Hot Rods Swapmeet junk
Discussion in 'The Hokey Ass Message Board' started by mikyboy, Nov 26, 2014.
  1. mikyboy
    mikyboy
    Bought a chevy flex plate bolted it up to the motor and the trans,put it in the car and @#$%^! Always take your measuring tools with you! Some junk out there. IMG_0044.jpg IMG_0043.jpg
  2. mikyboy
    mikyboy
    Someone knew it was s**** but still took it to the swap meet to sell !! The good one is the bottom one.Top one obviously a reject.
  3. txturbo
    txturbo
    You can buy new ones for about $30
  4. alchemy
    alchemy
    Yeah, why buy something like that used?
  5. low budget
    low budget
    from Central Ky
    Whats wrong with it?
  6. Weezy1930
    Weezy1930
    from OHIO
    I saw a vendor once at a meet selling a Texaco Fire Chief gas sign as vintage. Reproductions have the date painted on the opposite side of the vintage ones so they can be identified as repop. But the vendor had chipped the date off and "rusted" the spot so the sign looked aged and vintage. He claimed it was the real deal.o_O Just walked away.:rolleyes: Buyer beware.
  7. mikyboy
    mikyboy
    The mounting surface to the crank has a 4mm difference meaning it was too tight against the converter.
  8. mikyboy
    mikyboy
    Where?
  9. txturbo
    txturbo
    Auto parts store, transmission shops....etc
    O'reilly has them in 3 different price ranges.....$19.95, 39.95 and 94.95. Not sure what the differences are.
  10. Hotrodmyk
    Hotrodmyk
    Speedway SBC $22 to $24.
    Weezy1930 likes this.
  11. patmanta
    patmanta
    from Woburn, MA
    Make a new shop clock out of it?
  12. txturbo
    txturbo
    They work good for storing crankshafts...
    Hotrodmyk likes this.
  13. Weezy1930
    Weezy1930
    from OHIO
    Sell it in one month, one year or keeping it awhile.
  14. Jalopy Joker
    Jalopy Joker
    yep, measure twice - install once. we all have screwed up somewhere along the line.
  15. low budget
    low budget
    from Central Ky
    I wonder what caused it to be like that,for a diffrent application? bent?
    Maybe the seller didnt know either, I wouldnt have noticed and definitely wouldnt have thought to check the tolerance or even known what it was suppose to be on something like that
    Bubba1955 likes this.
  16. txturbo
    txturbo
    Could have been installed backwards and bent when the torque converter bolts were tightened.
  17. alchemy
    alchemy
    Those are very hard to install backwards. The little ridge at the center hole prevents it, except for a major idiot.
    kidcampbell71 likes this.
  18. Weezy1930
    Weezy1930
    from OHIO
    Build an idiot-proof part and they'll go and build the better idiot.:p
    I am living proof.:oops:;)
    56don and kidcampbell71 like this.
  19. low budget
    low budget
    from Central Ky
    Just curious here but you say you had the motor and trans bolted together before you put it in the car, did you not try to get the torque converter bolts before putting it in the car?
    Did you have the torque converter turned and clicked into the pump three clicks?
    Seems like I remember 4mm or more worth of space (on a normal one) between the torque and flex if the torque is all the way back where its suppose to be.so the torque should have still turned even with this one if thats the case, I could be wrong, I have been before :D
  20. mikyboy
    mikyboy
    I wish I had attempted to do up the converter bolts before it went in the car. At least I didn't put oil and trans fluid in it !! As for the plate,I bet it was a GM reject that ended up in the dumpster out back,maybe the guy working the press screwed up and pressed out a lot more.
  21. low budget
    low budget
    from Central Ky
    ...so the torque converter was all the way in?
  22. mikyboy
    mikyboy
    Yep.
