Hot Rods Winter projects
Discussion in 'The Hokey Ass Message Board' started by scrap metal 48, Nov 11, 2014.
  1. 1941coupe
    1941coupe
    my 46 merc will be going in for paint soon, will be polishing all the stainless over the winter boy theres a ton of it lol...
  2. junkyardjeff
    junkyardjeff
    I am going to pull the motor out of my 37 Chevy p/u,it has a rod knocking so I am either going to replace it with one of my spare motors or fix the existing motor.
  3. Drewski
    Drewski
    I hope to have my F100 finished to a point that I can drive it to some of the local cruises. Got what seems like a million things to do before I can just hop in and go for a spin.
    Max Gearhead likes this.
  4. scrap metal 48
    scrap metal 48
  5. olscrounger
    olscrounger
    Gonna maybe go get another 40 coupe to do--know of two-need something to do. If I start 1st of year should be done by July or sooner depending on Uph schedule
  6. Voh
    Voh
    My plan was to get the rear fenders back on the '41 and the floor started back in, but it looks like we will be doing a new shop building!
    DeucePhaeton likes this.
  7. bgaro
    bgaro
    getting my stocker sedan ready for the streets. drop in another banger, juice brakes, lower, chop top. i'll try and keep you guys posted.
  8. gonzo
    gonzo
    I've been working on this heap.
  9. flatheadfever
    flatheadfever
    Building a 39 wide five ch***is for my 36
    koolkemp likes this.
  10. CB_Chief
    CB_Chief
    from Oklahoma
    Going to repair the transmission in our 58 Apache then put a steel floor in place of the wood and repainted the whole truck. In between working on the truck I hope to get started TIG welding the sectioned 50 Ford coupe my son is building.
  11. HOTRODPRIMER
    HOTRODPRIMER
    I like your heap! :) HRP
  12. Smokeybear
    Smokeybear
    My 48 is getting a workover. From the original L6 and 3 speed...
    to a warmed over 360 magnum and NV3500 5 speed...
    I've already rebuilt the front suspension, relocated the lower pockets to the bottom of the A-arms and replaced the springs with the Aerostar units.
    I've mounted the brake booster, hydraulic clutch, and pedals (using the original pads)...
    Once the engine and trans are mounted I'll be rewiring the car. If I get all that done I'll change over to power rack and pinion and changing the stock rear suspension over to a triangulated 4-link.
  13. missysdad1
    missysdad1
    I'll be giving my coupester a much needed facelift including narrowing the rear end and rear fenders, changing to more traditional wheels and tires, and losing some al***ude. A few other details, too, but that's the big stuff.
    Oh, and I'll be starting a new car as well. Already got a big pile of parts gathered and a top-notch ch***is builder poised to do the heavy lifting. It'll be fun! I can't wait.
    So...somebody buy my '54 Merc hardtop. I need the money!
  14. Jason455
    Jason455
    1958 f100 302 efi/aod
  15. TagMan
    TagMan
    I'm hoping to have the body work on my '36 3w all done and ready for paint by mid-summer next year, if my health holds up..
  16. ct1932ford
    ct1932ford
    Just looked outside and it is snowing and both my 32's are done. Now what?
  17. TANNERGANG
    TANNERGANG
    from alabama
    Hope to have this finished by Nashville Goodguys...finished fitting fenders this week and starting to take them all off and prep for paint.....running a one man Sign and Pinstriping Business donesn't leave much time...I'm the handyman, yardman, salesman, deliveryman and the old man that doesn't have enough hours in a day...hehehe 20140928_174152_resized_1.jpg
  18. gonzo
    gonzo
    Thanks HRP, I've been sitting on it for almost a year trying to collect parts and make space. The guy who had it before me sat on it for 30 years without doing a damn thing to it, so I guess I'm doing all right. Finally have most of what I need to make an actual car out of it!
  19. brad2v
    brad2v
    Gonna get the '57 Pontiac in my avatar running, and hopefully, able to move/stop under it's own power.
  20. bobss396
    bobss396
    I'll be working on the '59 Ford all winter. Gotta get the garage in shape so the car fits into it, get some heat going as well. First task will be to plumb the new brake system then onto a full rewire to kick things off.
  21. .
    My winter project is turning this...
    into this...
    to get it ready for the Detroit Autorama. Making a few changes to make it my own and will be changing the color as well.
  22. flamedabone
    flamedabone
    This heap will be solid and rust free by spring.
    -Abone.
    koolkemp and gonzo like this.
  23. flat top austin
    flat top austin
    New paint on my 60 impala and working on my 59?elcamino ImageUploadedByH.A.M.B.1416021476.100096.jpg ImageUploadedByH.A.M.B.1416021509.804258.jpg
    gonzo likes this.
  24. Fxnjetz56
    Fxnjetz56
    from Chicago
    46 Ford pickup:
    Riley Automotive frame
    Desoto 291 Hemi, .060 over, Wiseco forged Pistons 10:1
    Tremec 5 spd.
    9" Ford rear
  25. Notaclue34
    Notaclue34
    ImageUploadedByH.A.M.B.1416802049.378071.jpg this is my 34 Ford 2door sedan. This will be my first attempt at a hot rod. I will post pics as I progress.
  26. ardun1932
    ardun1932
    from Iowa
    Brock --
    I'm just down the road from your place. Would like to see your project some time.
    Bob
  27. Hot Rod Nut
    Hot Rod Nut
    Ardun,
    Hi, yea, anytime your free, please stop in, I'm in my shop Mon. through Fri. Call if you want to make sure I'm here and not after parts or something. Cell-319-79-8063 or house 319-752-1036
  28. 36couper
    36couper
    from ontario
    I'll be taking this heap apart and ditching the wide whites, flat black, the leaky 305 and some other questionable parts. I have it apart now and so far have installed new front springs, corrected the rear spring setup, starting to pound out the dents. Will be selling quite a few things off it so keep your eyes on the cl***ifieds. It will eventually be painted either dove gray or folkstone gray.......depending on the budget. I did get a Vortec 350 for a smoking deal so that will go in sometime this winter.
  29. das858
    das858
    Going to install a hilborn on the dragster in place of the carb, and get my 1964 Dodge wagon in shape for towing the dragster.
  30. mike bowling
    mike bowling
    Change course to Zero-one three niner-I was going to work on a coupe (Frankencar), but I think this one is getting the nod for the winter of 2015. Already in the garage and not as big a challenge as the coupe.I read somewhere else on here, it ****s when it takes twice as long to get half as much done!And I know the feeling! Happy Thanksgiving All.
