Has anyone here modifed a header to use on a 153? I know clifford offers one but I am not sure I am willing to ponie up the 350 bucks yet. A small block header looks damn close and some have a 1 1/2 primary so that would be perfect. Anyone here done this?
I tried one from Clifford years ago in my otherwise stock '32 with a '39 trans. It didn't clear the front wishbone. Good thing I took it with the understanding I could return it if it didn't fit. A nice thing about the stock exhaust manifold is that it heats the bottom off the intake manifold to help vaporize the fuel when used with a stock intake. I am currently running a Clifford intake with a stock manifold blocked off at the top. The stock intake ran better for a street car. If you are going to be building build manifolds it might be a good time to consider an eight port head from the 181 Mercruiser. Charlie Stephens
I am not planning on using the 181 head. I just revalved the stock head with 1.94 Intake 1.65 Exhaust. I am using a clifford intake with the water running though it to help with vaporizing the fuel. The stock exhaust manifold will be way to restrictive now, but 350 for 1 none coated header is steep. I have fitted a SBC V8 header and the spacing really is close. Didn't know if anyone has tried and had a experiance to share to aid me along my way with modifing one.
I made a lakes style header for my old track roadster. Bought a flange from Hearders by Ed, a megaphone and a cheap pair of sbc circle track headers and cut one up and sold the other one.
OK, Here's what I'm doing. There will probably be a dozen of these around before mine hits the road just remember where you saw it. With minimal cutting, welding, and port work this will be great! It's for the 153 with a 181 crank that's going in my '26 Chevy roadster. https://picasaweb.google.com/sixpic...&authkey=Gv1sRgCMWRsJTGnNfHRQ&feat=directlink
I'm working on this... http://i163.photobucket.com/albums/t307/nostalgia59/1927 modified/100_0261_zps3fbf18c1.jpg http://i163.photobucket.com/albums/t307/nostalgia59/1927 modified/100_0263_zpsd08aa2d0.jpg http://i163.photobucket.com/albums/t307/nostalgia59/1927 modified/100_0262_zpsfea7331b.jpg
Charlie, Thanks. I need to get off my duff and get the exhaust header done so I can get the engine ***embled and sitting in the rails. I like your build. I wish mine was that far along. Larry, What do you want for the manifold? Nostalgia, That looks like a fun project. I'd like to see more pictures of the adaptor and for sure the 2X2 Offey. Some day I want to build a duel Weber DCOE setup.
There is a newly designed finned valve cover for 153s on eBay. I think there are some finish options. http://www.ebay.com/itm/282120340260?ssPageName=STRK:MESELX:IT&_trksid=p3984.m1555.l2649&rmvSB=true
