302 ford will not warm up in cold weather??
Discussion in 'The Hokey Ass Message Board' started by willys_truck, Nov 18, 2014.
  1. willys_truck
    willys_truck
    Hello, I have a 65 f100 and the engine will not warm up in cold weather. I drive the truck everyday and am about to freeze. Any help is appreciated. Here are the detail, 91 5.0l 302 from a f100 pickup. The engine only had 41000 miles on it when I got it, it was torn completely down. I got the block honed, new freeze plugs,new cam bearings,new rings, new oil pump, and I bought a set of new gt40p heads. The engine has a b303 hydraulic roller can, edelbrock performer intake, carter 625 carb, and headers. The truck has a new vintage air a/c heat system. During the summer the engine will heat up fine but in the winter it will not even touch the first mark on the temp gauge. The air coming out of the heater is barely warm if warm at all. I have changed the thermostat 4 times with no change. Does anyone have any ideas? I used the 91 model timing cover and a old iron water pump so I could use v belts. I don't know if I have something mismatched or what. Thanks for the help.
  2. mtflat
    mtflat
    Back in the day we stuck a piece of cardboard in front of the radiator.... with openings in it as necessary. I still do it sometimes when the temp hits -30F
  3. George
    George
    What thermostat? a 160, should use a 180-190. Clevelands need the type that's like a br*** cup on the bottom, not sure about the Ws.
  4. Bill Rinaldi
    Bill Rinaldi
    Bottom line----the thermostat is not getting warm enough to operate----- not all bad. Try cardboard in front of the radiator to restrict air flow. BILL RINALDI
    SanDiegoHighwayman likes this.
  5. willys_truck
    willys_truck
    Last time I changed it I went to a 195 to try to have heat, if the everything is working correctly I would not think blocking the radiator would be necessary, it rarely gets below 25 here. If it is below 40 the engine will not warm up.
  6. willys_truck
    willys_truck
    I was thinking that using some newer model parts and some older parts that the water flow may be byp***ing the thermostat some way, I am a chevy guy, this is my first ford engine. So I did not know if I was missing something.
  7. Phillips
    Phillips
    I had a 65 F100 that I swapped a 302 into about 20 years back. It could be my faulty memory, but I recall there being a heater control valve, have you looked at that? Seems like I just removed mine.
  8. BISHOP
    BISHOP
    belt on the water pump is turning it the wrong direction.
    turboroadster likes this.
  9. George
    George
    Serpentine W/P runs the opposite direction of the V belt one, but you did change everything over to V belt....
  10. willys_truck
    willys_truck
    I changed the water pump over to a v belt pump and all the pulleys, i salvaged the parts for the v belt conversion from a 67 fair lane. I did use the aluminum timing cover from the 91 model truck. The newer timing cover does not have a hole for a fuel pump but I am using a carter electric pump.
  11. willys41
    willys41
    what about a blockage in the heater core. Engine at temp. but barley warm air sounds like no water flow.
  12. willys_truck
    willys_truck
    I have been driving the truck for 4 or 5 years, but I did not drive it that much. It has now become my daily driver so having heat is a lot more of a concern than it use to be.
  13. Diavolo
    Diavolo
    Under normal cir***stances, I would also say thermostat. It literally doesn't matter how big or cold the radiator and outside air is. If the thermostat is working correctly, the engine will reach operating temperature before flowing a significant amount of water through it. The only reason a radiator cover should be used is in places where it's so cold that not blocking the radiator will prevent the engine to reach operating temp. For anything other than a big rig, or living north of the arctic circle, covering the radiator should not be something that is in any way necessary. It might help a regular engine warm up quicker but the time is only a matter of minutes different.
    I would guess the thermostat is being byp***ed some way. That or you are getting a batch of ****py ones that don't work. The quickest way to test one (and you should, it's easy) is to take it and dangle it in a pot of water as you heat it to boil. Put a thermometer in the pot and watch the temp and the thermostat. There should be no movement until the water is at the point the thermostat should open. Since they are designed to open below boiling point, they will open while you can watch it.
    I would suggest getting a cheap infrared thermometer and point at stuff as the engine is warming up. Find the cold spot, find the problem. The first things to get hot should be headers, then heads, then block, then intake. Point at different spots of the item you are checking to see if you can find a cold spot.
    Without actually being there to see what is going on, I can't give a real response so this is a bump.
  14. willys_truck
    willys_truck
    The engine is not at operating temp, it will not even warm up to 120, the heater hoses and heater core are new
  15. willys_truck
    willys_truck
    I agree diavolo, I believe the thermostat is being byp***ed some way, I just do not have enough experience with sbf to know where. I do have a infrared thermometer and I will check that
  16. BISHOP
    BISHOP
    make sure the thermostat is not upside down also, should look like a tree, with the roots pointed at the block.
  17. 50dodge4x4
    50dodge4x4
    Easiest thing to do would be to pull the thermostat, and put it and a thermometer in a pan of water and see where its opening up. Its either opening too soon, or not closing completely, or your gauge is wacky. While its apart, install a temp gauge with numbers on it that you can read. If the stat proves to be OK, then you need to look for a plugged heater core, or a path for the coolant to byp*** the stat. Do you have an engine mounted and driven fan or is it an electric fan that might be running too early or all the time? You may have too much cold air coming into the car for the heater to heat. At least one of the heater hoses is coming from the motor side of the thermostat, right? Gene
  18. willys_truck
    willys_truck
    I have a engine driven clutch fan, one heater hose is coming off the water pump and the other hose is coming off the intake. I just went and cranked the truck with it cold and did not see any water flow in the radiator.
  19. Engine man
    Engine man
    from Wisconsin
    The water pump takes coolant from the bottom of the radiator and pushes it into the engine block from the front to the back, through the heads from the back to the front, into the intake manifold. From there it can go through the byp*** hose on the thermostat housing back to the water pump to circulate back through the engine or it can go through the heater core or through the thermostat, through the radiator and back through the water pump. The byp*** hose doesn't allow any significant opportunity for the coolant to lose heat. The heater core could cool the coolant slightly, maybe more if the ac is on but the engine heat usually overcomes the ac cooling capacity. The only way the coolant can get cooled significantly is by going through the radiator which would require the thermostat to be open or out of position so it doesn't block the flow.
    You could try clamping the upper radiator hose to prevent any flow through the radiator.
    Maybe enough heat radiates off the block. Try removing the fan to see if that helps.
  20. Johnboy34
    Johnboy34
    from Seattle,Wa
    I am thinking that the 91 timing cover is not compatible with the older style water pump. I thought the water pump and timing cover had to mate together in a specific way for standard rotation or reverse rotation,you have them mixed together. I have a 66 289, 71 302, and 89 5.0 and they are all different.
  21. I have the same problem on my off topic 81 Toyota 4X4. If it gets below 35 or so, no heat. Above that it will run you out. I've flushed the heater core, and the radiator. I've ran water through all the hoses. I've tested the thermostat, and tried different temp ranges, and tested each of those. I've removed the fan, and drove it all summer, sometimes in 100 degree heat, and it never got above operating temp. even in traffic. The fan is still off, and has been for over a year. You can put your hand on any part of the cooling system, and the block, with the exception of the exhaust and not get burnt no matter how long you let it run. I've blocked the radiator, and that didn't help, it just won't get hot. I let it idle for about 30 minutes, then drove it about 4 miles, pulled the radiator cap, which is new, and was warm, but not hot, and put a thermometer in the water, and it dropped 20 degrees just sitting there idling. It was at 140 when I inserted the thermometer. This truck is all stock, radiator and all. Nobody can tell me why it does this. Sorry I don't have an answer for you. I wish I did, because it would fix mine too. It just doesn't get hot enough to open the thermostat. I even tried it without a thermostat.
  22. SanDiegoHighwayman
    SanDiegoHighwayman
    K.I.S.S. it! you know the acronym right? oh the TIMES I usta WISH my Merc *would* run COOL -- in the summer of course ;) I'd "cardboard" half the radiator -- was I you --
  23. 1946caddy
    1946caddy
    from washington
    Call vintage air and talk to them. The switch that regulates the temp could be broken and your cooling the air from the ac side of the unit.
  24. Don's Hot Rods
    Don's Hot Rods
    from florida
    One possibility is that your radiator is too efficient. My 23 was that way, sbc engine and even with a 195 thermostat it wouldn't get higher than 170 on the hottest day in traffic. Going down the road it would go down to 150 sometimes. My top radiator hose would be very hot but I could put my hand on the lower hose and it was just warm.
    As a test, do the cardboard routine.
    Don
  25. ClayMart
    ClayMart
    Did the Ford engine originally use quick connect fittings to attach the heater hoses to the to the heater core, engine and/or water pump? Did you replace these fittings with more conventional pipe ******s?
    I don't know so much about Fords, but on a lot of GM models the fittings for the quick connectors often had a flow restriction built into them. My understanding was that the restrictions were there to help keep the coolant temps lower in the summer and/or higher in winter weather. If they weren't needed I doubt they would have been used in production.
    Removing these restrictions might reduce the ability of the coolant to come up to operating temperature. If there are any of these restriction currently used in your system, make sure they aren't possibly plugged up.
  26. prpmmp
    prpmmp
  27. George
    George
    The thermostat is supposed to be closed until the engine is hot enough to open it. With it closed the radiator shouldn't be involved in the problem
  28. studebaker46
    studebaker46
    I agree with prpmmp that is easy to check. every body is overthinking this you have a water flow prob that is obvious now we need to find where. and I would bet is something simple . the water pump and housing if they were not compatible I don't think they would bolt together
  29. ClayMart
    ClayMart
    I love it when someone remembers to NOT overlook the simple and obvious stuff. Which is usually my approach to tackling these kinds of problems... o_O
  30. InstantT
    InstantT
    from SoCal
    Spitballing... Moving from socal to Wyoming and the resulting elevation change caused my chevy to run so rich that it NEVER went over 150. I rejetted it and it solved the problem.
