Technical Official" 4 speed, performance clutch and bell housing thread''
Discussion in 'The Hokey Ass Message Board' started by Hackman, Nov 23, 2014.
  1. Hackman
    Hackman
    from Butte, MT
    Mods please delete this if I am off my rocker.
    I have searched high and low for information on actual internal and external modifications to Muncie, T-10, Super T-10, Sag ect. for street strip use. With the HAMB's m***ive knowledge base from racing and street use in years past, I think that starting a tech thread on the subject is in order. I am a 4 speed nut and would like to aid in this as much as I can but, as a younger guy, I would probably be a freshman on the subject.
    I recently built the coupe in my avatar as a severe street, performance minded hot rod. growing up in drag racing, I wanted to cross the line into crazy fast just a little while still having some street manners. The idea was to use old school parts to create as killer of a combo as I could and go beat up on new Mustangs and such, just like you guys did in the hay days of street wars. The only problem, as I am finding out, is that these old crash boxes need some modifications to make that happen. It is an art form in its self and I KNOW that this forums members have more knowledge about them than any other.
    So when starting out on this journey, I was really lost when it came to 4 speed info on the web. Sure there were many searches that pointed out ID, shifters, basic info and all that I did find was greatly helpful and appreciated. But as far as an actual organized thread dedicated to the subject, I came up short.
    So what do you guys think? Can we cram all of that knowledge into a thread? I (and I'm sure many more) would be pumped to learn about all of the tricks, parts, sources, costs, ID's, ratios, shifters, modifications ect. to any piece of the definitive hot rod trans.
    Ponti461 and Tudor like this.
  2. Hackman
    Hackman
    from Butte, MT
    You guys must be sleepin. This would be a great thread.
  3. kasselyn29
    kasselyn29
    If you are talking about Muncie four speeds there is a new book out written by Paul Cangialosi it's available on amazon. Loads of good info in it.
    loudbang and cktasto like this.
  4. Hackman
    Hackman
    from Butte, MT
    Boom. That right there is good information. We should also list any literature anyone knows of. The thread should cover all of these "like" transmissions. Lets get it rolling.
    Thank you k***elyn29
  5. 3wLarry
    3wLarry
    from Owasso, Ok
    blatant self promoting post here...
    I've got a 1967 Muncie M-20 wide ratio and a 1963 Borg Warner T-10 close ratio trans that can be pried from my grasp $$$ :)
    kidcampbell71 likes this.
  6. Hackman
    Hackman
    from Butte, MT
    Larry, that is great info! Wish i could buy them both! Good luck with the sale.
  7. chevy57dude
    chevy57dude
    stillrunners and loudbang like this.
  8. seb fontana
    seb fontana
    from ct
    Well Hackman I'm pretty sure there was articles in HRM but damn site never lets me search...Here is first level...Grind every other syncro tooth off 2nd gear and every other tooth about 1/4" down the slider side that would engage 2nd gear and remove all the teeth from the br*** syncro ring for second gear..Do the same for 3rd and 4th gears , sliders and syncro rings...Keeping the br*** syncro rings allows some slow speed shifting like on the street but full no interference with speed of gear change at the strip leave the br*** out but not sure how to keep the slider detents, works great in a Ford top loader as detents are in the fork rails too..Will have to shift fast all the time otherwise it burrs the teeth [from grinding] up and either binds the slider and/or wears the teeth out...Next step, not street friendly unless you can master double clutching is "face plating and Dog rings"..Check Liberty gear as I think they still make these items, at least for T5's but you will get the idea..
  9. Hackman
    Hackman
    from Butte, MT
    Awesome info right there! I have heard about the synchronizer modification as well. That is an old school trick and is very cool to learn more about. Keep it going guys. This could be a very helpful thread to many.
  10. The37Kid
    The37Kid
    Someday down the road I plan to attach a T-10 to my 354 HEMI to have a time perfect 1962 build. Bob
  11. seb fontana
    seb fontana
    from ct
    I hate to say it, but I will..:D I probably threw out at least five whole T10s and maybe another five in dissasembled parts back in 89' when I moved...Couldn't find anyone to take them..All Ford based..
  12. Hackman
    Hackman
    from Butte, MT
    That hurts me. Deep inside.
    I fight tooth and nail for them around here. No one builds stick cars anymore it seems. I have been trying to buy them up as much as possible.
  13. wvenfield
    wvenfield
    I recently picked up an early 70's M21. It's going to go into my 56 Pontiac. Hopefully I'll have no further need for this thread but now it will be easier to find if I do.
  14. pat59
    pat59
    I think I'll get a copy of that book.
    -Pat
  15. stillrunners
    stillrunners
    from dallas
    sorry.....but what Fontana said - everyone seems to be talking 5 or 6 speeds.....
    in my stock/cars.....T10's - Stude/GM/Ford, 833's including 833OD's and TOD'S....out of early top loaders/cars at the moment......will see if I can dig some books out but what's been mentioned would most likely be in them...
  16. Hackman
    Hackman
    from Butte, MT
    Stillrunners, that would be awesome! This is the kind of info im talking about. Anything will be super useful to the thread.
  17. Hackman
    Hackman
    from Butte, MT
    Bumpin for the day crowd.
  18. 60 Belair
    60 Belair
    There are quite a few super muncie cases out there now I dont know if they are all made by the same company or not, and iorn midplates is suppose to be a huge improvment for muncis, also some really good gear sets Italian company I think Maserio? suppose to be bullet proof but saying that there are quite a few diff gear sets and manufactures out there now. Can we modify the ***le to include clutch tech and which ones will actually support over 500hp
    reliably?
    cktasto likes this.
  19. Hackman
    Hackman
    from Butte, MT
    That is a great idea! Thank you for the info. Going to be a super helpful thread.
  20. Hackman
    Hackman
    from Butte, MT
    How about that ***le? Does that cover it?
  21. 66cayne
    66cayne
    Okay, Im in. I need help too. I have a mid 60s Biscayne that is being upgraded from smallblock/Saginaw 3 speed to 496BBC/M22 this winter. I have the M22 now. It is a stock build, no Super Case or other mods. I am already paranoid about hurting it behind a big BBC. My understanding is the M22 was actually built as a road racing trans, not for drag racing and hooking up. Thats how you snap the ears of them. I know they ran one in Two Lane Blacktop, but hey, that was a movie. I also need a good clutch setup. Centerforce maybe or old school ? I do have a Lakewood sheild which will be installed. I want to keep my toes...
  22. 60 Belair
    60 Belair
    I am running the fairly expensive ($430.00 ) centerforce dual friction behind my blown small block and it is allready not a happy camper! I am afraid I am going to have to step up to the dual disc? What are you guys running? I am afraid the old school clutch setups are just not going to do what we are wanting (survive on the steets and track with mild to severe abuse) and nice street characteristics to boot.
    Andy
  23. Hackman
    Hackman
    from Butte, MT
    I recently built a 49 Chev pickup for a customer thats a little non trad for the HAMB. The truck is outfitted with a 600 hp pump gas 427 Dart small block. The trans is a tko 5 speed and I went with a Hays single disk clutch and a billet flywheel combo. They rated it to 600 horses and I have heard good things about them. A local fellow drag racer is running the same combo with good results in a big inch Olds 442. That car stands on end.
  24. Hackman
    Hackman
    from Butte, MT
    My coupe has a billet Hays flywheel and a solid hub stock car disk from speedway. The pressure plate is also a stock car diaphragm unit from speedway. I will say I am impressed with how it works aside from it wanting to be in or out. But you kind of figure it out quick. I would run it in another car too. Good bang for the buck.
  25. The37Kid
    The37Kid
    That's ok, I'm sure a nice numbers matching one will turn up when I'm out of money. Bob
    need louvers ? likes this.
  26. Good thread idea. Not directly relating to my plans for Celica 5 sp behind 138" inline six. Should be a very interesting thread.
  27. saltflats
    saltflats
    from Missouri
    Did you brake in the clutch ?
  28. pat59
    pat59
    Hey, If one wishes to tear down a muncie to check it out and replace the gaskets. Are there any special tools that are needed, or tools that make the job a whole lot easier?
    -Pat
  29. Subscribed
    Dustin
  30. gtolarry
    gtolarry
    from Texas
    Im in . How about expanding this thread to show clutch linkage pics on your hotrods. I'm building a 32 and would like to see some ideas.Thanks
    cktasto likes this.
