Customs transmission upgrade
Discussion in 'The Hokey Ass Message Board' started by shadyt, Nov 21, 2014.
  1. shadyt
    shadyt
    After overhauling my 1962 fairlane 221 V-8, I made the mistake of using the 2.77 3 spd. standard transmission that was in it. No low gear synchro, slow shifting and sloppy. Turns out Ford built a better 3 spd in `63`. , the 3.03. Does anyone out there know of a better 3 , 4 , or even 5 spd. that would match up to my bell bolt pattern, 23 spline, or a different bellhousing that would match 5 bolt pattern of the 221?. This topic was already addressed on h.a.m.b. before but didn`t quite solve my problem. Any further help would be much appreciated.
  2. Jalopy Joker
    Jalopy Joker
  3. junkyardjeff
    junkyardjeff
    You can use a T-5 but will need a adapter,I think the newer 3 speeds have both bolt patterns as do the toploader and T10s.
    shadyt likes this.
  4. gimpyshotrods
    gimpyshotrods
    S10 T5, with a simple adapter.
    This, a clutch disc with splines to match the input, and an S10 T5, with the 3.76 ge****t (many lists on line show the part number, like 1352-145):
    http://www.speedwaymotors.com/GM-Manual-Trans-to-1949-64-Ford-Bellhousing-Adapter,20628.html
    Bolts to the stock bellhousing. Uses the stock clutch linkage-n-stuff.
    You'd have to fashion a crossmember, but that should not be too bad.
    "CORE" shifters on eBay makes replica Hurst shifter bases. They work well. I run one. You can get one set up for a tall stick, to the travel is not huge. Stick is up to you.
    http://www.ebay.com/itm/Core-Hurst-...Parts_Accessories&hash=item3f412d9114&vxp=mtr
    I used a Chevy truck 4-speed forged stick, cut off the tower, with the end heated, flattened and drilled for the Hurst pattern. I topped that with a ball that matched the dashboard knobs. It looks like an OEM piece, that plausibly could have came that way.
    shadyt, 270dodge and Hnstray like this.
  5. gimpyshotrods
    gimpyshotrods
    Everything after 1964 has a different belhousing pattern. If you are going to have to pony-up for an adapter, you might as well get a lower first gear, a better gear spread, and an overdrive.
    The single biggest thing, aside from fuel injection, that modern cars have, in terms of efficiency are the gears. More gears = more efficient use of the available power. You will get the power you have to the road better. Performance AND mileage will be better.
    Hnstray likes this.
  6. shadyt
    shadyt
    a big THANKS to you. I didn`t realize Speedway had that specific adaptor. Now I`ll start hittin` the junkyards for a T5.
  7. gimpyshotrods
    gimpyshotrods
    Also, I think you have a 10.4" clutch. I am hoping that someone can verify this. Some materials say that it is a 10".
    You will need a clutch disc that has that diameter, and has the S10 T5 splines, which are 1"-14 teeth.
    If 10.4" is the clutch size, then this:
    http://www.summitracing.com/parts/ctf-382114/overview/
    If it is a 10", it will take some digging, but there must be something.
    Or the equivalent, will get you going.
    You will also need a Ford to GM pilot bushing, which is:
    http://www.summitracing.com/parts/mcl-8-1380-1
    Or the equivalent.
  8. gimpyshotrods
    gimpyshotrods
  9. shadyt
    shadyt
    The bellhousing adapter plate @ Speedway includes an adapter sleeve for the pilot bushing. As far as the clutch size, I recall it being a 10 inch. Hope I can find one with a T-5 spline.
  10. gimpyshotrods
    gimpyshotrods
    The one in post #8 is a 10" disc, with S10 T5 splines.
  11. gimpyshotrods
    gimpyshotrods
    I have that adapter. It came with no sleeve.
    The only variable I can think of now is the diameter of the collar where the throwout bearing rides. I think the S10 T5 might be smaller.
    This can be swapped for a Ford one.
  12. shadyt
    shadyt
    I'll check back with Speedway on the 10 inch clutch disc because I should use a new one. There 's a swap meet coming up near here in Febuary. That will be a good place to try to locate the rest of the parts. Thanks again.
