Technical Experiment with a Deuce frame
Discussion in 'Traditional Hot Rods' started by Andy, Nov 24, 2014.
  1. Andy
    Andy
    A while back I did some experimenting with some 32 frames. I put a stock one up on jackstands. Two were under the rear kichup and one under the front crossmember. I tied a 283 block to the left rear corner and got a load on that corrner. I put a 2x 12 across the front crossmember and measured from the right frame horn to the ground. I then sat on the 2x12 so I had about a three foot moment arm. The one side went down 2 inches and the other side went up the same.
    Pretty scary.
    The source of 32 cowl shake.
    I had a unboxed repo frame with a Ch***is Engr style crossmember.
    I measured again and could not accurately measure the deflection. Maybe 1/8 inch.
    I went ahead and boxed firewall forward and over the kick up.
    I still saw maybe the 1/8th.
    I would love to try this with other frames. Especially the ones with the tubular crossmembers.
    I did not see any aditional stiffness from all the boxing and welding.
    Anybody have one to test?
  2. Hitchhiker
    Hitchhiker
    Interesting.
  3. 3wLarry
    3wLarry
    from Owasso, Ok
    I think a stock unboxed '32 frame will be just fine if you replace the K-member with an X-member...that's what I'm doing on my next build.
    kidcampbell71 likes this.
  4. Ned Ludd
    Ned Ludd
    I've been mulling over interconnected suspensions for ages. Torsional rigidity suddenly becomes for all intents and purposes a non-issue. Here are some of the results of my investigations: http://www.jalopyjournal.com/forum/threads/31-a-fhc-build-design-thread.374184/
    Here are some things to read up on:
    https://www.google.co.za/search?new...5.0....0...1c.1.58.hp..8.5.1957.0.Pz7-foljnKc
    https://www.google.co.za/search?new....0....0...1c.1.58.serp..18.7.3197.6Uq1vZ3ZtAQ
    https://www.google.co.za/search?new...3.0....0...1c.1.58.serp..2.3.1460.NVLmLC2HlMg
    2CV
    Hydrolastic/Hydragas
    Packard
  5. Kerrynzl
    Kerrynzl
    The deeper the X-member is , the better.
    Also , if the OP had spreader bars in the frames it also would be better
  6. You will find that properly bolting your body down and adding your engine and transmission will change that twist to the better. nearly everything that you bolt to the ch***is becomes part of the structure.
    That said when I was a kid we bolted a balls to the walls 426 in a A sedan and made it hook. it didn't take long before we were replacing the wood with steel.
  7. wingman9
    wingman9
    from left coast
    I've been working on a '32 frame from that other car company - Chevrolet. I picked up the driver's side rear frame horn a good 2" before there was any motion at the p***enger side front. Not ideal, the body was breaking apart in a few places. It didn't help that there is a lot of wood in the body. I boxed the frame and put in a tubing cage. It's solid as a bridge now.
  8. HOTRODPRIMER
    HOTRODPRIMER
    When we built the frame for my Deuce pickup I used a original frame and boxed the front and the rear,I then used a Ch***is Engineering X member and I am really happy with the way it turned out,absolutely no flex at all. HRP
  9. alchemy
    alchemy
    The center of the X needs to be connected with a rigid center like HRP shows in his pic above. If you add a center X but only have a bottom chord to hold up the tail of the transmission, it will twist like sheetmetal. The forward forces along one leg of the X as it twists need to be counteracted by a a rearward force from the opposite leg. And the legs need to be connected top and bottom to press upon each other.
    Any flex not held in the frame will radiate up into the body. And if you just spent $5 to 10 grand on that new paint job it will now be chipping and cracking soon without a solid frame under it.
    29EHV8 likes this.
  10. Bruce Lancaster
    Bruce Lancaster
    El Polacko's page on his K-to-X conversion has some comments on torsion. And an interesting piece!
    Issues I see in here somewhere...boxing gives you 2 very stiff rails, but the ends are still attached one to the other by Ford Crossmembers which obviously don't contain a lot of metal, especially if the rear of the front member has been trimmed away. X-ing adds more in the middle.
    On steetrod X-ing, a lot of what I see in ads and features has a baffling lack of serious connection between the two halves, as Alchemy and Primer are saying. The >< parts are built like bridge girders, with more metal and bracing than the entire original frame, but it looks like many have that final connection made with a single welded tube and the nearly irrelevant bolt-in trans mount. Huh?? That is almost reduced to two pieces of dead weight rather than a real X member.
    Clearly adding a floor plate and a hump over the middle welded to the sides would do a lot.
    Nobody seems interested in depth of the frame...body adds some deep reinforcement, but it is pretty frail. especially on a roadster.
    Look at the '32 firewall...it is shaped perfectly, with cowl hoop and 45 degree legs, as a deep crossmember, but again it is not a tremendously strong piece. What if you made a tubing hoop right behind the body channel of the firewall and tied it into the frame either by welding or by a much stronger than stock flat piece against the rail, then added welded tube at 45 degrees where the toe-board mounts?
    Other places some serious stiff could be sneaked in would be in a tubing-hoop welded to a steel firewall between ****pit and trunk or, a very traditional way, add a roll bar with braces back into trunk.
    And...look at the typical tin box that mounts the seat cushion. What could that do if you made a new one of twice the gauge, made to bolt flat to floor with the bolts running into frame rail?
    Depth I think could add a LOT of stiffness beyond the normal approach.
  11. X38
    X38
    Me too! At the end of the day all that tubing is for naught if the sides aren't joined with anything decent:rolleyes:
    Also, a well known frame brand has this type of deuce frame with tubing everywhere yet their A Model frame is made from simple tapered 4x2 with ONE centre crossmember! Both the deuce and the A will get the same powerplant and suspension. That I don't get.
  12. brady1929
    brady1929
    Wow, you guys need a hobby!
    Montana1 likes this.
  13. Runnin shine
    Runnin shine
    There was another car company in 32? Better yet, there was a year of manufacture other than 32? Not an original joke but I couldn't resist.
    "I need my mirror boy"
  14. alchemy
    alchemy
    Hot rods aren't our hobby, they are our life! And we want our loved ones to last, not shake apart.
    29EHV8 likes this.
  15. hemiboy
    hemiboy
    Those old frames are supposed to flex like crazy (BAD roads or no roads)- why do you think so many '32 frames where built into 4 wheel wagons!
  16. 383deuce
    383deuce
    You sure can tell winter is setting in and guys have spare time on tap.
    But it is very interesting I will say. That is why I went with Brookvilles 34 cross member set up on my latest deuce frame. Would have liked to used ElPolacko's, just did not have the bucks.
  17. Pewsplace
    Pewsplace
    ElPolacko's Deuce X member is super strong and probably one of the best on the market. I have used the CE one and one I made using 2 x 5/3/4 x 11 ga. C channel which proved to be easy to fabricate. The reason Ford went to the X member from 33 up is for the very reason stated above. Cowl shake is not to be taken lightly if you have just spent your entire savings to have the car painted. I build 33's so unless I use the ASC rails my X is included from Ford. Let's hear from some more of you who build your own. Here are a couple I like:
    I don't who made this X but it looks strong when tied in top and bottom. Adding side braces like a 35-48 also make a big difference in rigidity.
    Here is another example showing the modified original center and the added cross brace for the radius rods.
  18. Runnin shine
    Runnin shine
    This is why I'm building a tidy chromoly roll bar in my PU even though the boos will probably start rolling in...now! I'm also not that keen on seeing it in there but...
  19. brady1929
    brady1929
    Just a joke. Insert smiley face here.
  20. verde742
    verde742
