Projects The Hardscrabble Hop-Up; A 1940's Style 'T' RPU build
Discussion in 'Traditional Hot Rods' started by gwhite, Jul 21, 2013.
  1. gwhite
    gwhite
    SUPER MODERATOR
    Jamie, that's a very good question! I would guess this combination would be good for 65-70 horsepower and 155-165 ft-lb torque give or take. Dual carbs, a modern ignition system, and free-flowing exhaust would likely give another 5 hp/10-12 ft-lb.
    This is probably in line with the average "hot" late-30's to mid-40's 'banger. IMO, valve float is the limiting factor in most of these engines, and the primary reason the OHV conversions and larger displacement V8's could not, for the most part, outperform the 'hopped up' flathead 4's on the lakes. To combat this, I had steel valve spring spacers machined to increase spring pressure, which should reduce float. That said, my A motor will be limited to 3500-4000 RPM, as that's probably the practical limit to stock (styled) con rod fasteners, shimmed valve springs, and splash oiling. This corresponds (roughly) with a 90-95 mph top speed (with stock gearing and 30" diameter tires)....a good speed in the late 1930's - early 40's.
    Speedy Canuck and Hitchhiker like this.
  2. kidcampbell71
    kidcampbell71
    Nice.....about twenty pounds per horsepower then....at least. Yep, that thing is gonna' fly. Thank you sir.
  3. 65gregg
    65gregg
    from Willis, TX
    It looks like you should be ready for Round Up if you'd quit typing and start working, just kidding. Keep at it!!!
    gwhite likes this.
  4. dwest999
    dwest999
    from Saline, MI
    Looks great Gary. I am hoping you're going to post a video of the test fire!
  5. gwhite
    gwhite
    SUPER MODERATOR
    Probably not...still have more asphaltum paint to sniff, uh, err paint first :)
    Actually, I'm on a bit of a hiatus for a little while...broke my tailbone last week, so I'm learning the hard way that the phrase "****hurt" is a real and painful truism.
    Shoot neighbor, I may call you when the time comes to see if you want to accompany me :)
  6. jmiller1918
    jmiller1918
    from Tulsa, OK
    The 90 m.p.h. Club! ;o)
    gwhite likes this.
  7. Runnin shine
    Runnin shine
    See Gary, if you wouldn't have invested so heavily to get into the "90 mph" club, your pocketbook may have had the padding required to save you from injury.
    "I need my mirror boy"
    Jungle Jalopy, volvobrynk and gwhite like this.
  8. ct1932ford
    ct1932ford
    Just catching up on this build and I like it!:cool:
  9. loudbang
    Come on don't hold back there HAS TO BE a "backstory" to go with this LOL.
    kidcampbell71 likes this.
  10. gwhite
    gwhite
    SUPER MODERATOR
    Honestly, it's not all it's "cracked" up to be, hahaha. Ouch. @3wLarry says I'm "****" (no pun intended) about the details - I'm a little fanatic about keeping all my parts organized...to make a long story short, I was dragging a heavy container across the garage and lost my balance - caught a piece of angle iron right in the tail. Literally.
  11. loudbang
    So you "backed" into it LOL.:rolleyes:
    volvobrynk likes this.
  12. Hitchhiker
    Hitchhiker
  13. 3wLarry
    3wLarry
    from Owasso, Ok
    Sorry to hear your injury will make you 'fall behind' in your updates.
    ba-dum-bum
  14. PINEAPPLE
    PINEAPPLE
    I just read this entire thread..wow! I love it. The ****pit area looks perfect! Great car. subscribed.
  15. jerseyboy
    jerseyboy
    Sorry about your *** break:rolleyes: I've broken mine several times. Not much you can do about it and it ****s to sit on it!
    I had to sit on mine on the train from RI to Jersey. Man that was a long ride! Hope your bum is feelin better soon:D
    BTW, you still want the panel? I'm not in any rush, just wondering.
  16. Speedy Canuck
    Speedy Canuck
    The result of sitting down on the job.
    And yes, I cringed reading about your fall. Heal quickly. Cracked tailbones are no fun at all. And you can't even get your friends and family to sign the cast.
    volvobrynk, Hitchhiker and gwhite like this.
  17. gwhite
    gwhite
    SUPER MODERATOR
    Thanks, fellas.
    @jerseyboy, my apologies...ADD kicked in and I completely forgot. Sending you a PM.
  18. rail job
    rail job
    from Michigan
    There is always some part of building a car that's a pain in the ***.
  19. gwhite
    gwhite
    SUPER MODERATOR
    @ct1932ford I had to delete that...hurts too bad to look at it. YIKES, hahaha
  20. tb33anda3rd
    tb33anda3rd
    just lay on the creeper backwards.
    gwhite likes this.
  21. Runnin shine
    Runnin shine
    That's a pic I want to delete, ugly.
  22. OLLIN
    OLLIN
    That's the name for your car! "fanny" or "fanny mae" haha
    Speedy Canuck likes this.
  23. 65gregg
    65gregg
    from Willis, TX
    C'mon guys let's leave the ***inine remarks behind, heal, quickly Gary.
    gwhite likes this.
  24. volvobrynk
    volvobrynk
    from Denmark
    I missed your Updates, I came in about where your engine pics was.
    And I feel powerfrace ol' henry;
    No engine need more cylinders, then a cow has teats. Espacialy when my 4 banger is so damn good.
    B) :D LOL.
    I've been sitting on that one for three pages, but still not as painfull as it must be for you!
    Get Well soon, and get cracking. :)
    gwhite likes this.
  25. -Brent-
    -Brent-
    Love this build. If you'd be interested is selling the pump/gauge bezel, I would be interested to use it with my pump and gauge.
    Your first set-up is similar (very very alike) to what I will be doing in a couple weeks.
  26. gwhite
    gwhite
    SUPER MODERATOR
    Sorry Brent, just saw this...shoot me a PM.
  27. gwhite
    gwhite
    SUPER MODERATOR
    Small update and a setback; motor is ready, got a quick test fire in, but couldn't run her very long...carb is spewing gas all over....need to tear it apart again.
    Will get video if I can get the carb dialed in well enough to actually run it for any length of time.
  28. Carter
    Carter
    Glad to see an update!
    Where is carb leaking from?
  29. Hitchhiker
    Hitchhiker
    Sounds familiar
    gwhite likes this.
  30. RainierHooker
    RainierHooker
    from Tacoma, WA
    Good luck Gary! I'll be trying to fire mine in the next few days...
    Posted using my Lil' Orphan Annie Secret Society Decoder Pin
    gwhite likes this.
