1946 & 1947 Studebaker Trucks M5
Discussion in 'The Hokey Ass Message Board' started by juddvh, Nov 26, 2012.
  1. juddvh
    juddvh
    I just bought two Studebaker Pick up trucks. A 1946 M5 and a 1946 M5. I have attached a few pics of the trucks. The green truck is pretty solid. However the blue one is pretty rough. I am looking for a cab and running boards. If anyone has parts to sell or knows where I can find them, give me a shout out or point me in the right direction. The trucks are rough but I haven't even started on them yet. 2012-11-15 10.42.28.jpg
  2. Normbc9
    Normbc9
    A local in my area is a Body Technician and is now working on his grandfather's '47 M-5. I thought you'd appreciate what coud be if you are so inclined. Those were sturdy and reliable trucks.
    Normbc9
    kiwijeff likes this.
  3. bstie
    bstie
  4. juddvh
    juddvh
    Thanks for the pics Norm. I am so excited about these trucks that I can't wait to get my hands on them. I am new to the HAMB. I'm hoping that it will lead me to some replacement parts that I need. Thanx again for the cool pix.
  5. juddvh
    juddvh
    Bstie,
    I was surprised when I got the hood popped and found a small block ford v-8 under it. Unfortunately, the intake manifold and carb were stored in the cab and the block and rods etc are rusted tight. I was planning on trying to find a 289,302, or 351 that I can easily slip into the green truck. The blue truck is a bigger project and I am thinking something similar to your truck. I am initially planning on getting more modern suspension and brakes. Probably will lower it like you have done. I like your truck. What do you have under the hood?
  6. bstie
    bstie
    Thanks, I have a small block chevy stroked to 383 and a t400 trans. I have air ride installed on the original ch***is. Lots of parts show up on the auction sites but they command big bucks. I have been looking for a decent pair of fenders for a long time finally ended up with the fibergl*** ones on the rear until I can find good steel ones. The green M5 looks pretty decent there are patch panels out there for those cab corners and cab floors too. I am trying to put together a build page for my truck to post here Just taking longer than I hoped. Good luck with those!
  7. bstie
    bstie
    Welcome to the HAMB! you will find a ton of good information here.
  8. callen65
    callen65
    from mo, usa
    Hi guys. New here.
    My son and I are starting a 41 m5 project and we plan on keeping the little 6 but want to build it a little. I saw the pic above with the finned head with Studebaker on it. One of those would be cool! Know of any good sources for speed parts for the Champion 6?
    Also want to lower it and keep the straight axle. But its lookin a little harder than you might think. Any suggestions?
  9. callen65
    callen65
    from mo, usa
    Its his truck and I will be helping him!
  10. Love to have one for a shop truck
  11. Good score! Parts are a little hard to find, but it looks like you have a pretty good start with the green one. Lower it, skip the boards, and turn the rear fenders around. It's all they need! A little chop works too ;)
  12. 46stude
    46stude
    Studebaker Truck Talk:
    http://www.network54.com/Forum/23885/
    Be advised- many there are Stude purists. There are alot of hot rodders, too. But you won't find a more knowledgable group that knows old Studebaker trucks better.
      130 KB
  13. Locomotive Breath
    Locomotive Breath
    from Texas
    Nice score, welcome to the HAMB. I just recently picked a '48 M15 1 ton pickup that will be my shop truck soon.
  14. Ranunculous
    Ranunculous
    If you see front grill pieces grab em! They're the hard parts to get!
    I need window pane-to-wing window chromed divider bars if anyone has any!
  15. Old thread, I know, but I need some info.
    Just bought one sight unseen.
    Need to grab a couple of wheels to move it.
    Can anyone tell me what is the wheel stud pattern (PCD) ?
    off to pick it up soon.
  16. Reverborama
    Reverborama
    from Minnesota
    Should be 5 on 5.
  17. john mullen
    john mullen
    hears mine after 4 years working on it .getting close now..
  18. 46stude
    46stude
    Lug pattern is 5 on 5. Same as the GM trucks and many GM big cars.
  19. bstie
    bstie
    Be aware one side is right hand lugs the other is left hand lugs brine a set of each,
  20. bstie
    bstie
    Bring
  21. Thomas 13
    Thomas 13
    Is that the original frame or did you change it to lower it? I have a 1947 M5 that I'm interested in lowering and was curious about how to go about it.
  22. rusty1
    rusty1
    ...here's my nephew's 48 Stude, we installed a 72 Nova clip and S-10 rear springs with a Nova rear,....motor/trans, etc. coming this Winter... jims 48 stude build 070.jpg
  23. So did you get it?
    Haven't seen anything on local forum.
    There's a couple floating around my neck of the woods, but you don't see em much.
  24. john mullen
    john mullen
    The frame is S10 extended cab that was shortened to 115 inch's it has air ride kit installed to lower it
  25. Thomas 13
    Thomas 13
    Thank you! And congratulations, one of the best looking Studebakers I've seen yet!
  26. Slopok
    Slopok
    The Front & Rear Fenders are the same and interchangeable. Pretty neat.
  27. john mullen
    john mullen
    I had no stock rear fenders or a bed so I made the bed side's and tail gate.. I used rear fenders from a 52 Chevy truck... Both the front and rear fenders were cut to match the radius of the tire.. The rear fenders were widened 3 inch's I used 4 fender's to make 2.. Thanks for the complements ...John
  28. 37jimmy
    37jimmy
    from kentucky
    I hope someone can post some photo of a lowered front end using the original front axle. Would like to see some options.
