Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. gimpyshotrods
    gimpyshotrods
    The 1963 260 z-bar will work.
  2. ditchdigger
    ditchdigger
    from Eugene,OR
    I apologize in advance for the terrible pictures but...
    Trying to identify the bellhousing I used when I did the T5 swap. The whole mess was a swap meet score. The CPC adapter came with a Bell, clutch, flywheel and starter.
    The starter is going out. I remember that the starter from my 63 3spd/170 did not bolt up so I used what was included. Just looking for an idea of what to order.
  3. gimpyshotrods
    gimpyshotrods
    It looks like a 9" Falcon-6 clutch bellhousing.
    If the starter is held on with two bolts, and not three, you would ask the parts jockey for a starter for a 1965 Mustang, with a 200.
  4. ditchdigger
    ditchdigger
    from Eugene,OR
  5. Mike51Merc
    Mike51Merc
    No, the 260 is narrower at the bell than the 302, therefore the Z-bar is wider.
  6. gimpyshotrods
    gimpyshotrods
    Isn't the ball on the block?
  7. Mike51Merc
    Mike51Merc
    Yes it is. The back of block (at the bell) is narrower.
  8. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Okay, now I'm not following Mike. I thought all Windsor SBF's were dimensionally identical 'cept the 351 that has a taller deck height...
    Is the ball mount in a different location on the block? I'm too lazy to drive a clutch so I was just wondering...
    Posted from an IBM Selectric
  9. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Early 221 and 260s were 5 bolt bell housings. Later 260s and 289s were 6 bolt bell housings. The 6 bolt blocks are about 1&1/4 inches wider than 5 bolts. It is not a big deal all you have to do is shorten the z bar from the block side.
  10. Mike51Merc
    Mike51Merc
    Fuzzy said it. The block itself is the same width head-to-head, but the bell mounting flange is narrower.
    I sectioned out a piece of my old z-bar, installed a steel rod inside the hollow tube, and put deep allen set screws through both the tube and the rod to create a 2 piece telescoping z-bar. I needed the two pieces because my headers prevent installation of a one piece z-bar.
    @Evilfalcon1961 the 1965 z-bar is prescribed for 302 swaps. You can get one at www.falconparts.com for about $78.
  11. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Got it.
    Didn't consider the 5 bolt vs 6 bolt mount difference.
  12. gimpyshotrods
    gimpyshotrods
    I am still considering this, but on a different hood. Mine has some serious pitting, and I am not sure that I want to put all of the time into correcting that.
    Of course, now that I am looking for a '60-'61 hood, I can't find one.
    Usually, I can find them stacked like cord-wood.
  13. need louvers ?
    need louvers ?
    I'll keep my eyes open around here and save you some shipping if I can.
  14. gimpyshotrods
    gimpyshotrods
    Thanks. Two months ago, I could have purchased 4. Now....
  15. need louvers ?
    need louvers ?
    That's the way it always works.
    gimpyshotrods likes this.
  16. scf100
    scf100
    from Georgia
    1961 Wagon.....PO installed 1985 HO 302.....just replaced EVERYTHING in front end with v-8 stuff.......gotta rewire car and install my Comet rear end then back on the road.......
  17. redzula
    redzula
    Anyone know if you can buy generator pulleys that have the fan. I had to destroy mine just to get the front cover off during my rebuild it was rusted to the armature. My kit came with new bearings, armature and brushes but the only pulleys I seem to find are without the fan and I actually think they are for an alternator. I have a mustang Gen somewhere but it's been years and it's probably worse than this one was.
  18. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    So I finally decided to **** can all the relays, circuit breakers and the weather proof fuse panel that I'd installed on my left fender apron inside the engine compartment to isolate my tired n' brittle 50 year old factory wiring harness from my 95A 3G alternator and all the other **** that I've added to car.
    After doing a bit of research, I decided to go with the Ron Francis Express fuse box and harness for Falcons.
    I liked the features of the fuse box (18 circuits with 16 fuses). I also liked that the wiring could be cut to length after it was run to the fuse box, or away from it. The fact that it looks like circa 1966 HeathKit wasn't very appealing but I decided to take the plunge.
    The first thing I had to decide was where to put the fuse box- it's HUGE! (4 3/4" W x 7 1/2" L x 3 3/8" H).
    There's not much room under the dash of my 63 sedan- what ain't heater box or cowl is wipers or steering column.
    I made a primitive drawing and headed to ClutchDumpin'Dan's place for him to fab me up a bracket to mount the fuse box in:
    I never kept anything important in the glove box anyhow....
    The next thing I needed to address was how the hell was I gonna' get the GM headlight switch to work in my dash without using the **** ugly billet bezel (that was too short anyhow) and knob that was supplied with the kit.
    So I barrowed a 63 head light switch from a buddy and......
    Left: Original 63 Falcon headlight switch with 7/16-24 bezel nut (and factory fuse panel on the plug!)
    Middle: Ron Francis (GM) headlight switch with 7/16-28 custom bezel nut made by my long suffering machinist.
    Right: ugly Ron Francis billet 7/16-28 GM headlight switch bezel nut
    7/16-24 and 7/16-28...
    I also had no idea how old the electrical portion of my ignition switch was- I went ahead and got a new switch and the correct plug from Falcon Enterprises. Because I didn't wanna' deal with any more of the goofy 60's vintage FoMoCo .180 bullet connectors than I had to, I added a 6 pin Deutsch connector to the ignition plug.
    I'm queer for Deutsch connectors.
    More Later.....
  19. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    So on the last 70* day we had here in my part of Virginia ( Dec 1st) I spent the morning bombin' around in the car and began tearing all the wiring out of the car in the afternoon.
    Here's the under dash harness complete with firewall block connectors:
    Looks worse than it was mostly because I had to cut through the 50 year old harness tape to separate the wiper harness from it.......
    Nice shoes, huh?
  20. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    So I started under the hood-
    Top: 100A HMEG fuse for ignition/accessory circuits
    Middle: 125A HMEG fuse for 3G alternator
    Bottom: Ground point
    Zero gauge battery cable to master shut off in trunk
    Zero/one gauge negative cable from battery to engine block (behind alternator pivot mount) to ground point
    Electric water pump relays with delayed shut down- runs the pump for 2 minutes after the key is shut off.
    L to R: 6 pin Deutsch for MSD 6AL and timing controller connections, bump start relay, 30 circuit breaker for bump start relay and weatherproof H-4 headlight relays (swiped from a Toyota parts car, I think, at a buddy's shop) cooling fan terminal block,
    The stud above everything is a power point.
  21. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    When I'd done as much as I could under the hood, I moved inside:
    Ignition and modified headlight switch installed:
    If you peek into the left corner of the dash, you can see the 6 pin Deutsch connector for the ignition switch. The 2 pin on the right is for the fan override switch.
    Two post dash ground point- ten gauge ground wire that goes to another covered ground point on the left front fender apron. Everything for the dash will ground here.
    Fuse panel beginning to fill....
  22. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Gauge panel wiring w/ 6 pin Deutsch. Cooling fan controller in the background.
    Gauges were an earlier project:
    L to R: engine oil pressure, voltmeter, trans temp, trans throttle valve pressure
    Neutral safety/back up light switch 4 pin Deutsch
  23. Twinpilot001
    Twinpilot001
    I ve had a 1965 comet Caliente- origional 289/ 4 speed car since 1984. added c-6 rebuilt ****** then too. still driving it. Now building a 64 ranchero- was a 6 cyl/ 3speed car- now having posi =4:11 rear with new front suspension & hd 390 mustang springs. building a 351 w - stroked to 427 & AOD ****** for this summer. Should be fun!!
  24. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    I'll say it again; I'm queer for Deutsch connectors.
    8 pin for the turn signal switch.
    Wires run for instrument cluster.
    The 2 pin on the right is temporary; I had to put a warning light in series so the alternator worked when I started the car to test my work.
    At this point:
    Car starts and runs and charges.
    Electric choke functions.
    Electric water pump and cooling fan work.
    Lower gauge panel (oil press, voltmeter, trans temp, trans throttle valve pressure) and AFR gauges all work.
    Wipers, heater fan and cigarette lighter all work.
    I wired the instrument cluster next.
    For more info on the cluster search "Vandalizing a Falcon Instrument Cluster"
  25. Falcon61wagon
    Falcon61wagon
    from Indiana
    @ Those of you who did the Weber 32 36 conversion.
    Did you use a idle cut off solenoid and why? Or why not?
  26. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Turn signal/brake lamp/ horn wiring done.
    I didn't want to bore you with more Deutsch connector pictures.
    Dimmer switch hopelessly rusted to floor.
    A minor victory.
    Next: Head lamp/ parking/tail lamps. Nice harness, huh?
    My very sad fifty year old FoMoCo dimmer switch and a NAPA DS115 GM dimmer.
    The flash didn't flash....
    Pulling the headlamp/running lamp harnesses....
    EEEEK! All this is headed for the trunk...
    Front parking lamp/turn signal wring....
  27. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Fuse box ****oned up.
    Power point cover made from a couple of tube plugs. I'm not happy with it because it looks like a sore ******.
    Any ideas?
    I'd incorporated a "data" plug into the old harness, so I did it with the new harness:
    A bunch of cast off gauges in a Radio Shack project box: Tachometer, vacuum, oil pressure (for setting throttle valve pressure) and a voltmeter......
    Plugged in. Saves me from running back and forth to look at the engine speed or vacuum
    Minor Clean up:
    Coil, distributor and engine sensors all got the same 1200* heat wrap that my fuel line got in a different diameter.
  28. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Original tail light wiring harder than Chinese arithmetic:
    Only a couple of frozen bullet connectors:
    Rear ground point for all lights:
    Left side complete aside from some detailing:
    I had to pull the battery to get to the right hand tail light.....
  29. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Old right tail light harness. The metal tube in the foreground is the fuel tank vent.
    So I pulled the battery.....
    Ground point completed: Tail light ***emblies, back up lights and fuel tank grounds; the 10ga cable goes to the rear body ground point that is directly connected to the negative battery cable.
    I really wanted to use something besides the original bullet connectors. The wiring is so brittle and dirty, I couldn't even get solder to stick to the original wiring without using a bunch of liquid flux.
    Nobody repops Falcon tail lights with back up lights yet.
    You can buy the lenses, but not the reflector ***emblies.
    So I got out my trusty ratcheting crimper and....
    And it's back together.
    I made a new 3A fused lead for my Battery Tender Plus (shameless plug).
    Master cut off, spare 6AL box and hour meter...
    And that's it. It all works. Thanks for letting me spam the thread.....
  30. mcnally351
    mcnally351
    from boston
