Let's Talk Cyclecars
Discussion in 'The Hokey Ass Message Board' started by Bigcheese327, Dec 4, 2007.
  1. motoklas
    motoklas
    from Bern, CH
    ... a pair phtos of the same modelle!
    Zoran
  2. Kume
    Kume
    absolutely gorgeous - It must have been hard to part with.
    Thanks for solving the mystery - I wouldn't have thought it was 1400cc - do you have any other specs on the motor ?
  3. SR100
    SR100
    That wide skirt looked French to me. I would have guessed Majola Type B (59x90mm, 984cc) With a 59mm bore, a 1400cc engine would have a 128mm stroke. Not out of the range of possibility for prewar engines, but pretty remarkable. I found a similar clement-bayard engine on carandcl***ic.co.uk.
    It is probably newer. It has a different magneto setup & the water inlet is different (not visible in this pic.)
  4. Kume
    Kume
    Thanks SR100
    I found these picks of a Clement Bayard motor which matches mine in all respects . I also understand that they produced an 1131cc motor which is more consistent with my bore and probable stroke (60mm x 100mm).
  5. SR100
    SR100
    The Beaulieu Encyclopedia of the Automobile lists the larger engine at 1356cc, which would be 59 x 124mm. Do you have plans for your engine?
  6. banjeaux bob
    banjeaux bob
    from alaska
  7. Kume
    Kume
    Thanks again SR100
    My old wooden ruler must have been more accurate than I thought at 59mm. I must get a copy of that book - it sounds like the bible. I was relying on an old 1964 book on French vintage cars by John Bolster. As to what plans I have for it - As I don't have any other parts for it I will see if anybody wants it in NZ I think there are about 6 Clement Bayard's down here but I am not sure what models.
  8. motoklas
    motoklas
    from Bern, CH
    ... or to find some veteran car sh***is and built replica, or re-creation of some ******* from the era?
    Ciao,
    Zoran
  9. SR100
    SR100
    It is missing the lower crankcase, which holds the camshaft on that engine. Without it (or a borrowed one to copy) it will be a difficult engine to rebuild.
  10. Kume
    Kume
    I agree - i will see what is around parts wise but suspect it best goes to someone who owns a runner.
    shame as it is very light and just 30cm long - would have been ideal for a little special.
  11. banjeaux bob
    banjeaux bob
    from alaska
  12. Kume
    Kume
    banjeaux bob likes this.
  13. banjeaux bob
    banjeaux bob
    from alaska
    I like that Bignan too.Those are probably the best images of it I have seen.
  14. Kume
    Kume
  15. banjeaux bob
    banjeaux bob
    from alaska
  16. metal45
    metal45
    from WI
    New panel for a Morgan 3 wheeler
  17. motoklas
    motoklas
    from Bern, CH
    Hello There,
    Who needs gasoline engines, electric-motors, or pedals – when we have gravity?
    (legend said that cycle-cars were developed in Spain, before The Great War: compe***ors in gravity races put small engines on their cars to drive them up hill, instead walking and pulling them; later used to drive them from home to hill and back, and later to drive them around... more about Spanish cycle-cars next time)
    2013 Goodwood Festival of Speed Soapbox Racers
    http://www.youtube.com/watch?v=Wi7UUPrQ7_A
    http://www.youtube.com/watch?v=_kIgU7vID3k
    ...and, one old - just for nostalgia!
    http://word.photos/index.php?photo=1DLxuXPUDv4&keyword=maine%20street%20soapbox&***le=1935%20All%20American%20Soap%20Box%20Derby%201935%20Chevrolet%20Newsreel&video=1
    Ciao, Zoran
  18. banjeaux bob
    banjeaux bob
    from alaska
  19. noboD
    noboD
    Some of those look like the illegal soapbox cars from a few years ago.
  20. Zerk
    Zerk
    For those unfamiliar with SFVISBF's (San Fernando Valley Illegal Soap Box Federation) exploits:
  21. KFC
    KFC
    from UK
    Ive just made the seat for the owners "other" C6 also restored by thornely kelham
  22. fredvv44
    fredvv44
    I cannot believe the lawyers haven't put a stop to that. What fun!
  23. motoklas
    motoklas
    from Bern, CH
    Lawyers?
    Probably didn't see any money in gravity racing!
    However, nothing strange that they call thier races "ILLEGAL". Quite dardevil racing, but much better than those stupid RED-BULL "races"...
    Probably the simplest and cheapest form of racing on four (or sometime three) wheels... I saw some more "normal" in which I would like to take appearence, in spite of my 64 years. Once, here in Bern I saw one such racer parked at gr*** in front of house, but never find anything about such races in Switzerland... Probaly, that there are some - have to check!
    Ciao,
    Zoran
  24. banjeaux bob
    banjeaux bob
    from alaska
  25. noboD
    noboD
    Wasn't trying to hijack the thread. The illegal guys were stopped. For those that weren't here back then a guy was killed running into a parked car. Let's get back to cycle cars.
  26. banjeaux bob
    banjeaux bob
    from alaska
    Kume,not worry about being on topic or not! Great find.Did you bring home the rest of the machine shop too?I'd like to see pictures of THAT!
    Bob
  27. Kume
    Kume
    An immense boost to my 1913 Alldays & Onions cycle car project this week with the purchase of a running motor and radiator.. It was being used to run an overhead belt set up in a private workshop since it was removed from the car in the 1950s. Sadly no idea what happened to teh rest of the car. Rare items retained include the throttle and timing levers formerly mounted on the steering column and chain oilier that mounted on the dash. Has an interesting Binks 3 jet carb fitted (not original).
  28. Kume
    Kume
    I guess technically the Alldays midget was a micro car rather than a true cycle car.
    Unfortunately the workshop went elsewhere as part of a deceased estate. Funny how these things come out of the woodwork every now and then. I recently acquired a spare gearbox for my 1920 Wolseley that was being used on an old engineers lathe and was in pristine condition inside. Beats trying to use weathered parts from old bush mills.
  29. Grahamsc
    Grahamsc
    from Colorado
    image.jpg Couldn't find an image of a complete auto but here is a pic of a Japanese light car ch***is by the name Sekine.
    The driveline is angular and drives a gear at the left rear wheel.
