Id my steering wheel and column?
Discussion in 'The Hokey Ass Message Board' started by 54sled, Dec 4, 2014.
  1. 54sled
    54sled
    Meausures about 17 inches
  2. 54sled
    54sled
  3. tb33anda3rd
    tb33anda3rd
    it looks like the 33 and 34 car [supposedly] steering wheels i just bought at hershey, they were both 17" but the hole size for the shafts were different and the one with the larger hole had an extra piece of hub that stuck out the back that i don't know if you could see with yours on. this larger hole wheel matched the steering wheel for a 37 chevy truck i am working on. so to make a long story short i would guess mid 30's chevy.
    54sled likes this.
  4. 49ratfink
    49ratfink
    mid 30's Chevrolet. 1935 ... probably a few years on either side as well
    54sled likes this.
  5. 49ratfink
    49ratfink
    here's one on the google.
    54sled likes this.
  6. 54sled
    54sled
    Now do any other wheels fit that column?
  7. tb33anda3rd
    tb33anda3rd
    i am looking for one like that except 16" . don't mean to hyjack.
    have you pulled it off to check the taper size?
  8. 54sled
    54sled
    Have not pulled it,was trying to easily swap it for something a little better looking
  9. tb33anda3rd
    tb33anda3rd
    better looking? you must mean fancier.:)
    54sled likes this.
  10. 55 dude
    55 dude
    keyed or splined?
  11. 54sled
    54sled
    I would have to check
  12. tb33anda3rd
    tb33anda3rd
    when you pull the wheel, tap the two holes that the horn contacts go through and use a puller. don't try to bang it off like i tried when i was 14, or you will be hunting for another.
    54sled likes this.
  13. 49ratfink
    49ratfink
    I don't know when they started the "Chevrolet" splines we all know and love but I would not be surprised if they had them in 1935. .
  14. TagMan
    TagMan
    My stock '37 Chevy coupe has a keyway - no splines. The wheel in your pic appears to have grooves on the face of it, but my '37 is smooth. Also, the '37 wheel has bright metal "spears" on each of the three spokes.
  15. Fat47
    Fat47
    What car is it on. It may be original to the vehicle. As mentioned above, you need to remove the horn ****on and check to see if it is held on by a nut with a key slug or is on splines. That would help us to help you identify it.
  16. 54sled
    54sled
    It's on my 27' ford roadster
  17. 54sled
    54sled
    They are raised lines and has a key way
