1950 Mercury ReChop
Discussion in 'Traditional Customs' started by 53chevtrev, Aug 14, 2014.
  1. lil runaway
    lil runaway
    from Wisconsin
    Heres My Merc that was just finished 20141017_160816.jpg 10390184_636899549720856_5908001339668869980_n.jpeg
    justntime likes this.
  2. Dragginwaggin
    Dragginwaggin
    from Canada
    Good times today, glad I finally met you Trev. You've done some really nice work. Looking forward to next time.
  3. Graveyardsaint1
    Graveyardsaint1
    Kool... Nice work
  4. Zed
    Zed
    from FRANCE
    this is work of art...as ever :D
  5. 53chevtrev
    53chevtrev
    from Langley BC
    Started the non exciting work of replacing the entire package tray in the merc. In the initial chop, the sliced through the middle of it from end to end and only re welded the center section. Also the hinge mounts weren't braced and were out by over an inch when we tried to mount the trunk hinges back into the car. It also wasn't shortened so it sloped towards the back. Needless to say this wasn't gonna cut it so we cut it out. I got a replacement tray from the merc owners collection of 4 door parts cars. I blasted it then started the modifications to make it work. I had to section it and cap where the hinge mounts were set back to line up properly. Ran outta argon so couldn't finish it. Next time.
    ImageUploadedByH.A.M.B.1415575403.698042.jpg ImageUploadedByH.A.M.B.1415575424.581680.jpg ImageUploadedByH.A.M.B.1415575577.578656.jpg
  6. 58 Delpala
    58 Delpala
    from NC
    Hate running out of Argon. Looks good though. Keep it up.
  7. 53chevtrev
    53chevtrev
    from Langley BC
    Got my bottle filled today and was able to wrap up the package tray modifications. Fits great and retained the factory look for the most part other than the recessed hinge pockets. Belt line area is next and then should be wrapping this chop up soon after.
    ImageUploadedByH.A.M.B.1415666989.004976.jpg ImageUploadedByH.A.M.B.1415667004.153327.jpg ImageUploadedByH.A.M.B.1415667023.106405.jpg
  8. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Looks really good Trev.You have done an amazing rescue. Following this with great intrest since I´m about to start on a 50 Merc soon .
  9. straykatkustoms
    straykatkustoms
    You have done a great job getting the Merc right. I'm looking forward to watching the progress.
  10. 53chevtrev
    53chevtrev
    from Langley BC
    Started the belt line surgery today. Cut out all the old metal and started fitting the donor sections I pulled out of a four door parts car. Pieces need to be re shaped and run through the shrinker a bit.
    ImageUploadedByH.A.M.B.1416096115.958671.jpg ImageUploadedByH.A.M.B.1416096132.126300.jpg
    shoebox1950 and hacknwhack like this.
  11. 562roadster
    562roadster
    Wow! Great work!
  12. 53chevtrev
    53chevtrev
    from Langley BC
    Thanks man!
  13. 53chevtrev
    53chevtrev
    from Langley BC
    Bunch of progress today on the merc. The top trunk gap was way off so spent the morning getting the gap right before I went ahead with fitting the drivers side belt line panel. Got it all tacked in and also started re shaping the p***enger side to sit right.
  14. Mr48chev
    Every time I check in on it this just gets better and better. Along with the great eye for getting the look right the attention to the little unseen details that turn a cool custom into a spectacular custom.
  15. 51 Leadsled
    51 Leadsled
    from NC
    Your first chop! Nice work, even if you been doing the for years, very clean lines. A mixture of art and funtion, and that is rare!!
  16. 53chevtrev
    53chevtrev
    from Langley BC
    Thanks man, really appreciate it!
    Thanks. This is my second chop, first by myself. I chopped my 53 with my friend Jay. Really stoked on the way this car is starting to look
  17. kidcampbell71
    kidcampbell71
    You think by your third chop, you'll know what you're doing ? :) Unbelievable man. I can't even talent-ly chop into a soup can, at my thousandth try already. Beautiful, just beautiful.
  18. 53chevtrev
    53chevtrev
    from Langley BC
    Got some evening work on the merc last night and re shaped and fitted the p***enger side belt line.
  19. Deucecoupe
    Deucecoupe
    Beautiful work. 1st cl*** all the way. It's an art form.
  20. 53chevtrev
    53chevtrev
    from Langley BC
    Worked on getting the p***enger side belt line tacked in and everything hammered and ready to weld. Ross came over to check out the progress and we rolled the car outside for a look at the end of today. Super happy with the new belt line.
  21. Slopok
    Slopok
    Don't know if you had anything to do with it but I like the way the tailpipes come outa the bumperettes.
  22. Kenneth31coupe
    Kenneth31coupe
    from Sweden
    Wow Trev. Came out perfect and you have all the reasons to feel happy. Do you have any idea of how much the chop is? Looks quite heavy in the pics.
  23. 53chevtrev
    53chevtrev
    from Langley BC
    I did not install or do the initial work on the kaiser over ride. However I will be smoothing and metal finishing it for chrome later after the chop.
    Thanks ken. As I didn't do the original chop I am unsure how much it has been chopped. Once I get to chopping the garnish moldings I should have a better idea of how much was taken out. I'll let you know. Chop is as heavy as I would ever go on a merc.
  24. 53chevtrev
    53chevtrev
    from Langley BC
    Today was filled with lots of welding and a bunch of hammering. Got the belt line completely welded and ready to be dressed and finished. Close to 16 feet of TIG welding in the belt line.
    drdave likes this.
  25. drdave
    drdave
    …and for good reason. It looks fantastic!!
  26. 117harv
    117harv
    Been following along, to say your work is outstanding hardly seems adequate, maybe auto art would be better. There so many sheet metal masters here on the HAMB, thanks to all of them for taking the time to do***ent and share!
  27. 53chevtrev
    53chevtrev
    from Langley BC
    Thanks man!
  28. 53chevtrev
    53chevtrev
    from Langley BC
    Started finishing the belt line tonight. Long way to go still but got a good start.
  29. Dragginwaggin
    Dragginwaggin
    from Canada
    Looking good Trev.
    I think you left the garage door unlocked again, Ross isn't going to go home if you keep doing that. He's just like me ;)
  30. 53chevtrev
    53chevtrev
    from Langley BC
    Finished the belt line yesterday. Roof is almost finished. Need to adjust the radius'd door tops as I'm not happy with the flow into the quarter windows then onto garnish moldings.
