Technical 4 speed in a Model A
Discussion in 'The Hokey Ass Message Board' started by sdluck, Nov 17, 2014.
  1. sdluck
    sdluck
    I have a 29 model A gl*** car with a recessed firewall it has a SBC with A turbo 350,I purchased a t-10 from a 63 vette I want to put in there.Where can I get the pedals and brackets to put this in the car.Any Information would be helpful. Thanks
  2. sdluck
    sdluck
    Cool,I will check it out.
  3. madmak95
    madmak95
    Not a lot of room in an A frame. I took out a 4 speed and went with the T5 because i couldn't get the shifter in. And the fact that i get OD.
  4. Babar40
    Babar40
    from Florida
    Nice set-up madmak, I think that is what I would do. The 4 speed may necessitate some crossmember modification.
    Of course try to mock up the 4 speed first.
  5. Countn'Carbs
    Countn'Carbs
    from CO
    Another option is a set of hanging pedals with the early M/C on the firewall. I've always liked that look on a traditional car plus it frees up pedal space as it can get pretty tight when they come thru the floor.
    Cory at Rjays (Alliance Vendor) has a great setup
    http://www.rjays.com/RJays_Traditional_Parts/brake & clutch-02.htm
    3kross likes this.
  6. Countn'Carbs
    Countn'Carbs
    from CO
    Also...what are you planning on running for a bell housing?
  7. mwhistle
    mwhistle
    from sacramento
    I built my own many years ago. It's all mechanical linkage and works well. However, as Chopsaw said above, if you can buy a quality set up, it is worth the time and effort you'll expend making your own.
  8. sdluck
    sdluck
    The recess firewall doesn't look like it gives room for another master.With this engine (very mild) I was going to try a stock bellhousing,with the other engine I have a ****tershield.
  9. sdluck
    sdluck
    Anybody else?
