Projects What!!? another 27 on 32 chassis!??. Scratch build body.
Discussion in 'Traditional Hot Rods' started by Mindover, Jun 5, 2011.
  1. Mindover
    Mindover
    from England
    Cheers Louis, When I took on the extra workshop space I had to spend time on that and it put me behind with my customers work so I could not spend much time on this. I am still busy as hell but can get some time in on this now. more to come soon.
    David
  2. Mindover
    Mindover
    from England
    Following on from the photos on the last page here is the almost finished bun panel...
    Inside...
    Just a little tweaking from here, and I have to dress the weld.
    David
    the metalsurgeon and bct like this.
  3. T27owner
    T27owner
    from Nebraska
    You do amazing work, great progress! Maybe next year I can get back on track.
  4. K13
    K13
    Thanks for the update David. Great work as always!
  5. bambbrose
    bambbrose
    from So. Utah
    Work of art, wish you could make me a set and ship to US. All I can find are panels in worse shape than your template panel
  6. I'm impressed. You know that because I have told you at least a half dozen times already. Less concerned with what you have done and more interested in where you are going. If you have to chose between updating and pounding tin, I hope you will pound tin. If you have to chose between recapturing old images and posting new ones, I would prefer new ones. But mostly, I like opening up the HAMB and finding a fresh post on this thread from you at the top of the forum. Always interesting. Always inspiring.
  7. Mindover
    Mindover
    from England
    Thanks, I really want to get this moving on now.
    I could do that but the cost might be prohibitive. I am going to make some more I will show how I get on.
    Thank you you are kind. Thanks for taking the time to comment. I usually post on here while watching tv. It's uploading photos that takes time.
    David
  8. Mindover
    Mindover
    from England
    I used a clamp to put the turtle deck panel I made together with this bun panel to check the fit. The top of the turtle deck panel is slightly wrong and when I checked the buck I realised that a chunk had fallen off. It has been knocking about for a lot of years. Simple enough to sort out.
    David
  9. Mindover
    Mindover
    from England
    Here's another shot. I had to clean a load of rust off the turtle deck panel for these shots, I am going to have to put everything in primer to stop it getting worse.
    David
  10. Mindover
    Mindover
    from England
    One more photo o found.
    I am going to knock up the inner wheel well section soon. Then make the rest of the turtle deck.
    David
  11. bambbrose
    bambbrose
    from So. Utah
    What gauge metal are you using for all of these panels? I couldn't recall if I saw it elsewhere in your thread.
  12. Mindover
    Mindover
    from England
    I use one mm which is pretty close to 19 gauge.
    David
  13. bambbrose
    bambbrose
    from So. Utah
    Thanks David. Looking forward to more pictures as always. Curious if you are going to fabricate internal bun panel brackets that are just like factory as well.
  14. Mindover
    Mindover
    from England
    Yes I am. The idea is that it would be hard to to tell this from an original once I get it done
    David
  15. 64 DODGE 440
    64 DODGE 440
    from so cal
    It's already far nicer than the original.
  16. stephane-rod
    stephane-rod
    from france
    Beautiful works metal ;-)
  17. Mindover
    Mindover
    from England
    Thanks very much guys. It good to be progressing on the car again.
    David
    sko_ford likes this.
  18. Mindover
    Mindover
    from England
    Here is a close up of the welded joint...
    David
  19. Mindover
    Mindover
    from England
    ...and this is the inside of the welded area, no planishing or dressing had been done when these photos were taken.
    David
  20. 64 DODGE 440
    64 DODGE 440
    from so cal
    Beautifully done David.
  21. King ford
    King ford
    from 08302
    Thanks a bunch for posting.....VERRY good fabricating lessons
  22. Mindover
    Mindover
    from England
    Thanks Tom.
    No problem, thanks for taking the time to reply.
    David
  23. alchemy
    alchemy
    I love seeing the progress on this car. Please keep posting lots of pics, as I learn every time I look. I'm building a '26 T as well and it needs almost as much panel replacement as you are creating from scratch.
  24. 1952B3b23
    1952B3b23
    from Western MA
    I know this has been said a bunch of times before but your skills are amazing. I enjoy reading this thread and learning from your posts, thank you. Also i've watched your YouTube video and its great. Really inspirational and informative for a novice metal man like me. Thanks again.
  25. Mindover
    Mindover
    from England
    I have a few more photo's of the making of this panel I will post soon. I started making the tooling for the inner wheel well panels today.
    I have four youtube videos but I think you are talking about my DVD. I am glad you liked it.
    Thanks for your comments guys
    David
  26. Looks great David! ( I knew it would, ha!)
    Cheers!
    Mike
  27. 1952B3b23
    1952B3b23
    from Western MA
    I actually don't have your DVD but the you tube video i was talking about was the one you provide the link to in your signature. I didn't know you had others, i would like to watch those.
  28. Mindover
    Mindover
    from England
    Here are the links to the other three
    David
  29. fab32
    fab32
  30. 1952B3b23
    1952B3b23
    from Western MA
    Thanks for posting those links David.
