Technical ***Santa's Banger Sleigh: December 2014 Banger Meet***
Discussion in 'Traditional Hot Rods' started by Jiminy, Dec 1, 2014.
  1. Jiminy
    Jiminy
    Here is the banger link list .
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Flat Ernie maintains the monthly link list. Every month is listed:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    Post #105 of link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=6
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://www.centuryperformance.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    http://www.scribd.com/doc/22469332/The-High-Speed-Internal-Combustion-Engine-Ricardo-1931
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    Maybe these links should be posted early in each months meeting.
    If anyone knows of more, please post them.
    " I've tried nothing ...and I'm all out of ideas."
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
  2. Holy Chevy, its December already...............
  3. 48thames
    48thames
    from so cal
    I found a crack in the block of my B motor. It still runs good, but don't know if it is going to get any bigger.
  4. denis4x4
    denis4x4
    from Colorado
    Checking in so that this will show up on the "Participated" column on the iPhone app.
  5. Yep, it won't get any smaller.
    Worst is it will leak a little.
  6. Bearing Burner
    Bearing Burner
    from W. MA
    I've never heard of one healing itself yet.
  7. Binger
    Binger
    from wyoming
    Found a couple of pictures of my running gear progress. Thought I would post them.
  8. Crazydaddyo
    Crazydaddyo
    I like the trans set up!!!
    :D
  9. Binger
    Binger
    from wyoming
    I found out Auto Restorations is closed. They were the only ones who made a clutch disc for my T-5 set up using a stock A bell housing. I am not sure what to do. I don't really want to change all the work I have done and run a AA bell housing. AA parts are hard to come by and a new adapter is expensive. How hard would it be to modify and balance a Speedway Disc hub to work for my set up. Should have ordered the disc when I got the rest of the parts last year. Hindsight is 20/20 I guess.
  10. Crazydaddyo
    Crazydaddyo
    How big of a hurry are you in?
    I may have to make one soon. I could make you one too.
    BCCHOPIT likes this.
  11. -Brent-
    -Brent-
    Binger, contact Bill, @BCCHOPIT , he may be able to help you out. He runs a pretty successful side business that partly focuses on bangers. This may be something he's interested in.
  12. Binger
    Binger
    from wyoming
    Thanks for the help. I am trying to do my best to not have to change all the fab work I have done so far.
  13. Binger
    Binger
    from wyoming
    Not a terrible big hurry. I would like to have it by the spring so I can get the car on the road. I hope to have it running and driving for the summer and work out all the bugs and then take it all apart for paint and upholstery next winter.
    Thanks for the lead. I will send him a PM.
  14. 5280A2
    5280A2
    Please explain what it is about the Speedway clutch disk that makes it unworkable for an A clutch housing but apparently OK for an AA set-up? I thought that there was also an Astro-van clutch disk that supposedly worked for a T-5 adapted to an A or B motor. Can someone enlighten me??
  15. Bluto
    Bluto
    Father and Sons in LA
    323 2325146
    Please tell Frank "Merry Christmas" from Jim in Poland
    These guys build anything you want and top quality. They did stuff fir my race cars for years NEVER A PROBLEM Never!!
    Crazydaddyo likes this.
  16. Crazydaddyo
    Crazydaddyo
    There is about a 2" difference in the length of the A and AA bell. The distance from the flywheel to the trans is longer on the A bell. That puts the spline for the T-5 trans. input shaft in a different location requiring an extended clutch disk center hub. This is a special piece made by Auto Restorations.
  17. jkeesey
    jkeesey
    Finally getting some more work on my rpu driver so I'm gonna subscribe here.
  18. 5280A2
    5280A2
    Thanks for the explanation. I have a Dwight Bond adaptor for an AA bellhousing and had always planned to use a Speedway or Astro-van clutch disk when I finally put it to use, so I was a little concerned when I read Binger's post.
  19. woodz
    woodz
    Hey Binger,
    How did you adapt the T5 to the closed drive shaft? Is it a 4X4 ******? Did you make that adaptor?
  20. This is an answer I gave to 530sandman in another conversation, just in case he doesn't see it.
    Hi, I'm sorry to bug you but I'm having trouble finding a set of B rods. Crower has a 9 week waiting period due to the holidays. I've read that you've had good luck with the Jay Steel / Taylor Rods. Are they still available? If yes, would you please tell me a website or phone number of who to contact?
    Thanks,
    Joe
    Joe,
    Sorry I'm slow getting back to you; I just got back into town.
    Jay Steel died several years ago. His wife sold the business. It struggled for a year or so and closed it's doors. I don't know what happened to the inventory. I was just looking at my rods last night. My engine's all apart for a "Major". They have no identifying names or numbers; but, if I had to guess, I think they're Crowers. And, off topic, I misspoke on this thread a few weeks ago when I said that my crank was ground out by Joe Panek of Roto-Faze. It's from Crower. Joe ground a cam blank for me.
  21. skryla
    skryla
    from Brick, NJ
    I'm looking forward to tomorrow morning. TJ from throttle jockey originals just finished some fabrication and ***embly for me. I now have a driving, stopping car. Now it's my turn. Need to put the rest of the sheet metal back on. I'm looking forward to this, my first pre-war car. Should be very cool.
  22. I might be able to find a set or two of the Eubanks rods made a few years ago.
    "B" size, with inserts. not sure on the pins. Both 4130 or Alum.
    John
  23. Hi, I first want to thank Old Dawg for posting my message.;)
    johnneilson,
    I'm wanting to run steel.
    Thanks,
    Joe
  24. Bluto
    Bluto
    Any of you guys know what these are? I'll post the answer in a day or two
  25. Nice.
    What head and exhaust manifolds are you using?
  26. waxhead
    waxhead
    from West Oz
    Very nice. What can you tell us about the engine.
  27. Binger
    Binger
    from wyoming
  28. woodz
    woodz
    Thanks Binger, much appreciated.
