Technical What makes the best metal top fill metal?
Discussion in 'Traditional Hot Rods' started by bartmcneill, Nov 16, 2014.
  1. bartmcneill
    bartmcneill
    from Ada, OK
    I plan to fill my 1930 Model A coupe top. What donor car has the best looking metal for the top? Some like smooth, some like ribbed. I have not decided yet. Opinions..........
  2. Hot Rod Rodney
    Hot Rod Rodney
    from USA
    1982 Buick has the perfect compound curvature.
  3. manyolcars
    manyolcars
    I would be rich if I had a nickle for every time this has been asked. Search!
  4. Texas Webb
    Texas Webb
    Measure yours...Go to junk yard,battery sawzall-circular or jigsaw.And try to use 60's or earlier metal.
  5. fine29
    fine29
    from Des Moines
    I used a 1966 mustang roof panel turned around backwards. ImageUploadedByH.A.M.B.1416195260.474726.jpg ImageUploadedByH.A.M.B.1416195289.774916.jpg
  6. volvobrynk
    volvobrynk
    from Denmark
    Roof of a OT jeep charokee, If you wants ribs for her plessure.
    Volvo 240/245 roof do work too.
    But most roofes with a slight curb can be made to fit
  7. bartmcneill
    bartmcneill
    from Ada, OK
    Thanks for the help. Did a search, still did not find what I was looking for which is a bunch of pictures that will help make a decision of what to use.
  8. olcurmdgeon
    olcurmdgeon
    I built this A coupe some years ago, now owned by Cam from the Ringwreckers. I used the hood panel from a '62 Chevy, told people the two raised ribs were for "lateral stability" at high speed! Actually someone had cut the panel out of the hood at a local s**** yard in So. Maine and it was lying there and turns out it worked good. 036.jpg
    dana barlow and volvobrynk like this.
  9. boutlaw
    boutlaw
    I used a Maverick roof turned around backwards, fit perfect. Mustang roofs work as well. Got it at pull-a-part for something like $20. You can also use the stiffener across the center of the roof, shortened on the sides like the roof panel, to mount an interior light if you happen to want an interior light in your hot rod.
  10. theHIGHLANDER
    theHIGHLANDER
    I like the long/short grain materi...oops, flashback. Sorry...
  11. 1947vert
    1947vert
    from Minnesota
    When I filled the roof on my 35 Ford 5 window I made a template front to back and side to side of the profile. Headed to French Lake and it turned out to be an 80's Chev Monza that fit the bill. Good l
  12. Jeff Norwell
    Jeff Norwell
    MODERATOR
  13. Weezy1930
    Weezy1930
    from OHIO
    There seems to be many options listed here. Here's one more: My friend was told to use a mid-70's Camero roof and he got great results with it. Real nice fit with the smooth look.
  14. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Also…. (if you can find one) a 58 Ford wagon roof will work well too. very nice factory ribs.
  15. ClarkH
    ClarkH
    Last year my brother and I picked up a '29 coupe that had been filled. The guy said the panel was from a Pinto wagon.
  16. Mr48chev
    Reading down that list I'd say it's what has close to the right shape the day you go to the do it yourself yard that will let you cut a roof out or off. I've got two friends with wrecking yards that will let you cut pieces like that off cars in the "crusher row" real cheap.
    Cutting a couple of templates out of something stiff enough to carry around and set on roofs helps a lot too.
  17. Falcon wagon or if you like ribbed late '50s GM wagon.
  18. R A Wrench
    R A Wrench
    from Denver, Co
    A car buddy has a 32 Plymouth 3 window coupe. I have a roof skin from a 68 Chev Suburban. We cut a few feet off at the front and it worked very well.
  19. pdunn10
    pdunn10
    jeep cherokee.
  20. Fine29, that is one great looking coupe! The proportions are right on, I like the headers too. The only detraction is the radiator top and bottom tanks and the side bands visible in the grille. I know it can be a difficult job finding one to fit or quite expensive to have one made. My father owned a radiator shop that spe******ed in custom radiators and they can get ridiculous in price, so its a case of "I have the $$ for a custom fit" or "It looks good to me". Some black paint and you wouldn't notice it so much.
    Doc.
  21. Doc,
    Still on this side of the gr***, how cool is that.
    When we out the mustang rad in the ravens he put metal mesh in front of it so it is only really noticeable from the rear. A cheap solution to an ugly problem and I agree nice old coupe. Not all millennium-ized.
  22. Porkn******, indeed its always good to be walking on the gr*** rather than fertilizing it!
    The mesh is an obvious and great solution that I didn't even consider, I need to be more awake!! You would have to be really looking to notice it from the back, I dare say it wouldn't be very obvious.
    Cheers mate, have a great day!
    Doc.
  23. Just Gary
    Just Gary
    I made a plywood template and took it to a junkyard, exactly as Mr48chev recommends.
    Turns out an '86 Toyota minivan matches a '28-31 Ford sedan perfectly. :rolleyes:
    Here's a picture-heavy thread showing how I did mine.
    http://www.jalopyjournal.com/forum/threads/’28-tudor-update-6-steel-roof-covered-by-stock-vinyl.636247/
  24. Ravenwood
    Ravenwood
    from Texas
    The absolute best fit would be a 2014 Walden. :)
  25. dexleo2
    dexleo2
    I used the roof off an 85 camaro
  26. fine29
    fine29
    from Des Moines
    Thanks for the kind words doc. The radiator was supposed to fit the 29 shell but either way it is getting a mesh insert and the rad is going to be made black.
  27. big duece
    big duece
    from kansas
    I too, will be using a '64 2 door corvair roof skin flipped 180 degrees.
  28. banginona40
    banginona40
    Yep! Maverick turned around backwards.
  29. bobss396
    bobss396
    I saw one recently on a '32 Ford sedan, came off a Taurus station wagon, so it was a 1 piece deal, looked sanitary as heck.
