    40Ford77
    from Louisa
    Thanks, will call in the PM.
  7. Frank Carey
    Frank Carey
    I put one of the ministarters on my sbc400 and was surprised that I had to drill and tap one hole in the block !!!! This was with the engine in the car. Pain. But everthing works well.
  8. Phil1934
    Phil1934
    I also drilled for small flywheel. Only way as no staggered bolt starter for this.
  9. 40Ford77
    40Ford77
    from Louisa
    Ya'll have the corner on smarts, as I can not find such a beast. Looks like the drill is the only way.
